Hazy, washed out picture on Magnavox 51mp6100d
I'm at my girlfriend's parent's house for the holidays and they have a Magnavox 51mp6100d/37 rear projection TV with a horrible picture. Objects on the screen have halos around them and the on-screen adjustments don't do anything for this issue. I've called customer support which was less than helpful. How do I open up the TV and what can I clean inside and how? Also, where can I find a replacement lamp and how can do I do that?
  • bgroemer Dec 19, 2008
    Ok, I do have a better picture after cleaning and adjusting the internal controls, however I've found out that there is something very wrong with the blue lens/bulb. When the red and green lights where on by themselves, the picture was defined. However, when the blue was on by itself, I could hardly see any picture at all. The halos are all blue. I've adjusted everything on the black box as well as unscewing the wing nut and adjusting the lens manually. Is there something wrong with the bulb that I can replace? Is something wrong with the lens?
Need to change fluid in the blue tube
Posted on Jun 05, 2009
  • 5,138 Answers
Remove back see if you can get to tubes top lenses clean all 3 from dirt/dust/ After cleaning off lenses there is a black control box has 3 controls on top 3 on bottom these are to adjust each tube R-G-B Tubes screen/ focus adjust one tube at a time--- Like to adjust red turn g,b.screen drive off turn red up adjust focus to a clear picture ,then green same and blue If you turn screen up to much it will either shut off or you will see Drive lines adjust back down.OK after doing this turn color off in menu adjust all 3 screen controls untill you have Black and white picture try to adjust as close as you can to get bl/wt picture when that is done now turn color on and you should have alot better picture.
Posted on Dec 19, 2008
  • ladywinn
    ladywinn Dec 19, 2008
    I started to tell you blue was more then likely to be very weak or bad .Replace tube and you will have a nice picture on tv then! So it turns out that my answer is a Fixya rating.
SOURCE:
Ihave a 52" Magnavox rear projection TV. Model no.
You need a convergence kit available at tvrepairkits.com
Jan 04, 2011 | Philips Televison & Video
My magnavox 51mp6100d/37 rear projection television has a distortion problem. When I suse the adjustment box for the rgb tubes, red is fine, blue seems to just apply a blue haze, not really go great...
This problems is not the lamp problems.This problems is call convergence problems.The colors R,G,B mis alignmrnent, have ghost picture or 3D pictures.The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts nust be change in the convergence board to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Sep 02, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox 51mp6100d/37 power light flashes and
you can get replacement boards from www.tvrepairworld.com you can call or send them a email they respond quickly.
Apr 15, 2010 | Televison & Video
My television is actually a magnavox 51mp6100d/37 51" rear projection and im having a problem with the picture! it is really bright in the middle and then going towards the outsides it gets darker and i...
YOU HAVE ALGAE IN THE BLUE AND GREEN TUBES IT DOES NOT GROW IN THE RED TUBE TAKE OFF THE FRONT COVER AND LOOK IN THE TUBES COMPAIRE IT WITH THE RED WHEN IT IS ON WITH A PICTURE WILL NOT HEART YOU TO LOOK IN THEM WITH IT ON DONT TRY TO FIX IT YOUR SELF
Feb 09, 2010 | Philips Magnavox 51MP392H Rear Projection...
We have a Magnavox 51MP6100D/37 tv that doesn't have a manual,
http://www.retrevo.com/support/Philips-51MP6100D%2F37B-TVs-manual/id/278dj091/t/2/
Nov 25, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Power button flashs
you have a bad power supply
Oct 26, 2008 | Televison & Video
Sound
Bill,
That's a DPTV585 chassis I believe and there are no known common problems with the audio circuit. Does the volume bar still come on-screen when you change the audio level? When you turn it up high is there any faint sound or static noise you can hear? Any possibility it's just muted?
Try unplugging the unit for 15 minutes and plug it back in and see if the audio returns. That will reset the micro in case that's simply latched up and confused over what command(s) it was given. And let me know.
Bill
Dec 06, 2007 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 51" TV Screen
take the broken piece to the hardware store and have a piece of plexiglass cut the same size. thats what we did and it worked really well.
Jan 31, 2007 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
907 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
