Question about Fisher and Paykel DEGX1 Electric Dryer
Fisher & Paykel ED56 random stops + wont work upside down
Hi all
I have an ED56 that works most of the time when sitting on level ground, the right way up. However, more frequently it just stops and flashes the "start / pause" light. Clothes are far from dry.
Purchased mounting brackets and installed upside down onto wall. The machine is plumb in both directions and now it just wont start. Flashes the start / pause at me, wont go at all, or occasional will do half a revolution if I keep pressing the start button.
Any ideas?
Thanks
  • zakwilliams2 Dec 19, 2008
    Reply to myself here....after more investigation it is the door sensor...not sure how it works, but basically if you apply pressure to the door it will work fine. Let it go and the door gradually moves out like 1 - 2mm and it cuts out. Presently wedged a stick of 4x2 between a door and the door...goes great.
    How do i fix this please?
    Thank you.
  • 351 Answers
SOURCE: How to install capacitor to
if the cap has two terminals it doesnt matter where you put the wires
Posted on Aug 28, 2008
SOURCE: Fisher & Paykel ED56 Dryer alarm on. Nothing else works
Replaced electric control panel. Looks like power spike fried the works
Posted on Mar 02, 2009
TheMobilian
  • 8220 Answers
SOURCE: Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
Posted on Sep 08, 2009
SOURCE: Fisher & Paykel ED56 not working
Replace (repair) the exhaust sensor this looks like a transistor with the middle leg cut off. it is situated below the lint filter but can only accessed by removing the back panel, top panel (or rear screws to allow the removal of the drum). drum and then front panel to remove the connector from the mainboard. If you follow the exhaust tube once the back is off you will see a single phillips head screw that is the sensor. check the wires to the circuit board are not broken or dry joints or just replace it. sorry i had a spare machine i scavenged from to fix my problem so i dont know where to buy new.
Posted on Apr 09, 2010
SOURCE: Dryer Problem
Grinding noise most likely due to the front drum bearings worn out - result is the metal drum making contact with the rim of the from panel.
This requires a total disassembly of the dryer to investigate & likely replacement of the front slipper pads (dry nylon slipper bearings 4 x ).
This will only be a succesful repair if you stopped using the dryer the moment it started screeching.
If you have let it run, the metal-on-metal will have gouged the edge of the drum and will rip up any new replacement bearing pads.
Do not attempt this unless you are a very competent handyperson. Many screws lost, cut fingers and swear words will ensure if you are not confident in approaching this job, so either toss the dryer or get a competent repairman to do the job.
Posted on Apr 19, 2010
Fisher and Paykel ED56 start/pause button keeps blinking.. wonts start
Possibly the door switch is playing up, this model can be susceptible to the door slightly bending and not contacting the switch every time. give a gentle press at the top of the door to see if you can hear the door switch mechanism working.
Sep 04, 2017 | Fisher and Paykel Washing Machines
Fisher and Paykel ED56 dryer won't run.
Glad to got it taken care of. Next time be a little more careful, I usually recommend using a leaf blower.
May 10, 2015 | Fisher and Paykel Dryers
F&P ED56 has 2 problems
Yes, (2) certainly sounds like the start/run capacitor has failed. You will see it has a split or bulging case, or a displaced end cap. Replace it with one of the same voltage rating and capacitance.
I can't advise you on (1)
Jun 20, 2013 | Fisher and Paykel Dryers
Fisher ED56 dryer wont turn off!
HI, this will occur if the timer control module or control board has failed. replacing the timer or control will fix this issue.
thank you,
vijay (vote for me)
Sep 24, 2009 | Fisher and Paykel Dryers
Diagnostic Mode
button.
Last Fault
The manual is here
Sep 08, 2009 | Dryers
My fisher and paykel dryer ( mod# ED56 ) wont start, power is on
I had this same problem with my Dryer. It is making the few quick beeps because it thinks the door is still open. Near the bottom of the opening to the dryer there is a sensor switch that gets pushed in when you shut the door. Try holding the switch in with a knife or something and then start the dryer with the door open to check if that is the problem.
After i did this, i closed the door and my dryer started as normal.
Aug 11, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Feb 27, 2009 | Fisher and Paykel DEGX1 Electric Dryer
F&P ED56
see if the jockey arms are hitting the drum or the capacitor is losse (if the dryer is upside down).hope this helps
Oct 20, 2007 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
123 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
