Question about Memorex MX4107 CD Shelf System
Volume control I can turn the volume down with no problem, but the volume up button doesn't work. I have the cover removed, and can see the volume control area, now what? Thanks in advance, Marie
0 characters
1 Points
Factory reset sony mhc-6700
I don't think that will cure the problem. Volume controls these days are done by an IC. If it fails it can cause the volume to go up on one channel and not on the other. If you trace the wiring back from the volume control you will eventually run into the chip. I would have thought that the two channels will go into one chip and not two separate chips for each channel, but it depends on how complex the system is. If you are lucky the PCB will even tell you that the area is tone and volume control.
Feb 27, 2016 | Sony Audio Shelf Systems
Why does the volume increase when I'm trying to turn it down on my AIWA receiver?
Your volume control is bad. If you are good at this kind of stuff, you can remove it from the board, open it up and clean the contacts. Otherwise you need to get it replaced.
Jul 20, 2014 | Audio Shelf Systems
Remote control volume doesnt work
May be some sort of leakage. Remove the back cover and see
Apr 08, 2014 | Panasonic SC-AK44 CD Shelf System
Sticky volume control when turning up and down
The volume control needs a good flush out, take the unit apart to expose volume control pod, buy some electronic contact cleaner and flush the pod while turning the volume back and forth, repeat 2 or 3 times. Note some pods have small slot where you can spray.
Mar 08, 2012 | Audio Shelf Systems
Volume goes all the way up by itself
1. The volume up button on the remote may be stuck down- try wiggling the button to get it out. If it isn't the remote if the local volume control is in fact two buttons perhaps that one is stuck in or damaged.
2. The dvd sounds like it needs a new laser unit- a worn laser unit may play up like this.
It might be time for a new one as replacement can be sometimes more than the cost of a new one nowdays!
Jan 17, 2010 | LG LFD7150 Shelf System
Need to use remote to change volume
this aiwa equipment failure is common, is that the contacts within the volume botton causing misreading get dirty when going up or down the volume. you have two options the first is to buy the button or pull it out and clean it is not difficult. bye
Jun 14, 2009 | Aiwa NSX-A999 Shelf System
remove knob and use some pressurised air to blow out any scum thats built up. yes a remot would still work.
Jun 02, 2009 | Sony CMT-HPX10W CD Shelf System
the volume control needs to be cleaned. this control is a step switch basicly. and the switch contacts are not making proper contact. cleaning this requires dis-assembly and desoldering so if you are inclined to do this work happy fixing if not it shouldn't cost much to fix.
Jan 19, 2008 | Aiwa NSX-A115 Shelf System
Volume knob
Normal Aiwa compact shelf units use what is called a jog switch for the volume. Usually you can tell the difference if when you you turn the volume up or down. It goes a short distance and seems to spring back. In this case there are two momentary contact switches. One for up one for down. With a plastic lever on the back of the knob that bumps the approriate switch whether turning down or up. If the lever is broken it will bump up against one but not the other. If it is broken plastic you know how good gluing plastic goes it never seems to hold.
Aug 02, 2006 | Aiwa NSX-A777 Shelf System
Memorex MX4107 CD Shelf System Logo
14 people viewed this question
Top Memorex Audio Shelf Systems Experts
Tom Chichester
Are you a Memorex Audio Shelf System Expert? Answer questions, earn points and help others
