I have a ViewSonic flat screen monitor. The images on the sign in page are fuzzy and unreadable. I have Windows XP.
    Problem Solver:
  • 6 Answers
I would check the connections between the monitor and computer. Also the refresh rate and/or resolution might be wrong. To correct this, you will need to boot your computer in safe mode. (restart computer, right after the computer's logo appears rapidly press the F8 key until a black and white menu appears. Select SAFE MODE) once the computer boots to safe mode, the sign on screen will appear very large. Sign onto the computer once at the desktop, RIGHT CLICK the background and select PROPERTIES. Once the display properties window appears click on the last tab SETTINGS. Here is where you can adjust the resolution. Take the screen resoltution to a low setting. You can always change this later when you boot your computer normally to get a better view. Next click on the ADVANCED button click on the MONITOR tab, usually flat screens operate at a lower refresh rate then CRT monitors. I usually keep my refresh rate to 60 Hertz. Next click on the GENERAL tab. This will allow you to change the DPI setting. I usually keep mine set to 96 DPI. You may want to experiment with this as monitors vary. Once done, click on the APPLY button then OK. Restart the comptuer and see if this has improved your display. You may need to do this several times trying different settings until you get a clear display. If you've exhausted all these steps, try a different monitor or changing the cable. If that fixes the problem then you know you have a bad monitor or cable. Good luck, let me know how it turns out.
Posted on Dec 19, 2008
Every time I sign on I get a pop-up saying Input signal is wrong & I need to set it to 1600x900 60h
The operating system is detecting that the video resolution is incorrect for the monitor attached to the device. It is recommending that you change it to 1600x900 at 60Hz. This may not be what you want. As long as the resolution and refresh rate are within the limits of the monitor, you can set it at any value that you wish. Of course, anything less than optimal may degrade picture quality and can cause distorted images. If you have the correct settings, then what may be the problem is that your OS may not be seeing the correct monitor or you may have a corrupted video driver. To change the resolution and refresh rate in Windows XP is easy. Anywhere on the background of the desktop, simply right click. Select the "properties" option. On the Display Properties window, select the "Settings" tab. Then click the "Advanced" button in the lower right corner of the settings page. Next select the "adapter" tab. O the next page, click the "List all Modes" button near the bottom. Scroll down the list to select 1600x900, True Color (32 bit), 60 Hertz, then click OK. When that page closes, click APPLY on the Adapter page. The screen will update. If the screen goes blank or unreadable, don't worry, there is a 15-second time-out and the previous resolution will return. If the screen updates correctly and you are satisfied with the results, click the Yes button on the popup before the selection times out.
Oct 26, 2015 | Microsoft Windows XP Home Edition
I run on Windows XP, pack3 and I use a CRT ViewSonic EF70 ... 17 inches The screen is not filled completely with the image from Microsoft Internet Explorer, nor with Outlook Express .... there is about 3...
two things you can do, first right click on your windows screen and look for "settings" this will open a dialog box where you can set the screen resolution. Set it lower and see if your screen is now filled. if that doesn't work go into the monitor setup (buttons on the bottom or side of the monitor) and try to set the verticle and horizontal size, since its only 3/4 of an inch you should be able to stretch the screen to fill up the space.
Mar 11, 2011 | ViewSonic E70f 17" CRT Monitor
Have just hooked up my Viewsonic VA720 moniter as the main moniter to a new laptop that I have. The laptop is an ACER Travelmate 6293 running windows XP. When I come to start up my computer each morning...
You most likely have a capacitor that has changed value. When a capacitor goes bad it will work after it heats up. Sometimes a bad cap will have a bulging top or show signs of leakage. Sometimes can only be checked with a meter.
Oct 04, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Out of range
Your windows video settings are for a monitor that has more capability (eg more pixels/finer resolution, higher refresh rate, more colour bits than the current screen can handle so it's spit the dummy.
Run your computer in safe mode (I believe that uses basic video driver) and set the video display options to a very low level, then re-start your computer again in normal mode, and set the options to the native resolution, refresh rate etc of the monitor. These should be listed in the specs that would come in the box with it (may be resolution: 1,680x1,050)
Sep 13, 2009 | ViewSonic VX2235wm LCD Monitor
ViewSonic 19" flat screen monitor goes black - intermittently
There could be a problem with your display card settings or the display card itself. If you are using Windows operating system, make sure that you have the monitor driver installed for that specific monitor. This is to ensure that Windows only allows settings for which your particular monitor was designed.
Let me know if I can assist you any further regarding this.
Best wishes,
Jun 12, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Dark unreadable screen
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out for parts, repair service and DIY info.
Mar 13, 2009 | HP Pavilion dv6000z Notebook
Dark screen
reset your monitor settings with deafaults with menu.u see some buton on lcd or monitor.
Dec 29, 2008 | ViewSonic VG900 19" Flat Panel LCD Monitor
View sonic flat screen monitor trouble
I have a Viewsonic Flat Screen - recently I turn it on and all I see is like tye dye colors across the monitor with a slight ghost images of windows trying to boot-up. What can I do to fix this. The monitor is about 1 1/2 year old.
Sep 08, 2008 | Computers & Internet
Hi, Using the OSD, select the Auto image adjust.
Sep 15, 2007 | ViewSonic VA703B LCD Monitor
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
