Question about Linksys EtherFast 10/100 16-Port Workgroup Switch [ EZXS16W ] (104834)
I cant login to the motorola login screen?
I have tried every username and password i could get. and none of them worked.
  • madarjeff Dec 19, 2008
    Well when ever i put my gateway address in the url bar it goes to a motorola login page. and if its the linksys then i cant find the reset button if its the motorola i found it and tryed reseting it
  • Questman
    Questman May 11, 2010
    Are you trying to log on to the Linksys Router or your Motorola Modem? If you are trying to log in to the Linksys, you can try Admin as the username and Admin as the password. If that doesn't work, you can reset the router by taking a paperclip and inserting it into the small hole in back and holding it in for 60 seconds. Once done the router will reset back to factory defaults where you can reconfigure your router. Let me know if this is what you are trying to do, or if it's the modem. Good Luck....
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
For Linksys routers there is no username only the password which is admin.
Posted on Jan 09, 2009
My motorola router (SGB941) will not show up on wireless. Already reset in the back. Any ideas?
Make a wired connection to the router. Open a Web browser. Type in the Web address 192.168.0.1. You should get a login screen. If you don't know the username and password, try "admin" for username and "motorola" for password (without the quotes).
Once you've logged in, navigate to the Wireless Primary Network page and make sure "Primary Network" is Enabled and "Closed Network" is disabled.
Manual:
http://setuprouter.com/router/motorola/sbg941/manual-398.pdf
May 21, 2016 | Motorola Computers & Internet
Couldn't log in. would't take pssword. Changed password still wouldn't take password
the default login information is Username: admin Password: motorola... when changiong the password it is best not to use characters ie. !@#$%^ etc, and no numbers and keep the password 4 to 8 letters long and always sve/apply changes... if none of these work, and you still can not access the user interface i suggest factory resetting it, but unless you are checking your signal levels or making sure you have a WAN address i really don't see a need to accessing the user interface of this modem as it has no firewall, wireless settings or anything else worth trying to change
Aug 18, 2013 | Arris SURFboard SB5120 Modem
How do I find my wep key? I cant remember it and cant get online wireless with out. I did go to http://192.168.0.1/login.asp but I cant seem to log in there. Please help.
Try to access 192.168.0.1 once again. Try to use "admin" for the username and "motorola" for the password. If "motorola" doesn't work, try "password".
Sep 03, 2011 | Arris SURFboard SBG900 Wireless Router...
Cant login to my motorola sbg900 wireless router. i know my username and password and it will not work. I've tried resetting it by holding the button down in the back, but that won't work either. i...
By holding down the button in the back, you may have reset it to factory defaults for the password and username. Try using Admin for the user name and motorola for the password.
Jul 28, 2011 | Arris SURFboard SBG900 Wireless Router...
Well,when i type in the adress bar 192.168.1.1 it ask the login and the password but i dont know the login or password my cable modem is a motorola sb5101i SURFboard Thanks
HI i beleive you are looking for a user name and password for the motorola sb5101i
here are the username and password for the modem which are default
USER NAME:-ADMIN
PASSWORD:-leave it blank>>press login(this should work)
DEFAULT IP FOR YOUR MODEM:-192.168.100.1
IF THIS doesnt work try to turn off the modem and turn it on back...this might work
or else you can try to reset the modem,once this is done you might have to reconfigure the modem...contact your internet service provider to set it up
Apr 25, 2011 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
I cant log in with my username and password
Reset the router to factory defaults by putting in a push-in in the small hold at the back of the router. You should then be able to login using the default password. Default password should be in the user manual.
Dec 05, 2009 | Arris SURFboard SBG900 Wireless Router...
Login for ip address 192.168.1.1
the usual username and password for this ip address is :-
username:- admin
password:- admin
let me know if that helpes
Jan 11, 2009 | Arris SURFboard SB5120 Modem
Cant login to router
When in doubt double check your work. You held the reset button down on the back of the router for long enough for the lights to go out then start blinking again? Then you went to 192.168.100.1 in your browser and tried admin for your login name and motorola for your password? If you did all of that and it's still won't accept your login try to power the router off for at least a minute by pulling the power cord and make sure you clear your browser cache before trying to access the default gateway address in your browser again.
Hope that helps!
Jill
Nov 30, 2008 | Arris SURFboard SBG900 (49402201900) Modem
I cant login into windows xp helppppppppppppppppppp
at the login screen of windows xp press ctrl+alt+del button twice it will take show username and password in black colour screen where type the username as administrator and press enter then u can login as administrator after logging in go to control panel in that user accouunts select u user name account and double click on it and remove the password and restart the machine it will automatically moves to u r normal settings
Aug 01, 2008 | Microsoft Windows XP Professional With...
I cant figure out my password
You can reset the router, There is a reset button when you press and hold it will change the settings to factory default, so you can use default password.
Good Luck
Jun 20, 2008 | Arris Wireless G Broadband Router (wr850g)
Linksys EtherFast 10/100 16-Port Workgroup Switch [ EZXS16W ] (104834) Logo
1,143 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
