Question about Zanussi FJS1225W Front Load Washer
Washing machine wont work
I've been switching my washing machine on and all I get is the sound of the motor trying to turn, no water coming into the machine and I keep getting the message of ERROR 10?
  • spock1 Apr 21, 2008
    The machine starts but stops before it starts to take in water, this happens intermitently.  No obvious patern or cause. I have tried turning off / on. cutting Power and re starting. Checked all filters. Checked door is always closed properly. Checked load is not too full. Any help really appreciated - Its driving me crazy....
There may not be any supply of wanter into the machine; check this by disconnecting the machine pipe and turning on/off the tap to see the water flow.
Posted on Apr 04, 2007
SOURCE:
My GE washing machine wont spin and no water
SOUNDS LIKE 2 DIFFERENT PROBLEMS HERE, THE SPIN IS DICTATED BY THE TRANNY AND CLUTCH, USUALLY A BAD CLUTCH WILL NOT ALLOW SPIN OR LEAVE WET CLOTHES, BUT IF U HAVE BELT DRIVE LOOK AT BELT, AND MOTOR COUPLER, WHEN U SAY NO WATER COING OUT? U MEAN AFTER WASHING? OR BEFORE WASH CYCLE? AFTER WASHING THEN MAY MEAN U HAVE BAD WATER PUMP OR CLOGED WATER PUMP? IF BEFORE WASHING, THEN LOOK AT UR WATER INLET VALVE AND UR WATER PRESSURE SWITCH WHICH DETERMINES WHEN MACHINE BEGANS WASH CYCLE AT LOW ,, MED OR HIGH LEVEL, U CAN CHECK THESE WITH A MULTIMETER OR TRY A VISUAL AND LOOK FOR OBSTRUCTIONS IN WATER LINES AND HOSES
Sep 14, 2014 | Washing Machines
1st start washing/wont wash but spin.
Sounds like that the washer motor may need to be replace
Check the washer interlock switch and the water pressure switch before thinking on the motor.
Jan 21, 2014 | Washing Machines
My frontload washing machine fills water but then it will not turn.
I would check the motor. Sound like it may be at fault.
Nov 04, 2012 | Washing Machines
My washing wont spin
this sounds like you need new brushes in the motor ok
Nov 02, 2012 | Hotpoint Aquarius Wma40 Washing Machine...
ERROR CODE E 60 washing machine zanussi ZWG1100M
This can be due to error in the control board. Shut down and remove plug and when switched on press down the start/stop button. If the error does not clear this can be a fault in the motor drive within the control panel board.
Remove the panel and check the connections to the motor, check the motor and the capacitor to the motor or if the motor is jammed.
Jul 03, 2012 | Zanussi Washing Machines
Washing machine wont begin a programme
Hi sam this might help if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
May 17, 2012 | Beko Washing Machines
F&P GW712 washing machine, the machine washes and when it gets to the spin part it wont spin, it tries to and then a continuous beeping sound and too lights long wash & short wash comes on until...
hello what might be happening when it's going through the cycle and come to the spin part there may be not enough water empting out from the pump causeing it not to spin also there may be a fault with the module board the control the motor speed also brushes on the motor can cause spin problems hope it
regards
shaun
May 01, 2011 | Washing Machines
MY WASHING MACHINE WONT START WASHING
Could be motor brushes or the motor....
Feb 09, 2010 | Washing Machines
Washing machine wont spin in spin cycle ,makes spinning sound just wont spin
It doesn't spin If your washer won't spin, check these: It doesn't pump or spin It pumps, but doesn't spin It spins only with the lid closed It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jan 01, 2010 | Washing Machines
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Zanussi FJS1225W Front Load Washer Logo
66 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
