Question about Canon CanoScan 3000F Flatbed Scanner
Only works on negatives - can no longer scan photographs
I had to re-install Windows XP (done lots of times) and for some reason can't get the scanner to work properly. I have finally got it to work on negatives, but when I try to scan photos, i get a mainly blue screen with red, black and yellow lines at random points. I am assuming the bit that scans photos is in the base of the scanner (the negatives use the top) so can my problem be with the base? I did put a thick document in there to test it initially, could this have caused my problem? Any help greatly appreciated.
eagle338
  • 4889 Answers
SOURCE: scanner started scanning color photographs in black and white
The problem is simple.Someone or somehow the "TYPE OF ORIGINAL" option on ur SCANGEAR CS window.Set it back to "MAGAZINE" or "PHOTO" and it should scan in color.
Posted on Oct 08, 2007
jackboy
  • 2985 Answers
SOURCE: Scanning negatives on CanoScan 600F, I get an error message "Cannot write or read. 252.0.0"
The Canon support site is the place to go for that if your Manual does not tell you.
However remove the software and reload it - it may be as simple as that.
Posted on Dec 26, 2007
mohanchennai
  • 490 Answers
SOURCE: Grayblue Background on scans
A color scan will give real output as it is. If the background is grey, the output will also be grey. If you select 256 Color output, there may be small change in color, as compared to the original. If you select grey output, all colors will be converted to Grey. If these files are converted to PDF, it will be same, except in ODF format.
If you select B&W you can save the file in TIFF format. Unlike grey or color, each pixel can be either black or white only. To scan in black and white you must select right brightness. By doing os you can eliminate background (technically noise) and capture foreground(data)
S. Mohan
Posted on Mar 18, 2008
old marine
  • 2217 Answers
SOURCE: colour change
In the Advanced tab for the scanner software, there is a tab labeled Color/Colour. On this tab, select the "Reset" button. This should return all color adjustment options to their default setting. If this does not resolve the issue, you may want to try reinstalling the software, but there is also a possibility that the unit itself has some problems.
Posted on Apr 21, 2008
SOURCE: The documents are scanned but dont appear on later inspection, or if they do they are just a horizontal line across the middle
Try the version that came with the scanner Mine Was 3.0.1250.336 and is more stable than the new one.
Posted on Feb 06, 2009
My Canoscan lide 700f will no longer scan negatives
Hello try to reinstall the software for the scanner from here:
http://www.usa.canon.com/cusa/consumer/products/scanners/film_negative_scanners/canoscan_lide_700f#DriversAndSoftware
Please select your windows system 32 or 64 bit.
Download the driver and uninstall the old software before you install the new.
Canon does make an driver upgrade once a while to fix previous problems with the software.
Hope this will help you
Dec 18, 2012 | Canon CanoScan LiDE 700F
Driver for Windows 7 and HP Scanjet 4470c
Hi ,
There are no drivers running under Windows Seven for this unit.
If you have the W XP install disc , you could install a virtual version of W XP on your HDD ( http://downloads.vmware.com/d/info/desktop_downloads/vmware_player/3_0 )
You could also partition your HDD (
http://www.partitionwizard.com/free-partition-manager.html ) and install W XP on the new one .
BUT :
Here is a workaround :
Make sure driver XP ( yes , XP ) is correctly installed . Then , go to http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html and install FreeKapture , it's free .
Load FreeKapture , clic on Scan and select WIA Hewlett-Packard . Scanner works fine in this mode . If you choose HP PrecisionScan Pro , program will hang .
In any case , no slides or negatives scans possible but the rest works .
Regards ,
Thank you for visiting FixYa .
Jan 20, 2011 | HP Scanjet 4470c Flatbed Scanner
Driver for 5470c scanner will not work with windows 7
Hi ,
Scanjet 5470c does'nt work under W 7 . No drivers available .
Here are a few hints :
1° hint :
Do not connect scanner .
Load XP driver ( yes , XP) , reboot , connect scanner and wait for confirmation of successfull operation .
Reboot .
Dowload and install FreeKapture ( yes , it's free ) from http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Open Freekapture , clic on Scan and select WIA-Hewlett-Packard . Scanjet 4470c works fine in this mode but if you choose HP PrecisionScan Pro , program will hang .
2° hint :
If you have the W XP install disc , you could install a virtual version of W XP on your HDD ( http://downloads.vmware.com/d/info/desktop_downloads/vmware_player/3_0 ) You could also partition your HDD ( http://www.partitionwizard.com/free-partition-manager.html ) and install W XP on the new one . Regards .
