My PC restarted automatically with a DOS massege
Sir mu PC with Intel 945gccr is restarted automatically with a DOS message is that
"Dump of Physical memory"
second problem is it automatic disconnect USB device after connecting USB device and show message on window
is that
"USB not recognize"
Chk m/b & smps
Posted on Dec 19, 2008
My gateway logo comes on but then it says its preparing automatic repair and nothing else will happen what can i do now
My first thought would be Hard Drive corruption. Either due to a physical failure or a problem with your operating system. Download Seatools for Dos, burn it to a CD, restart your Gateway from the CD, run the Seatools program and check your Hard Drive for errors.
May 28, 2014 | Gateway Ne56r31u Intel Celeron B830 X2...
I am getting an error everytime after 5 minutes, w...
Could you please provide me the exact error message?
However to stop the system shutdown first follow these steps.
Disable automatic system restart.
1. Restart the computer and press the f8 key to open the Advanced Boot Options menu.
2. Select the Disable automatic restart on system failure option.
3. Restart the computer to accept this change.
Then go to safe mode
This problem occurs after a memory dump file (error log file) is written by Windows XP. Because the memory dump file flag not reset in Windows XP the memory dump file will contiue to be written every time Windows is restarted.
1. Restart the computer and immediately press f8 repeatedly. Use the arrow keys to select Safe Mode and then press enter .
2. Click Start , right-click Computer , and then select Properties .
3. Click Advanced system settings , grant permission to continue if prompted, and then click the Advanced tab.
4. On the Advanced tab, click Settings
  1. In the Virtual Memory section, click Change .
  2. For Paging file size for selected drive, click No Paging File , and then click Set .
  3. Click Yes after the following warning appears:
If the paging file on volume X: has an initial size of less than xx megabytes, then the system may not be able to create a debugging information file if a STOP error occurs. Continue anyway?
(X is the drive letter and xx is the amount of RAM installed on your computer minus 1 megabyte.)
  1. Click System Managed Size .
  2. Click OK four times to return to the Windows Desktop Screen and then restart.
For more information plz check the below doc from HP.
I hope this will definitely resolve your issue.
If not plz get back with the exact error message so I can give you better solution on this.
If you find this helpful then Plz vote for me..Dreamkam
May 21, 2010 | HP Pavilion dv6000z Notebook
How do i fix a computer problem i get a message
this massege ocurs when the you computer windows or say OS gets corrupeted and unable to use the system32 file and exe.. and so to resolve the problem you are requrided to reinstall you windows because recovering it would work but will damage harddisk. thank you
Nov 06, 2009 | Computers & Internet
How many GB hdd does intel 945GCCR support
Depends on how your formatting this sir.. The bios first would need to support large drive or LBA mode if it does you need to format this using NTFS file system or FAT 32...
Oct 03, 2009 | Intel D945GCCR Motherboard
Memory dump
There are essentially two major causes of the physical memory dump screen: Running way to many programs at once, errors in the Windows registry.The first cause can be fixed rather easily. Simply run fewer programs or purchase additional RAM or processor upgrades. Your computer is running past its specified limits. But keep in mind the blue screen of
death should happen very infrequently. If you see the physical memory dump blue screen more often then the problem is errors in the Windows registry.This is a more abit of a harder problem to deal with. The registry is the most important component of your computer. The registry contains settings and information to run all software and hardware on the computers. When there are errors in the registry it disrupts the computers ability to communicate. When the system cannot compute, it freezes up and displays the Windows blue screen.
I found a registry cleaner that is free and works rather well. It is named cCleaner, has been around for some time and did I mention FREE...Download it from thelink below run it should clean up your registry...where good men fear to tread.
good luck, please leave a rating...thank you
May 04, 2009 | Intel Computers & Internet
Error message: Physical memory dump
The error code is pretty general and could indicate a few problems. You can try the solutions posted here: .
Mar 21, 2009 | Acer Extensa 4620 Notebook
Automatically restarted problem with mother board
enter the bios and enable the usb funtion memory dump is usally caused by bad data or memory sticks have you upgraded the ram if so check the speed match it as close as possible
Dec 19, 2008 | Computers & Internet
Window programme got currupt
try to reformat ur hard drive and install a new os (windows)
May 27, 2008 | Intel Motherboard
Intel 945GCCR mother board network drivers problem
hi dear .
when start up the computer automaic run bios , when i exit it display this masseg :
reinstall jumber in normal mode .
and the jumber is in normal mode already .
thanks .
Jan 29, 2008 | Computers & Internet
Computers & Internet Logo
355 people viewed this question
David Payne
David Payne
