Question about HP Pavilion dv2000t Notebook
I have an hp pavilion dv2000 writed infront of the screen but in bios show dv2500 and i want to downgrade it to windows xp but if i install a windows xp it gives me a massege which says the hard disk is no detected and after that i installed windows xp alien spirit it now installed but the sound card bluetooth figer print touch pad and some other drivers which is shows system base devices like these if u can help me so plz show me the way
Os problem
hi..yea but download 1st all drivers support for what kind OS/Windows are your using..good luck and have a nice day
Jun 25, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
Sound problem in hp pavilion dv2000 with window xp
well u need to tell me which series of pavilion dv2000 Note it's located on the label as in this example: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us
Jun 06, 2009 | HP Pavilion dv2000t Notebook
Reformatting an HP Pavilion DV2000
when you put in the windows installation disc and restart your computer you will get a screen where you have the option to delete and reformat any existing disc partitions, choose delete current partition and reformat in NTFS and then you can install windows on newly formatted drive
May 10, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
I have a hp pavilion dv2000 machine currently it is loaded with windows 6.0 OS now i want to install ubuntu but i am not able to enter into bios mode to change the boot drive.
To enter setup, you usually have to press a specific key as the computer boot, on the initial POST screen. Common keys are Del, F2, F10, F12.
May 02, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
XP on HP Pavilion dv2000
i think you have a sata hard disk drive.so go to cmos setup and in the cmos setup and please disable the sata drive there
Jan 04, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
For the laptop with no hard drive detected, this is most likely because Windows XP does not recognize SATA drives by default, which the laptop most likely has. To solve this, you will need to enter the BIOS setup utility (most likely Delete or F1 on startup). From there, you will need to change the drive mode to Compatibility mode. I'm not sure where this would be, but if you check in your laptop manual, you can probably find this somewhere.
For the 2519TU, download and install this for the LAN driver: ftp://ftp.hp.com/pub/softpaq/sp30001-30500/sp30264.exe it should work just fine.
Dec 23, 2008 | HP Pavilion dv9000z Notebook
Problem on loadind windows xp on hp pavilion dv2000 laptop
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Nov 29, 2008 | HP Pavilion dv2000t Notebook
Bios password dv2000
fffffffffffffffffb fffffffffffff
Oct 13, 2008 | HP Pavilion dv2000t Notebook
Installing win xp in hp pavilion dv2000
OK...
F10 to enter setup,
system configuration,
and disable SATA native
Aug 02, 2008 | Computers & Internet
How to install Widnows xp on HP Pavilion dv2000
Please help me, I bought a HP Pavillion dv2000 Laptop which came with a built-in Windows Vista. Thats cool, but the problem arises when I try to install windows XP. After inserting the Windows XP SP2 CD and after primary driver loading it is unable to detect my harddisk
May 07, 2008 | Computers & Internet
HP Pavilion dv2000t Notebook Logo
112 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
