Question about HP LaserJet 1320 Printer
MY PRINTER HP 1320 DOES NOT PICK PAPERS - HP LaserJet 1320 Printer
  • terryosaurus Jan 07, 2009
    My 1320 is used only occasionally, and tries-but-fails to pick up paper when it gets warm after extended use, but only if the tray is not nearly full.  My "solution": keep the tray nearly full.  however I will look into the "tire replacement" option from partsnow.com
  • 100 Answers
It most likely needs a new feed tire and seperation pad. You can buy at partsnow.com
For now do this, take a clean rag and dampen it with water or alchohol. Remove your paper tray, carefully hold it in the front middle under the pick up tire while also holding up the small black paper sensor. When you see a green light, press doen the top button 2 secs then down two more times. It should then try to print and this will cycle the print tire and you will be able to wipe the entire tire with your rag. Good Luck!
Posted on Jan 06, 2009
HOW DO I FIX THE MOTOR BEHIND WHICH ROTATE THE GEARS AND TO PICK PAPER
download the service manual.....
http://www.manualslib.com/manual/682599/Hp-Laserjet-1160.html#product-LaserJet 1320
Oct 24, 2015 | HP LaserJet 1320 Printer
Paper Feed problem
I think its logic board related problem.
have a technician look onto it...
Nov 08, 2013 | HP LaserJet 1320 Printer
Hp 1320 don't stop printing
my hp printer 1320 always prints two papers one of them is white.
what caused this problem?
Nov 02, 2012 | HP LaserJet 1320 Printer
Paper jam in hp laser 1320
Unplug the power cord and open the cover and remove toner and try to look I inside around the roller and try to manually roll the roller and if you can see the paper try to pull is slowly.
Have a nice day and do not forget to rate please...!
Feb 10, 2010 | HP LaserJet 1320 Printer
After 10 page printer not pick up
May you need to replace a pick up roller on your printer.
Oct 05, 2009 | HP LaserJet 1320 Printer
hi
your pickup roller infront just above the tray is broken and needs to be replaced. Rmove the tray and you will see it. It might have a crack in it on the side that inlocks with the arm that turns it. its common and breaks dew to wear and tear as nothing ever lasts forever. its easy to remove if  you take it out from the side that locks into the arm that turns it
Dec 19, 2008 | HP LaserJet 1320 Printer
My HP OJ 7310 all-in-one did not pick up papers.
the first ting I would do is clean the paper feed rollers with a cotton pad and alcohol. The rollers may have a build up of paper dust that are makind the rollers slip.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 27, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Printing problem
Amber/orange light blinking and not printing
Jul 07, 2008 | HP LaserJet 1320 Printer
Problem with HP 1320
Techguru, Tray 2 relay??
Where can that one be accessed from, is it an invasive procedure??
Feb 15, 2008 | HP LaserJet 1320 Printer
Laserjet 1320 will not pick paper
Paper misfeeds and failure to pickup the paper are both common symptoms of a worn pickup roller. This roller is on the bottom of the printer as shown in the attached picture.
With use the rubber tire gets smooth and can't grip the paper enough to pick it up and push it into the printer. The roller kit is easy to install yourself and will get the printer back going as good as new. You can get the roller kit here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_42&products_id=71
I hope this helps, if so please rate my solution.
BuddyMc
Dec 05, 2007 | HP LaserJet 1320 Printer
HP LaserJet 1320 Printer Logo
159 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
