Question about Asrock 775i65GV Motherboard
My computer will hang after a few minutes of use.. i suspected the CPU maybe it will get heat easy so i put some thermal paste in the heat sink.. i already test the memory card, power supply, video card and i already format the hard disk.. but still the problem goes on..
  • sohcahtoa Jan 29, 2009
    i already change the ram.. but nothings happen..
Change the ram
Posted on Dec 19, 2008
Computer freezes randomly
If you have a fan that is not running, it can cause the system to run hot and freeze or shut down. Maybe that fan only turns on at a certain temperature so open the case and run the computer and keep an eye on the fan to see if it ever turns on. If not, replace it.
You probably need to apply a fresh coat of Thermal Paste around the CPU and Heat Sink. If it has dried up or is too thin to keep the unit cool it will cause the system to freeze, run hot or not be able to boot. Remove the screws from the fan that sits on top of the cpu and heat sink, then remove the heat sink, then unlatch the handle on the side that holds the cpu in the bay and remove the cpu (remember how it goes back into the bay). Clean off the old thermal paste then put the cpu back into the bay, secure it by closing the latch. Apply a fresh coat of Thermal Paste on the CPU, clean the old thermal paste off the heat sink and apply a fresh coat of Thermal Paste to it. Put everything back together.
Boot the computer up then download and install MalwareBytes and run a Quick Scan to see if you have a virus or infection.
Go to www.google.com and in the search box type: "Download cnet Malwarebytes" (without the quotes). Download and install malwarebytes from the sites download.cnet/malwarebytes. When the site opens up click on the Green Download button on the left. Do not click the Red Download button, that's junk. When it finishes installing the Gui Interface will open up with an offer to Accept a Trial Version or Decline. CLICK DECLINE you want the totally free version. Run a QUICK SCAN. As it scans, if it finds infections the number will be in red. When it finishes scanning, click SHOW RESULTS. A notepad text document will open up showing you the results. You can close the text document and go back to the Gui Interface where you will click REMOVE SELECTED RESULTS. The objects will already be selected for you. When it finishes removing the objects click ok and it will sometimes reboot your machine.
Jun 03, 2012 | Computers & Internet
Does not boot, no beep, no display, fans running on high speed
Try blowing the dust out of the inside, around the vents, around the fans and by the cpu and heat sink.
Also remove the fan as it sits on the cpu and heat sink. Then remove the heat sink that sits on the cpu, then remove the cpu by releasing the latch on the side of the bay it sits in (remember how the cpu goes back into the bay). Now clean off the old dried up thermal paste on top of the cpu and on the heat sink that sits on the cpu. Put the cpu back into the bay and secure the latch. Apply a fresh coat of Thermal Paste to the CPU and Heat Sink. Put everything back together then reboot.
If the thermal paste has dried or is too thin to keep the unit cool it's like metal touching metal and shorts out the system so it can't boot.
May 31, 2012 | Computers & Internet
My NB temperature over heats really easy. What can I do to fix this?
Your computer is overheating. Three causes of overheating are:
1) Dust - Dust inside the computer, dust clogging the fans, dust clogging the vents, dust around the cpu and heat sink. Remedy - Open the case and blow out the dust with a can of compressed air.
2). A fan is not working. Remedy Replace the fan. There are two so find out which one is not working. One is inside the Power Supply where the power cord plugs in and the other one sits on top of the CPU and Heat Sink on the motherboard.
3) The Thermal Paste around the CPU and Heat Sink has dried up or is too thin to keep the unit cool. Remove the Fan, CPU and Heat Sink and apply a fresh coat of Thermal Paste.
May 07, 2012 | Gateway DX4300-03 Desktop PC
My computer keeps shutting down after a few minutes. I have replaced the powersupply as well as the cpu fan. I am being told now that it is the system/motherboard. Is that an accurate answer?
When the CPUoverheats it goes into thermal shutdown and will not boot up again until theCPU has cooled down.
The heat sink may be clogged with dust, which causes the CPU to overheat byreducing air circulation through the heat sink.When you replaced the CPU fan, did you put new thermal heatsink paste on the CPU/heatsink? If not then the CPU can overhest. Your computer fanmay be faulty and not spinning freely, in this case replace the fan.
Check the fan and heat sink assembly and remove the dust, loosen the dust anduse a can of compressed air to clear away the dust.
Mar 21, 2012 | Computers & Internet
Emachine w3609 cpu overheating
Easy Fix.. Computers over heat because either a fan is not working, Dust has clogged the vents around the fans, CPU and Heat Sink or the Thermal Paste around the CPU and Heat Sink has become hard or too thin to keep it cool.
Remove the cover from the computer and set it aside then turn the computer on. When you hit the power button to turn on the computer make sure you hear and see the constant blowing of the fans. There will be a fan that is on the Power Supply where the power cord plugs in and a fan on top of the CPU and Heat Sink. If not, replace it. If the fans are ok get a can of compressed air from a local computer store and blow out the dust from the fans, power supply and all throughout the computer. In order to apply Thermal Paste on the CPU and Heat Sink you will have to remove the fan that sits on top of it and is normally secured by screws or some type of latching device. Once the fan is removed you can remove the heat sink and it too will be secured by screws or a latch catching device. Clean the old paste off the heat sink and off of the area it sits on. Apply a fresh coat of Thermal Paste to both and reassemble. Thermal Paste is available at local computer stores for under $20
I resently got new screws and washers and cleaned up the CPU and GPU and put new thermal paste on them. I put my xbox 360 back together and turn the power on and it works for like maybe 2 minutes then just...
2 red lights denotes a heating issue. The CPU or GPU could be getting too hot. Another issue could be that the heat sinks are not making good enough contact with the CPU/GPU. Since you said you put washers onto the xbox, try tightening the screws a half turn each, and see if that solves it. If it doesn't, you may need to reapply the thermal paste and try again.
Jan 16, 2011 | Microsoft Xbox 360 Console
Computer will no longer turn on
Hi
You must ensure CPU fan is operating as an overheated CPU will shut down PC. Sounds like you may have cooked the CPU.
Cheers cbacer
Aug 12, 2009 | Dell Dimension 3000 PC Desktop
Hang-up
hello. try to find original manual and check & try to set jumpers. Before that remove the battery and put it back in if you didnt try that, so the mboard will reset. hope helped any
Dec 18, 2008 | Asrock 775i65GV Motherboard
Replace heatsink fan on CPU.
The thermal paste should be cleaned off. Clean the CPU and heatsink fan with a dry cloth, which should remove the paste quite well. It is simply a viscous liquid and should not require scraping.
You should replace the thermal paste when installing the new fan. You can purchase it at your local computer supply store. Simply place a small dab of it on top of the CPU and then install the fan.
If you try to re-use the existing thermal paste, you will not get reliable heat transfer from the CPU to the fins.
Sep 11, 2008 | Computers & Internet
Asrock 775i65GV Motherboard Logo
54 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
