Question about HP LaserJet 3030 All-In-One Printer
Cannot fax to an 0866 number
I cannot seem to send faxes to an 0866 nr, but then again to other 0866 or 0865 numbers it seems to work. Please help
  • 628 Answers
You mentioned one number. The problem doesn't seem to be with your machine. Some fax machines won't communicate with certain others. If your machine works all right with other fax machines, then most likely the one you're having trouble with won't talk. There's little you can do for that problem.
Posted on Feb 07, 2009
Lexmark X4270 won't send out a fax
If you have DSL. you need a filter on the line you are trying to fax through.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 24, 2012 | Lexmark X4270 All-In-One InkJet Printer
Fax will not send - I dial the number, the document scans but the number answers with a busy tone
Does your fax work to other numbers??? TRY IT.
aLSO WHAT YOU CAN DO IS CALL THE NUMBER THAT SEEMS TO BE BUSY FROM A "TELEPHONE" AND SEE IF YOU GET THE SAME "BUSY" RESULT.
Nov 10, 2010 | Samsung Office Equipment & Supplies
Unable to send fax
press *99 before the number it will work
Aug 09, 2009 | Brother FAX-575 Plain Paper Thermal
Cannot send faxes on my all in one hp office jet 5610
If the recipient side is ringing, then the problem is on their end. It sounds like the receiving fax is not set for auto-answering a fax call. A receiving fax machine should pick up and start to attempt the reception even if the fax number is dialed from a normal voice-only telephone; the receiving machine has no idea if the caller is a fax or a regular phone. It should pick up regardless and start to negiotiate the fax (that's the high-pitched whistling sound at the beginning of the call).
May 15, 2009 | HP Officejet 5610 All-In-One InkJet...
Hpofficejet: will not receive fax. Sender is given our phone number, our phone is answered and we dial our code -- this no longer works. Cannot find manual. Do we reset the number and how, or what...
I just got a new line just for my SF-5100 fax. It was working before I switched to this phone company. I checked the line on a regular phone and it seemed ok. When I plug it up to my fax machine, when it rings I get this static sound instead of rings. One of my customers said when she tried to fax something, she got that same static sound and it would not go through. When I tried to fax her something, I dialed the number and when the fax machine was repeating the numbers it was a series of that same static sound. Then the operator said I should try my call again - so it did not dial through. A few minutes ago, the screen said RX also. Can you please help?
Oct 07, 2008 | Samsung SF 5100 Laser Printer
Canon Faxphone L80 - Alan Silva
To send a fax you do not need to enter anything into your fax. You have to make sure that you connect the telephone line to it's desgnated connector. You dial a number to send as if you are calling form a normal phone. If you ever get a ringing tone press start. You can enter any data trough the data registration after you make sure your fax is functioning properly.
Jun 24, 2008 | Canon FAXPHONE L80 Laser
Can receive, can't send
I spoke to someone at Brother. She told me to "massage the keys in a circular motion". Feeling very foolish I did this. Sure enough when I got to the number "7" it was stuck. The massaging released the key and my fax was working again.
Mar 31, 2008 | Brother IntelliFAX 2800 Laser Fax
When faxing, what is Error 387? Can fax other places, why not this place?
Specifically, error code 387 on that machine is : Try to send the fax at a different time when telephone line conditions have improved. There is nothing wrong with your machine that I can tell from your description. It sounds like it is trying to handshake, fax term for connect, but does not complete. I had the same thing happen to me yesterday with some very important papers. I even called the person at the other end and they said they had been receiving faxes ok. Took me 4 tries but finally went through. It's just the phone lines. Keep trying. It can take several tries. If this helped please rate a big 4 fix ya. If you can't get through no matter how many times you try just post a comment and I'll be happy to come back and help you out.
Mar 25, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
Can't send out fax
the number you called does not answer or busy-you may have reached a number not connected to fax or it is connected and not activated in receiving mode-check the number and call again.
if you have a message "out of memory"there is no enough memory available to send your fax.press stop/exit print the faxes stored in the memory to delete them then try again.
Mar 18, 2008 | Brother IntelliFAX 885MC Plain Paper...
Epson ACULASER CX11NF incoming fax problem
Try this:
Unplug line from back of printer
Set the Incoming mode to autoswitching
set DRPD to Off so that it will recognize all incoming calls
** if possible call your telephone company and set a distinctive ring pattern for phone calls
replug cable on line port at the back of printer
then ask someone to send you a fax...
Feb 05, 2008 | Epson ACULASER CX11NF All-In-One Printer
HP LaserJet 3030 All-In-One Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
