Question about Epson Stylus C84 InkJet Printer
Dead Epson C84
My C84 has worked perfectly for almost two years. Pressed power switch today and nothing happened - completely dead. Checked power supply and lead connection - all o.k. Sometimes I switch off wall outlet instead of 'off' switch on printer - may have done this yesterday - could this be a factor? Took end panels and top cover off hoping to find internal fuse which I could replace - but no such luck!
  • Tom Bancroft Mar 30, 2007
    Many thanks to Chevvy 1976 and printhater for replies to Dead C84 problem. Portugal was "off the cuff" nickname - going there in three weeks - must have been subconcious prompt. Using my old Stylus Color 460 as a stopgap - slow and not best quality printouts - but it's lasted a damn site longer than the C84!
  • Anonymous Mar 14, 2014
    Was switched off. Had worked perfectly the day before. Today, won't switch on. Dead. Power supply OK
    Novelist:
  • 86 Answers
STOP using the wall outlet to shut off the printer; ALL inkjet printers need to go through a certain shutdown routine which ONLY happens when you use the proper "OFF" button on the printer... You will have to find the user's manual for your printer, or download a new copy from the Epson website... DISCONNECT the printer from the computer, then follow the instructions from the user's manual on how to print a test page (usually requires holding down a certain button while turning the printer on). Again, do this AFTER you disconnect the printer from the computer; the printer is designed to run through a quick self-test under those conditions, and it will attempt to print a test page when it completes the self-test process. If the test page prints successfully, you can shut the printer down, then reconnect it to the computer, and reboot. Your problem should be solved, and you'll know what to do the next time this happens. It would be best if you move the printer to a single power source, one that will prevent you from shutting off the printer unless you use the proper shutdown procedure. Good luck; hope this solves your problem...
Posted on Mar 30, 2007
    Problem Solver:
  • 7 Answers
The power supply inside your printer has failed. Unfortunately the C84 model does not feature a replaceable power supply. Sorry, but when a C84 power supply fails, you have little choice except to extract the ink cartridges and throw out the printer. You asked if this problem could have been caused by switching power at a point other than the switch on the printer. The answer is, "No." It's okay to power-cycle a printer this way. However, if your nickname of "portugal" truly indicates that you actually reside in Portugal, I would consider getting a "line conditioner", which would protect your printer (and your other computer equipment as well) from unfriendly spikes or dropouts in electricity. By the way, in the U.S. the phone number for Epson printer support is (562) 276-7525.
Why is it dead?
Check power at the source; there could be a tripped breaker. If power is getting to your dishwasher, there may have been sudden failure of a part, such as the heater.
Apr 14, 2010 | GE Dishwashers
My acer aspire 5920 is completley dead it will not turn on with a fully charged battery which was charged up using a second 5920, it will not turn on with a working power supply either. I have completly...
Might your switch be non-functioning? Can you check that independently?
Otherwise, sounds to me like you did eveything.
Same thing happened to me with my dog once. I let him out and that was it! :-)
Oct 09, 2009 | Acer Aspire 5920-6727 Notebook
Dead
you have a dead battery dont try to recharge it its burn hot temperature kill the and old the lead plate inside the battery move and short out the battery i seen that a million time change the battery its gonna be fine thank you for using fixya from montreal pierre
Jun 23, 2008 | 2005 Ford Explorer
Won't turn on
try the fuse in the plug
Apr 26, 2008 | Brother HL 1440 Laser Printer
Completely dead
Check the power adapter connection or the socket. Recently my power adapter socket gave me the same problem. When I check from the adapter using voltmeter it's seems to be working.
But when i plugged it in the laptop, nothing happens. So I google around for help and found this tutorial after following the suggestions I managed to revive my notebook.
Mar 20, 2008 | Acer Aspire 3000 Notebook
Polaroid i533 won't power on
I havent even had mine for a year yet! BOO HOO! I really need a camera cause I have a baby
Mar 01, 2008 | Polaroid I533P Digital Camera
Epson C84 - no power
Most likely cause is the power supply has let go. It could be a fuse inside the power supply. You would need a servie manual to get you in to the machine to check if a fuse is present on the PSU. Try either of the following: http://www.TheServiceManualShop.com http://mikeburton.tradebit.com (Join his list to see all the files available) Either of these should help you get a manual
Apr 12, 2007 | Epson Stylus C86 InkJet Printer
Epson Stylus C84 InkJet Printer Logo
167 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
