Question about Acer AL1715 17" LCD Monitor
ACER AL1715 PowerLed blinking only,no picture,flash about .5secs
Hi i have an ACER AL1715 flat screen monitor,last night it was working then when i woke up this morning and when i turned on my computer
my monitor power led (color green) only blinks. then when i press the menu button for about 1-5 secs. it only flashes the picture about half a second. what seems to be the problem. help please. =(
    Novelist:
    Filmmaker:
    Uploaded 5 video answers.
  • 64 Answers
Possibilities include a bad inverter or a bad back light. The inverter powers the back lights. If the inverter senses a problem such as a bad back light or transformer, it will shut down the back lights after about one second. There is actually a picture on the screen, it is just not back lit. Place a flash light flat against the screen and you should see a dark picture.
A common problem in monitors made in Taiwan and China is bad electrolytic capacitors, usually on the power supply board. Bad capacitors usually have a swollen top. This can also cause the screen to go on for a second and then shut off. In this case, the entire monitor will shut down and there will be no dark picture with a flash light. A blinking power suggests it is a bad capacitor.
Posted on Oct 15, 2014
  • 111 Answers
This sounds as if you are using the hibernate feature in windows reboot it and reset the power options to hibernate never check the vid connection as well
Posted on Dec 19, 2008
Plugging into a laptop
When you have strange problem like this, first thing to check will be the power supply section, look for caps with bulging or leaking. Please example of failed ACER here so you will know what to look for.
http://s807.photobucket.com/home/budm/allalbums
May 02, 2010 | Acer AL1715 17" LCD Monitor
My Acer Al1715 monitor does not display a picture the power is fine as the green light flashes but no picture at all
The light should come on steady. Your monitor most likely has the typical failed capacitor problem. The Power Supply board in the monitor most likely has some capacitors that have failed, visible signs include swelling of the ends of the parts, but they can fail without showing any visible sgns. Replacement of the capacitors often restores operation.
Feb 02, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
Screen has red dots all over the picture
its look like your lcd panel is getting break down. need to take to service.
May 19, 2009 | Acer AL1715 (Black, Silver) 17" LCD...
Flat sceen monitors, no sound
did you hook up the sound cable to the computer? and is the sound not muted in the on screen display?
check and advise
Jan 20, 2009 | Acer AL1715 17" LCD Monitor
SCRAMBLING SCREEN
befor replacing,make sure settings in video output from video card are set for that monitor.If color quality is set too high or resolution settings not supported by the monitor are used picture may not show up at all.(try safe mode,Settings are usually at bare min.in safe made)
Jan 09, 2009 | Acer AL1715 17" LCD Monitor
Acer AL1715 Monitor - screen distortion, discoloration, several times each day
Certain versions of the Acer AL1715 monitor had a problem with the VGA socket. Specifically, the plastic case around the socket was not wide enough. The plastic lip interfered with the plug and so the plug does not seat properly. This causes all sorts of intermittent problems. The version of the AL1715 with the problem with had the UPC code of 0 99802 19889 3. I fixed several of these monitors by shaving off the excess plastic with a Dremel Mototool. A hand file would probably work as well. You have to remove the plastic back to get the clearance to do the job.
e82875f5-b8a2-4548-9fdb-e60e2a37e9f1.jpg 14e1c79c-dd10-4643-b23c-053cfb0678e4.jpg fcd3ba29-2571-453c-838f-32c7fa61078d.jpg 038eb9e5-53a2-4fa0-88b9-56eb63be9378.jpg 19ef87e5-fc9a-423a-af2e-b0d949b0e884.jpg 092e022f-c3ac-4aa4-86ff-99eaa0075f07.jpg fe6adb60-288d-425f-9d35-156c724a2285.jpg
Oct 30, 2008 | Acer AL1715 17" LCD Monitor
The monitor turns off and on repeatedly.
does sound like a power supply issue... they are fixable but it's somewhat involved.
Robert
Aug 28, 2008 | Acer AL1715 17" LCD Monitor
Acer al1711
Hi.  I have no experience with an AL1711 but this sounds very much like the power supply problem that affects the AL1715.
If you understand electronics then you need to check the power supply for faulty components (there were two faulty capacitors in my AL1715).  Replacements should cost about 10p each and however much time it takes.
Unfortunately if you're not into electronics then there's really not much you can do.
If you do take the back off then please post whether you can see any faulty components.
Zeb.
Aug 05, 2008 | Acer AL1711 17" Flat Panel LCD Monitor
Acer auto config
same here never buy a freaking acer
Aug 24, 2007 | Acer AL1715 17" LCD Monitor
Certain versions of the Acer AL1715 monitor had a problem with the VGA socket. Specifically, the plastic case around the socket was not wide enough. The plastic interfered with the plug and so the plug did not seat properly. I fixed several of these monitors by shaving off some of the plastic with a dremel mototool. A hand file would probably work as well. You have to remove the plastic back to do the job.
Sep 02, 2006 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL1715 17" LCD Monitor Logo
561 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
