Question about Lexmark E232 Laser Printer
Printer jam The printer picks up the paper and then it stops putting the paper through to print. We have used the orange lever on the left side and this works sometimes. What might the repair be for this?
There is an easy fix for Lexmark E232 paper jams at the beginning of the paper path. This fix only works when the problem is that the paper starts to feed, but does not quite make it out of the paper tray.
The problem is the pickup paper rollers. If you remove the paper tray and press down on the paper indicator (the red lever to the left of the paper tray) you can see the twin rollers attached to a spring loaded armature.
Chances are these rollers are worn and are very smooth to the touch. This slick smooth surface does not have enough friction to push the paper up to the next roller.
To fix this, remove both rollers, they slide off easily. Then simply turn both rollers inside out and replace them on the armature. Notice how much "stickier" they feel now? Chances are your paper jam problems are over, until the rollers wear out again.
At that point you will have to replace them.
Posted on Nov 17, 2007
    Problem Solver:
  • 7 Answers
When you experience a paper jam on the Lexmark model E232, it is recommended that you check and clear the entire paper path. To clear a paper jam, do the following: 1) If you are feeding paper from a paper tray, first remove the tray. Look for and remove, any jammed or damaged paper you find. 2) Open the front cover, and remove the print cartridge assembly. IMPORTANT! Do NOT leave the print cartridge assembly EXPOSED to direct light, especially sunlight, for an extended period of time. Put it inside a dark place, like a box or a green plastic garbage bag. 3) Remove any paper you find jammed in the area behind the print cartridge assembly. 4) Also lift the flap at the front of the printer and remove any paper you find jammed beneath the flap. 5) Open the rear exit door/cover of the printer and remove any jammed paper you find there. 6) Once you have confirmed that the entire paper path is clear, reinstall the print cartridge assembly. Close all the printer covers/doors. Reinstall any paper trays you removed. 7) Press the Continue button to resume printing. NOTE: The printer may reprint the page that caused the paper jam. 8) If the paper continues to jam, press the Continue button twice quickly while the Continue and Paper Jam lights are on. This will cause the operator panel to display the secondary error paper jam light sequence. The secondary error code will tell you where the printer thinks the problem has arisen. For information on this code, consult the section of your user guide entitled, "Secondary Error Codes." If you do not have a printed user guide, look for the user guide on the CD that came with your printer.
Posted on Mar 30, 2007
I have paper in the printer C3180 there is no paper jam but it reads no paper and will not print
Hi
Well maybe you are able to hear a sound like the rollers are turning to pick the paper? this is usually associated with the disc encoder on the left side of the print mech. You also need to to open the printer and inspect if the carriage is getting locked on the right side of the printer to initiate the paper pick-up process. If the carriage is not getting lock on the small lever near the service station then the lever needs to be replaced as this is the main part responsible.
It looks like this and on the left side of the picture you can see the lever normally gets broken.
Jul 19, 2011 | HP Photosmart C3180 All-In-One InkJet...
How do I remove a paper jam? The paper is
The following is general advice that applies to removing paper jams in most printers, copiers, etc.
Switch off the printer at the wall and unplug it. Remove the paper tray from the printer. Check to see if the printer has an access door in the rear to allow you to see inside (open it). Open any other external flaps (eg. manual paper feed tray) that will allow you to see inside. Open any internal flaps or levers designed for user operation and usually indicated with a green or orange coloured tab.
Always remove jammed paper by pulling it in the direction of normal travel only. Don't try to pull it out against the direction that it entered the printer. Sometimes rollers inside the machine have a knob (usually coloured green or orange) that can be used to manually wind the page through the printer or fax. Always turn in direction of arrow indicated only.
After removing page, return all levers, flaps, doors, paper trays etc to original positions, reconnect power to the printer and test
Feb 04, 2010 | Brother IntelliFAX 4100 Laser Fax
My Brother HL 5250DN printer has started making a loud clicking sound when it tries to feed paper for printing. It then stops and the paper light starts flashing.
Clear the jammed paper as follows.
Observe Cautions signs in printer.
Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and prevents paper jams.
1. Press the cover release button and then open the front cover.
2. Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
3. Pull the paper tray completely out of the printer.
4. Close the front cover.
5. Pull the jammed paper up and out of the printer.
6. Open the front cover again.
7. Open the back cover.
8. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
9. Using both hands, gently pull the jammed paper out of the fuser unit.
10. Close the back cover.
11. Pull the duplex tray completely out of the printer.
12. Pull the the jammed paper out of the printer or the duplex tray. Put the duplex tray back in the printer.
13. Push down the blue lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
14. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
15. Put the drum unit and toner cartridge assembly back in the printer.
16. Put the paper tray firmly back in the printer.
17. Close the front cover.
18. Make sure that the Paper LED is now off and the printer is ready.
After clearing paper jam if noise persist printer may need a Repair Tech and parts replacement for broken or wore parts.
