Question about Zanussi ZHQ575 Electric Double Oven
Oven not working
Hi i have a zanussi mod no zhq575x the oven is not heating up the fan runs and the power light come on do you think its the thermostat at fault?
  • Zanussi Master
  • 744 Answers
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Posted on Mar 05, 2014
  • Zanussi Master
  • 3,463 Answers
You will find it is the heater element that is faulty
To access it remove panel at rear of oven compartment, there you will see the element.
Undo screws and pull it towards you, disconnect the wires, but don't loose inside, or you are in trouble.
Fit new element and test.
Plz rate this solution
Thanks.
Posted on Dec 19, 2008
My zanussi FM9232 fan assisted oven is not heating up, the fan is working
Nov 04, 2010 | Zanussi Ovens
Hi my zbf260w built in fan assisted oven is not getting heat in the oven department.The fan and grill are both fine but not the oven,
If the fan is working o/k, then y ou need to replace the oven element, located at the rear of the oven compartment behind removeable cover.
Sep 26, 2010 | Zanussi Ovens
Oven fan not working so oven not heating up
have the motor checked and replaced if no runnig the oven will not heat as it is a safty measure
on moter the fan blade could have been loose, the motor bearings could be worn out or the fan motor gone kaput
Jun 15, 2010 | Zanussi ZBQ665 Electric Single Oven
ZANUSSI Oven E025
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Asker's Testimonial " thanks i will have my husband look into that. " - 2gunsally
May 15, 2010 | Zanussi ZBF360 Electric Single Oven
My zanussi zbf360 will not heat up in the oven ,the fan works fine as you can hear it and the grill still works ,any ideas what it can be ,
Mar 14, 2010 | Zanussi ZBF360 Electric Single Oven
Fan not heating
Mar 12, 2010 | Zanussi ZBQ665 Electric Single Oven
Fan in main oven boken
Sounds as if your oven heating element has failed. You need to fit a new one.
Usually you have to get the back off, disconnect the old element, remove the fixxing screws and element, fit new one, reconnect and it should be fixed. Don't forget to switch the power off before starting work.
Dec 31, 2009 | Zanussi Ovens
Main oven not heating.
You need to replace a faulty main oven element.
This is done by removing the rear cover in the main oven,
there you will see the element, disconnect and replace.
It is not a difficult job , and is not too expensive.
Plz frate my solution.
THANKS.
Jan 06, 2009 | Zanussi Ovens
Fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
Zanussi ZHQ575 Electric Double Oven Logo
354 people viewed this question
Top Zanussi Ovens Experts
ashburton
Charles T Nevin
Charles T Nevin
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
