Question about HP LaserJet 1320 Printer
DOES NOT PICK PAPERS. - HP LaserJet 1320 Printer
    Problem Solver:
  • 14 Answers
Hi
your pickup roller infront just above the tray is broken and needs to be replaced. Rmove the tray and you will see it. It might have a crack in it on the side that inlocks with the arm that turns it. its common and breaks dew to wear and tear as nothing ever lasts forever. its easy to remove if  you take it out from the side that locks into the arm that turns it
Posted on Jan 10, 2009
Ricoh ardf 3090 jamming
Check the papers.
Papers are good then clean the pick up rubbers with ethylated alcohol.
Apr 11, 2016 | Ricoh Aficio Office Equipment & Supplies
Hp laser jet 1200 printer,orange light stays on and it doesn't pick the papers from the tray paper..problem?
Here is a link to the HP tech support site for that model printer with the error lights and what they indicate and the solution to correct each warning light pattern. I hope this helps.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl10633
BuddyMc
Aug 23, 2012 | HP LaserJet 1200 Printer
HP LaserJet P2015 Printer Cannot pick papers
Your paper pick-up roller is possibly broken and needs to be replaced, ( common occurance),the shaft that turns your paper pick-up roller could also be broken, it is on the right side of the pick-up roller, but this is not as common.
Good luck
Feb 21, 2011 | HP LaserJet P2015 Printer
Laser printer manual feed jam
like the name goes, it is manual. You will have to feed the papers one after the other. if you do not want that, then load the papers into the automatic tray if you have one.
Incase none of the above works it means the roller that is suppose to pick the papers finds it hard to pass papers on to the other which you will have to replace.
good luck
Jul 04, 2010 | Samsung ML 1450 Laser Printer
Printer won't print with Hahnemuhle 300gsm papers.
Brand new printer feed up to 350 gsm paper. Rubber paper paper pick up deterioration. Replace paper feeder. Or find similar solution (repairing paper feeder) on aicaxz's for resolving this.
Feb 02, 2010 | Epson Stylus Photo R220 InkJet Printer
It does not pick up papers when trying to print
I have the same problem,only pick up some of the paper and then stop.
May 01, 2009 | HP Deskjet 460c InkJet Printer
Hp deskjet 9800 wont take paper
I think this could be solved by simply putting some more papers (at least more than 4 papers). if this doesn't work, check for any buttons on the sides od the printer... good luck
Jan 10, 2009 | HP DeskJet 9800 InkJet Printer
My HP OJ 7310 all-in-one did not pick up papers.
the first ting I would do is clean the paper feed rollers with a cotton pad and alcohol. The rollers may have a build up of paper dust that are makind the rollers slip.
Sep 27, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Could not pick up papers from paper tray.
1- either the tray is not lifting the paper to meet the rollers ( which may indicate a motor problem) or the rollers are not coming down to meet hte paper (clutch problem)
Aug 30, 2008 | Sharp AL 1631 Copier
HP LaserJet 1320 Printer Logo
95 people viewed this question
Ben Johnson