Dec 04, 2009 | Brother Office Equipment & Supplies
HP 6540 Lights flashing can't print
This indicates a paper jam or the printer is out of paper. Do not clear a paper jam from the front of the printer.
The printer might be out of paper
1. Place paper in the In tray.
2. Press the Resume button on the front of the printer.
There might be a paper jam
1. Press the Resume button. If the paper jam does not clear, then go to the next step.
2. Push the two latch handles on the rear access door toward each other, and then remove the door.
3. Remove any paper that is inside the printer by pulling it out from the back of the printer. If you are printing labels, verify that a label did not become detached from the label sheet while passing through the printer.
4. Replace the rear access door.
5. Press the Resume button.
If the Two-Sided Printing Accessory is attached to the printer, follow these steps to clear a paper jam from the Two-Sided Printing Accessory.
1. Turn off the printer.
2. Press the buttons on the left and right sides of the duplexer, and then remove it from the printer.
3. Remove any paper inside the printer.
4. Open the duplexer.
5. Remove any paper from inside the duplexer.
6. Close the duplexer, and then re-attach the duplexer to the printer.
If the Auto Two-Sided Print Accessory with Small Paper Tray is attached to the printer, follow these steps to clear a paper jam
2. Press the buttons on the left and right sides of the accessory, and then remove it from the printer.
3. Remove any paper that is inside the printer.
4. Lift the back lever on the accessory, and then unhook the Small Paper Tray
5. Tilt the Small Paper Tray forward and open the lower door of the accessory.
1. Tilt the Small Paper Tray
2. Open the lower door
6. Remove any paper that is inside the accessory.
7. Close the accessory, and then secure the back lever to close the accessory.
8. Re-attach the accessory to the printer.
Oct 03, 2009 | HP DeskJet 6540 InkJet Printer
The icon with the exclamation in the middle is flashing, and
Put your mouse pointer on the Icon, the with your middle finger only, press down on the right side of the mouse. This will bring up a menu on the Icon.
Dec 27, 2008 | HP LaserJet 1320 Printer
Grinding Sound - Orange Paper Jam Light
You have a broken gear main motor. I had the same problem, bought $5 part and after the replacement of the gear,it runs like new
Dec 04, 2008 | HP LaserJet 4L Printer
Paper jam problem in pixma mp145. E3 error.
I have trying resseting and the error message does not clear. I have checked the printer througly and there is no paper jam.
Nov 25, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Printer says it has a paper jam even after it has been cleared
The screeching sound is caused when the print head reaches the end of its travel and hits the paper jam which you cannot see using the suggested jam-clearing steps. So
1. unplug the printer
2. lift the cover so the blue support on the left holds the cover up
3. plug in the printer, watch the printer head move
4. after it stops, gently move the printer head toward the middle and look at the far ends of travel. you should find the cause(s) of the jam up against the sides of the printer. remove with needle-nose pliers.
5. replace cover, plug in the machine. it will go through a cleaning or 2, but it should be ready to go after that
Nov 23, 2008 | Brother Multi-Function Center MFC-240C...
PAPER JAM
The problem sounds like your rollers have lost their grip. Remove the paper tray and tip the printer up. Push the red lever on the left of the printer down and you will see the feed mechanism with two wheels. Remove the rubbers on the wheels and turn them inside out. Replace them on the wheels with the worn side now inside and the 'sticky" side out. You should get at least another couple of years worth of use before you need to replace them.
Aug 22, 2008 | Lexmark E232 Laser Printer
Printer ripair
The BJC 3000 will flash two different colored lights in a pattern to signal several different errors. From the documentation I have the two colors are orange and green, could those be the colors you see? At any rate here is the code: Two orange flashes: Out of paper, paper jam, or paper feed error. If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing. Three orange flashes: Paper jam. If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing. Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink. Replace the empty BJ tank and press the Resume button to continue printing. Five orange flashes: BJ cartridge is not installed properly. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely. Six orange flashes: BJ cartridge (printhead) is not installed. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely. Seven orange flashes: BJ cartridge (printhead) is defective. Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge. Eight orange flashes: Waste ink absorber almost full. The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing. The POWER light flashes orange and green alternately: Service error. A service error means the printer requires the attention of a qualified technician. If you have any more questions let us know otherwise please don't forget to rate this post.
Feb 20, 2007 | Canon BJC 3000 InkJet Printer
Lexmark E232 Laser Printer Logo
3,081 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