Jan 06, 2011 | HP Scanjet 5470c Flatbed Scanner
Cannot connect hp scanjet 4470c to windows 7
There is no driver for this scanner under W7 but I succeeded to make it work this way :
Regards ,
Nov 27, 2010 | HP Scanjet 4470c Flatbed Scanner
Hi, HP scanjet 5470c scanner does not work on windows 7? HP hase no driver for vista, or windows7. What must i do? Greetings Peter.
Hi ,
if you are actually talking about 5470c and not 2200c , here are a few hints :
If you have the W XP install disc , you could install a virtual version of W XP on your HDD ( http://downloads.vmware.com/d/info/desktop_downloads/vmware_player/3_0 ) You could also partition your HDD ( http://www.partitionwizard.com/free-partition-manager.html ) and install W XP on the new one . Otherwise , you will have to buy a new scanner , what you probably already have done .
Regards .
Oct 10, 2010 | HP ScanJet 2200C Flatbed Scanner
I have installed scanner and disc but cannot find how to use it.I found the test box and that works but now how do I scan?thanks
Canon and other Scanners have both hardware and software buttons to scan documents and photographs.
Scanning with a computer is done with a destination in mind. So the buttons and the software are associated with destinations.
Typical destinations are File, email, Application, and print.
In a simple scan process for copy or print, the item is placed face down on the scanner, then the print button is pressed on the front of the scanner.
The software for the scanner pops up on the screen and the scanner moves the imaging light across the scanner under the glass, reading the item on the scanner. The software sends the image to the default printer and it prints a copy.
You will need to setup your preferences in the software so that a photograph is scanned properly and a newspaper article is scanned to come out clear black and white.
Documents are best saved as PDF files and photographs as TIFF files.
The software will have an expert mode where you can change all the settings and a beginner mode where you let the software decide.
Canon has a great document for your scanner. If it is not on the disk, here is the link. It is called CanoScan 4200F Scanning Guide. I think it will help you to use the scanner for any task.
Apr 24, 2010 | Canon CanoScan 4200F Flatbed Scanner
HP does nor offer a Windows 7 driver for HP4470
If you have the W XP install disc , you could install a virtual version of W XP on your HDD ( http://downloads.vmware.com/d/info/desktop_downloads/vmware_player/3_0 ) You could also partition your HDD ( http://www.partitionwizard.com/free-partition-manager.html ) and install W XP on the new one . Otherwise , you will have to buy a new scanner , what you probably have already done since a long time ago .
Regards
Dec 17, 2009 | HP Scanjet 4470c Flatbed Scanner
Scanning 35mm negs on my Epson Stylus PHOTO RX620
Try using a slightly off-white background sheet behind the negative (glass-negative-sheet-scanner lid) first, or a "frame" around the negative that is anything but white... some scanners have an auto-detect feature that may be skewed for one reason or another.
Another trick, from a photographer friend, is to take saran wrap or another transparent but non-reflective material and place as a filter between the negative and glass, thus reducing glare. The sharpness may be lessened, but the glare is also lessened...
Hope this helps!
-- RT
Aug 28, 2009 | Epson Perfection 4490 Office Flatbed...
Anyone dealt with a A99HW 35mm film scanner
Have you installed the software and running the scanner through the software?
Please see the FAQ below
Alan (20/08/2009)4-stars-small.gifThis works well scanning negatives when I eventually got it working on my Windows XP computer, the problem is the drivers, so did a search and found them here External link removed. The link can be requested via our technical department directly you need the one for XP only (FS-C1-VP). I also used an earlier version of Photo Impression6. I hope this is of help to many who have failed to get it running properly
So contact Maplin Tech support and they should be able to point you in the right direction of downloadable drivers or the correct procedure for installation and use.
Jan 21, 2009 | Cameras
Scanning negatives
Are you saying
The scanner worked with negative with XP but not with Vista?
Uf so this is a drver problem
Two thing to try- 1, Go to Programs/Accessories/system Tools Compatability Wizard and rest to XP then try.
Or 2 Google for suitable Vista Driver
Jun 11, 2008 | HP Scanjet 4070 Flatbed Scanner
Canon CanoScan 3000F Flatbed Scanner Logo
43 people viewed this question
old marine
old marine
mukhtar21 shaikh
mukhtar21 shaikh
