Question about Savin 9935DP Laser Printer
Add toner message
I can not clear the "add toner" message after adding new toner cartridge.
  • alstonlt Oct 17, 2008
    the add toner light came on and we installed a new toner bottle since we can not get the printer to clear the add toner light. Is there switch we need to enact to clear this problem. We have turned the printer offf thinking this may clear this problem but this did not work. The printer will not print even with the new toner installed.
  • dherzog Feb 26, 2009
    Replace Black PCU and error light will not go out even after I change the Black toner cartridge.
Replaced the toner supply pump and clened the toner supply hose. It works
Posted on Apr 28, 2013
CHANGE MOTOR TONER
Posted on Oct 30, 2007
  • 21 Answers
Have you tried another toner cartridge? eyo7 eyoifiok2005@yahoo.com
Posted on Mar 30, 2007
SOURCE:
How to clear or reset toshiba etudio18 dealing with the toner empty message. The machine has no numbers
This will work with these printers: Toshiba e-STUDIO520/600/720/850 and e-STUDIO523/603/723/853 series MFP's
- Press "USER FUNCTIONS"
-Then click "USER"
-Then "GENERAL"
-Now click "TONER NEAR EMPTY DETECTION"
-At this point a screen will open up asking you if you want to clear the TONER LOW message, click YES
Please note that "TONER LOW" message is different than the "ADD TONER" message, that means the cartridge is completely empty and you must replace the cartridge!
Hope you found it useful!
Dec 17, 2015 | Toshiba Office Equipment & Supplies
I had a jam, upon clearing the jam, the printer will hang with the motor turning, and the display saing 'adding toner'. I changed the (new) toner, for a brand new one. Still message will not go away.
Leave the machine working to see the next message of Adding Toner. Usually the next message of "Adding Toner" is "Ready to Copy".
If the next message is "Add Toner", i suggest you to pull the new toner kit out and push it a little bit harder and check again.
If you power the machine off and on again, can you see what the message about toner is, Original or Unknown Toner is installed?
Sep 30, 2014 | Kyocera Office Equipment & Supplies
Toner dumping straight into toner bag
use original toner OR reset toner indication
Sep 12, 2012 | Toshiba 2860 Copier
Lanier LP235c display says Add Yellow toner
Try removing the toner cartridge and gently cleaning the electrical contacts for the sensor. Sometimes they get toner residue on them and give false readings.
Aug 04, 2012 | Lanier 5235 Printer
I fix new drum,developerand toner but still showing add toner
after you do all those things you will have to add toner. If you did all that because it was asking for toner you wasted all of that work (and parts) by not adding toner.
Feb 17, 2011 | Xerox CopyCentre C118 Copier
Error message add toner follow instructions for adding toner. The toner doesn't need replacing it is quite full
all you have to do is take out the cartridge and put it back in and restart the machine
Jul 13, 2010 | Office Equipment & Supplies
My Ricoh Aficio MP 161 said to add toner but still won't copy
Check your old toner bottle and make sure the plastic "cap" is still in the bottle. These machines have an occaisional problem with the caps coming off (not the black screw off cap but the semi clear cap under the black screw off cap) and staying inside the black plastic "cup" that you insert the toner into. If the cap is missing it may be stuck inside this cup. If the cap is still in your old cartridge then try opening/closing the front door and letting the machine cycle to see if the toner light goes out. May have to do this several times. Had one customer just yesrday have to do this to clear the toner light after adding toner.
Good Luck.
Jan 28, 2010 | Ricoh Aficio Mp- 161 Copier
What is the meaning og service code coo 70 for minolta ep 1054. thanks
Toner bottle rotation failure. This is usually caused by the toner bottle/cartridge not being installed correctly. Did you just recently install a new one?
Best solution is to try and remove the cartridge. Then leave it out, and close the machine back up and let it run. Only re-install the toner cartridge after the machine has completely stopped.
The machine rotates this cartridge when adding toner. So what happens is the add toner light comes on and if you open the machine to add toner while it is running the bottle stops turning and is thus out of it's home position.
Nov 25, 2009 | Office Equipment & Supplies
Studio 230 added a new toner cartridge
When adding toner to the developer unit, it will load from the toner. So, if toner is empty, it will ask for replacement. Normally u can hear noise from the toner when loading.
Mar 19, 2009 | Office Equipment & Supplies
Add Black Toner Msg.
Try taking out the cartridge and reinstalling it. Was this a original ricoh toner cartridge or a el cheapo cartridge off the internet?
Mar 19, 2008 | Ricoh Aficio CL2000 Laser Printer
1,927 people viewed this question
Top Savin Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Chris
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
