Question about Kenmore 54383 Side by Side Refrigerator
Refrigerator not venting
My Refrigerator is not venting from the top. If I stand infront of the Refrigerator on the freezer side feel as if the coldness is coming from the bottom. I open it and notice that there was ice on the cooler(I think that is the name). As such I let it sit for about 2 hours and then plug it back on.At this point everything seems to be working fine. Once I repack my Refrigerator and turn it on ther was no air coming from the top vent. I then lower the temp on the Freezer and not that cold air is coming from the vent. This morning the vent is not working. please advice. help Help. My Refrigerator is 6 years old
3 Suggested Answers
  • 146 Answers
SOURCE: No cold air blowing into the refrigerator - temp too low
You have your own answer there - You have overfrosting and icing up behind the freezer, this will affect proper cooling - also if you have seperate freezer and refrigerator controls, it's possible the damper is not opening properly to let the cool air in. But in your case it sounds like a defrost problem. You will need to have a service person inspect your control board and defrost timer components - sometimes it's as simple as a board replacement due to a burnt resistor these things are the most common causes.
Good luck
Posted on Sep 25, 2009
  • 59 Answers
SOURCE: Refrigerator is not cold
Hi Louis,
This is what has happened. Due to the door being opened for so long moisture which is naturally in the air has collected on your freezer coils. What you need to do is turn the whole thing off for at least 24 hours. Open the doors and put some towels around it to let the frost melt out.
All the air that gets cooled in your unit gets cooled by a fan that pulls air through those coils. Once the frost has melted out of them it should cool just fine.
Posted on May 25, 2010
I have an Amana side by side refrigerator. Last night I noticed water running from underneath and the ice cream in the freezer melting. I found dog hair clogging a vent and cleaned it. This morning the...
usually when the bottomof the freezer is cold and the top isn't it's the evap fan motor isn't working and all the cold air sits at the bottom.when you open the freezer door you should hear the fan running inside the freezer,also tried to look up your model but it didn't come up.open the fridge door,look up on the right and hear the cieling and you'll see a tag with the model and serial numbers,i just need the model number and i can help you better
Jan 30, 2011 | Amana ARSE66MB Side by Side Refrigerator
My Maytag Plus refrigerator does not work, lack of frost, cold. The freezer side is working fine.
Need to see if the damper is open inside the fridge.  This the vent in to top left hand corner.  If it is not open then the damper needs to be replaced.  If it is open then one of the return vents (lower part of fridge) is blocked/plugged.  Let me know what you find.
Oct 21, 2007 | Maytag MSD2756G Side by Side Refrigerator
My refrigeraer has the freezer on top. the freezer is working fine but the bottom part does not get cold enough. i would like to know if it needs a part or if it ready to discard thank you. my email...
There should be a fan that blows air from the freezer compartment to the refrigerator side. Check to see if you can hear the fan or feel air coming from the vent. Also if the defrost is not working properly ice formation can block the air flow on some models. Also make sure the vent between the 2 compartments isn't blocked.
Dec 28, 2010 | Whirlpool ED2FHSS Side by Side...
Upright side by side. Refrigerator is getting warmer. Fan/vent on top is blowing okay. Vent at bottom left-above the bin-does not blow. Is it supposed to blow or is it just a vent? Coil is clean. ...
inside your freezer behind the vent if you stick your hand on the inside you should feel air blowing if not then the fan is gone if the fan is slowly making revolutions then you should replace also you can find the part at marcoe appliance parts or allbrands appliance parts they willmail directly to your door hope this helps plz write back if it is not your fan inside the freezer
Jul 25, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
The refrigerator side is not cooling though the freezer section is working.
Check in the frig side upper left at the top. The frig has to be running. There are air vents that bring the air to the frig side. If you dont feel any air this is what could be the problems with that:
Freezer fan not running
vent is closed
vent is iced up
evaporator is iced up
try to determine which one of these it is or not...
let me know and we will go from there
hope this helps
Mar 30, 2010 | KitchenAid Architect 25.3 Cu. Ft....
Kitchenaid KSRA25IL Freezer working Fine - Refrigerator not
many times when a unit has a defrost problem the coils freeze up and do not allow the fresh food side to cool properly...check for a build up of ice on the inside back wall of the freezer compartment. if there is a build up of ice, you have a defrost problem. Also, check to make sure the evaporator fan in the freezer is blowing the air into the fresh food side.
Dec 26, 2008 | KitchenAid KSRS25IL Side by Side...
Kenmore 54383 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
