Listen port i have bitcommet verson 1.07 and i using vista ultimate at the bottom of bitcommet where you havethat your logged in next to it on the right is a DHT connected and ihave a green light = ( all is good i think,) next to that is a yellowlight with my ip address saying ( blocked )???? i can download its slowbut it works, when i hover my curser over the yellow light is says mylistening port is blocked, you can still download but speeds will beslow = thats my problem slow speeds top speed..it goes on to say please check firewall or nat configurations?,,,, what is my NAT ?i can download and upload but just slow. sad_rain69@yahoo.com if u have any solution..thanks..
gunja
  • 43 Answers
SOURCE: Very Slow Connection
= try this to check your computer speed (at first checked all the connections the mdoem . computer. filters and cables ) 1. delete all the cookies and files on the computer 2 . disable the firewall and antivirus on the computer 3 . poweroff your modem ,router (if any) and computer and after 1 minute start them in the same serial 4. now again check thwe speed of your computer 5. if their is no result then contact your service provider definatly their is some problem in the lines
Posted on Apr 22, 2007
  • 317 Answers
SOURCE: my RCA router needs to be port fowarded
Go to this page: http://www.portforward.com/routers.htm Find your router on this list and it will give you a detailed description on how to port forward.
Posted on Aug 23, 2007
  • 10 Answers
SOURCE: how to configure ports on my modem
U will have to learn port forwarding.............u didn't mention router ur using since differnt router have different settings.......goto http://192.168.1.1 and search for port forwarding settings. Me too had this prob before port forwarding speed 15~20Kbps download and after 197~208Kbps.
Good luck with port forwarding.
Posted on Feb 13, 2009
  • 6 Answers
SOURCE: bitcomet - listening port is blocked
add bitcommet to windows firewall exceptions list
if that doesn't help, you need to open appropriate port in your router/modem
Posted on Mar 26, 2009
  • 83 Answers
SOURCE: 1st time installation: cannot install modem properly
If the internet light is red, it is not fine. Are you talking to AT&T support?. While on the phone with them, I had to re-add my username and password with IE and then they had to reset my connection and it worked. Give AT&T Internet support a call.
Posted on May 30, 2009
I have a hp compag laptop just cant seem to log on with it
try to go to safe mode by tapping F8 in safe mode
or use F11 to go to recovery partition and try system restore
and if u have upgraded it then reload the OS as this is a common problem with Vista Ultimate as some security updates wont install
for Vista Ultimate
Mar 22, 2010 | Microsoft Windows Vista Ultimate Edition
Tip
Installing a printer on the F8T030 Bluetooth AP in Vista
This worked for me...
Install Printer Driver on PC
Select driver properties - then PORTS tab
Add Port
Select "Standard TCP/IP Port" then "New Port"
Next on Wizard
Enter IP address of AP (ensure you have a fixed IP address)
Port name can be anything unique (I used "Belkin_USB2")
NEXT
Wizard will search but not find anything.
Under Device Type select Custom and "Settings")
Set Protocol to LPR
Set Queue Name to "upper" or "lower" depending which USB socket you have used on the AP
Ensure "LPR Byte Counting" is enabled - this is important.
OK
NEXT then FINISH and Close "Printer Ports" dialogue.
Apply settings and try test print.
Worked ok for me (Vista Ultimate 64)
on Oct 15, 2008 | Belkin F8T030 Bluetooth Access Point w/...
Toshiiba P200-Vista Ultimate. I can listen to music but cannot get any sounds in the Program Sound Events in windows. IE. Windows Logon-Logoff-Start up etc. I hope you can help, I've tried enerything....
You might have the system sounds disabled, to enable them go to control panel - hardware and sound - under sound - change system sounds. This has all the sounds in vista. I hope this helps!
Jul 12, 2009 | Ultimate Sound (195-012-001) 2-port KVM...
I have some problem for vga graphics mercury 845 motherboard for vista ultimate verson
dear friend
graphics of windows vista ultimate on intel 845 chiset are nopt fully supported
you will get only basic graphics quality on this motherboard
thanks
Apr 10, 2009 | Computers & Internet
Apache is not runing
Not Only Skype , Team-viewer is also using port 80 .
To know who uses port 80 go to command promt and type
" netstat -aon " in command prompt and and PID of app listening at port 80 and find athe app on Task Manager -> Servies and Stop it , Then try to Run Papche
If it is not solved
Try by editing httpd.conf of apache (can be found at c:/xampp/apache/conf/ )
If not solved Please attach the error log in order to troubleshoot it .
(log path c:/xampp/apache/log/error.log )
Mar 27, 2009 | Microsoft Windows Vista Home Premium with...
Bitcomet - listening port is blocked
Mar 26, 2009 | Computers & Internet
I need product key for vista ultimate
Hi there
Its against company and expert policy to give out product keys for pirated software.
Don't enter a product key when you install Vista, you will then have either 3 or 28 days to find one, even if you find a key the OS will take, chances are Microsoft will not activate it because the keys are already in use.
You can purchase a key from Microsoft.
Good luck and thanks for using Fixya!!!
Feb 27, 2009 | Microsoft Windows Vista Ultimate Edition
Product key of vista home besic
u shud not install vista of trial version.......... go for free installation of vista at google and than download it on your pc
Jan 08, 2009 | Microsoft Windows Vista Ultimate Edition
Autocad is not inastall
Vista is 64 bit O/s & your cad is not supported the application & also your cad is not vista verson that,s why it is not working, if you want to use either change the O/s or cad.
Mar 05, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
79 people viewed this question
Alun Cox
David Payne
David Payne
