Can I plug my 47" LCD TV into a 700/450 UPS? - Computers & Internet
  • 55 Answers
Yes. Depending on the draw of your TV will determine how long it will run when normal power is lost but you can plug it into a UPS.
Posted on Dec 20, 2008
47 inch vizio tv just has static noise when power supply is plugged in, no lights or anything else
Hi Chris,
This is a power supply issue and there is nothing you can do yourself about it. Please consult a good local TV technician.
May 27, 2015 | Vizio VO47L 47 in. LCD TV
Vizio 47
It sounds that the main board has got faulty. Seek check support.
Jun 07, 2012 | Vizio E470VL 47 in. HD-Ready LCD TV
Lg 47 ld500 lcd tv wont power on
Not likely as you are hearing the main power relay click and it is after the fuse.
First place to look will be the power supply board inside the set--look for puffed up caps and or check voltages etc.
5_3_2012_2_44_29_pm.jpgcaps should have perfectly flat silver tops with no puffing up on top and no brown material leaking top or bottom.
May 03, 2012 | LG 47LD500 47" LCD TV
How to exit off photo from vizio tv without remote
First unplug the Tv plug , After you do that hold your power button for about 1 minute then plug your Tv plug back.
Jan 07, 2012 | Vizio VO47L 47 in. LCD TV
I have a crack in my 47" LCD tv and I need just the lcd panel.
The LCD panel will be more than the newn 47" TV, it is limited production part and hard to come by, you can contact www.shojimmy.com to get some ideas.
Sell the TV for parts.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Oct 20, 2010 | JVC 47 in. LCD TV
OUr 47" LG LCD TV takes over 12 hours to turn on......why?
My bet is your power supply board has gone bad and some capacitors need to be replaced. If it's under warranty, take it to the shop for repair. If it's not, then you can replace them yourself or if you know some one who solders electronics they could do it also. To keep this from happening again buy a ups backup power supply which will condition the power to the tv and other components and save you alot of time and trouble later.
Oct 08, 2010 | LG 47LG50 47 in. LCD HDTV
Sometimes the volume just stopes in the middle of a program and sometimes it makes some type of noise
A hardware failure or an electrical problem.
I have seen this issue on several tv set's where it is related to an electrical issue. The essayist solution is to install a AVR which will ensure constant correct voltage and frequency. An AVR should last years and will protect anything you have plugged into it. This is a good investment even if your issues ends up not being related.
I often have people ask why this problem would start all of a sudden, it is because of changes in you electrical grid in the neighborhood and some electronics are more sensitive then others.
here is a cheap reliable
http://www.amazon.com/OPTI-UPS-SS1200-Stabilizer-Automatic-Regulator/dp/B0007P11M4 avr unit
Sep 14, 2010 | Vizio VO47L 47 in. LCD TV
I have a shadow on my 47" LG LCC7DF HDTV LCD TV
This is usually caused by dirt trapped between the lcd filter layers and appears when the screen is pressed, pressing the layers togehter producing an internal dust smear..This can only be removed by stripping the lcd down and cleaning the filter layers
Oct 17, 2009 | LG 47LC7DF 47 in. LCD HDTV
Vizio 47" lcd no picture no sound has power
this could be one of two problem. first, check if you have back light. If you do then the problem is with the M/B. Second, if you don't have back light then the inverter is bad and needs to be replace.
May 18, 2009 | Vizio VO47L 47 in. LCD TV
Lg 47 inch tv sound
We had the same problem of pathetic sound quality and volume with a sony brava. Thats just the way they make tv's these days because most people buy a surround sound system as well. We bought logitec computer surround sound speakers for about $140 and plugged into the ear jack, problem solved, we have heaps of volume and stacks of bass.
Dec 21, 2008 | LG 47LC7DF 47 in. LCD HDTV
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
