Mannual where i can find the cdi box?
SOURCE: 83 yamaha tt600e no spark
The CDI unit on the 83 model (TT600) is located under the fuel tank and suffers from heat
exposure.The solution is to get specialist help to open up the sealed CDI unit and repair/
replace internal connections (which are readily available electronic components)
When you re-install it put some heat shielding material there to protect it and this
will be OK as repair will utilise stronger parts,I think.
Later models have the CDI unit moved to the head-stem area.
(this info from a Non-mechanic who remembers what was done to his TT in Australia, many years
ago)
SOURCE: Lifting up the seat on a 1999 Yamaha Zeal.
There should be a release on the side of the seat. It may require a key to unlock it.
A service manual is a valuable tool with an aging bike. I suggest the
dealer/mfr. or Clymer books. In the meantime, go to the library
reference section...646 stacks should have what you need.
SOURCE: Where can I fine the chassis number Yamaha zeal
try on the frame area under seat. let me know if this helped. thanks mike
