My data cable to the monitor functions but i do not recieve the signals
There may be Problem with your Video Graphics Adapter (VGA).
Try External SID Card
Posted on Dec 19, 2008
Helo. i got this appian rushmore quad Graphics card installed in my computer i have a DMS 59 -> VGA splitter on it with 2 monitors. i currently am workign with 3 monitors under a onboard card (1) +...
did you install it with the disc that came in the package
did you go to add devices to add all of the monitors
have you checked compatibility for the graphic card with the os you have
Mar 26, 2017 | Appian Graphics Rushmore (64 MB) Graphic...
The monitor is coming on, saying there is no signal being recieved when the cable linking the monitor and screen is in fine working condition, and then turns itself into standby mode. Can this be fixed?
yes it can, the lcd is not communicating with the cpu. check the cpu with a known working screen. check the data cable also, if all not changing anything check the lcd pc board, if not sure about this take it in for repairs. Be careful when handling power circuits!
Oct 28, 2010 | Hannspree HW191D LCD Monitor
I have a samsung 17'' lcd monitor.when i power on my monitor without data cable i got a message on screen CHECK SIGNAL CABLE.when i connect data cable my lcd is going to power off.please help?
The message says that the monitor doesn't receives signal - which is normal. Since the problem appears only after you plug in the cable in means that the problem is located there - something is wrong with your pc, most likely the video card has died.
Oct 03, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
Hooking up my Sony HD Tv
Couple of items come to mind.
In the menu of the receiver, is there a way to choose video and RGB?
Set the receiver to SAT
Connect the HD Cable Box to SAT
Check the TV is on Monitor RGB.
Check the input being used by the monitor RGB cables is selected on the TV.
Have a picture? NO, receiver has issues.
Yes? Do this with each input to confirm they work.
You can reset the whole receiver to factory by holding the tone button down and holding the standby button for three seconds. (This clears your speaker setups, too.)
Apr 02, 2010 | Televison & Video
Brand new Monitor blank screen says No Signal
There is nothing wrong with the monitor. The LCD is not recieving any signals from the PC. Either you are connecting the VGA cable incorrectly or your VGA card is not set from the PC BIOS. The VGA cable might also be faulty.
Recheck that all the connections are clean and secure. If you are using a PCI-E or AGP card, the computer BIOS should be set to send the video signals through the PCI-E or AGP card. Follow the procedure in your motherboard manual.
If your pc has on-board graphics then you should connect the VGA cable to the on-board VGA out connector.
Oct 19, 2009 | Acer X203H bd Monitor
Second monitor detected but no signal?!
Try holding the function key ( fn) and pushing the F4 button. This very well may fix your problem.
Sep 22, 2009 | XFX NVIDIA GeForce FX5200 Graphic Card
Can get tv channels/signal through the monitor
try changing the cable connecting the tv to dvd it could be faulty
Apr 30, 2009 | Televison & Video
LCD Tv doesnot recieve signal from apple computer
try and borrow an adapter from a friend and see if it works. :)
Nov 05, 2008 | Apple MacBook Pro Laptop Computer with...
Green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Oct 13, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Check signal message when data cable unplugged. blank screen when data cable plugged
This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
Feb 05, 2007 | IBM E74 17" CRT Monitor
Computers & Internet Logo
313 people viewed this question
David Payne
David Payne
