Question about SanDisk Sansa Clip MP3 Player
Sansa mp3 player not switch on.
Bought d sansa mp3 player(litle monsta) few days back bt now its not even switchng on nor does it charge.help me
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
Sansa e280 was charging on the computer and computer died, now mp3 player won't turn on anymore, even when charging
Hey its Sunil here....
Just open the back panel of the Sansa... Take out the battery & replace it and switch it on...
Feb 18, 2010 | SanDisk Sansa E280 MP3 Player
My sansa lil monsta will not turn on
if you have tried to reset it and this has not helped the battery may be dead, you can purchase from Amazon for very short money.
Mar 22, 2009 | SanDisk Sansa e200 MP3 Player
-Tha Mp3 Doctor
Dec 19, 2008 | SanDisk Sansa Clip MP3 Player
My Sansa Express Music Player shows mulfactioned error
Insert A Micro SD Card And Start It Up
It Should Work
Shut It Down And Remove The Micro SD Card
It Should Startup Fine.
Sep 09, 2008 | SanDisk Sansa c150 MP3 Player
Sansa E250 hanged
I got a sansa player and it all of a sudden stopped working - It might just need to be reset - not sure if this will help but it did with mine.
If you have a power button that "slides" hold it up in the "on" position for 15 seconds.
Sep 02, 2008 | SanDisk Sansa e250 MP3 Player
Sansa Fuze not working anymore
My friend give me a sansa mp3 player BB0703UBB. When i charge it in my PC and i forgot to unplug sansa mp3 player BB0703UBB after half hour i plug it. But the power is not working. i cannot open and play it anymore. I try to insert it on my PC but then it says unknown device. HELP!
Jul 17, 2008 | Audio Players & Recorders
It´s dead
hey buddy just do one thing.. open the metal cover removing the 4 philips screws.. and then remove the battery then reinsert the battery and try.. it should work ... i had the same thing few days back.. it was charged and in my pocket when i tried to listen to it the damm thing wont switch on .. so i removed the batter and put a LED to the terminal to check power and inserted it back it and valaaa it hot and running again..
Jan 25, 2008 | SanDisk Sansa e250 MP3 Player
Sansa clip mp3 player
im experiencing the same problem...please help me....when i plug it in my computer it says it was connected and a new hardware found and asking for a installer and that it i cant do anything.....im using windows xp....guys, help me please! thank you very much!
Nov 08, 2007 | Audio Players & Recorders
Need help quick with sansa e280
try switching your usb mode, do that by going into settings, this might help but im not sure
May 28, 2007 | SanDisk Sansa e250 MP3 Player
Blank White Screen - No Menu Showing
My Sansa has a similar problem. Sometimes when the Sansa turns on (after the Sandisk logo) the screen will either turn black, blue, or black and white stripes. The player still works, but it is hard to navigate without the screen, obviously. What I end up doing is letting the backlight turn off and then pressing any button. Sometimes when the screen comes back, the display is allright again. But sometimes it takes more than a few tries. Turning it off and on again seems to work a little better, but it is more time consuming.
Apr 01, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
