Question about Adobe Acrobat 7.0 Professional
Acrobat 7 Pro - combining multiple pdf to single pdf errors
This error has re-occurred on three different PCs, all using licenced Acrobat 7.0 Pro. The problem remains the same on each machine - when combining correct single pdf files into one combined pdf file, especially on headers and sub-header lines in the combined pdf file we find that characters are missed out. They are correctly spelled in single pdf file but incorrect in combined, e.g. single pdf will have 'Project Name' and comined pdf will have ' ro ect N m '
Do you know of any similar instances and if so, what is causing this problem?
The 11 multiple pdf files range in size from 94kb to 263kb for a total of just ober 1Mb.
We have merged similar files before in exactly the same way but this is the first time we have encountered such a problem.
Your assistance would be gratefully appreciated.
  • jcommerford Dec 19, 2008
    PROBLEM RESOLVED.
    Problem caused by an incorrectly converted pdf file from an Excel 2003 worksheet. The worksheet had imbedded print titles.
    Acrobat PDFmaker cannot create tags, bookmarks, comments and links with print Titles. Asked it to ignore the tags but was still incorrect. Cleared the printtitles in Page Setup. Converted 100%. Multiple file conversion thereafter was also correct.
    Many Thanks.
    Scholar:
  • 98 Answers
Https://acrobat.adobe.com/in/en/acrobat/how-to/merge-combine-pdf-files-online.html
Posted on Mar 16, 2017
SOURCE: Getting a message about and error on page.
Dear Wendy,
This can happen because of multiple reason:
a) It isn't your fault. The file publisher has not correctly made pdf or its corrupt and won't work on your system because all pdf files can be opened in almost all versions.
b)You might like to check your adobe 8.1 settings for complete installation. Have you correctly installed the program. Also check if you are able to other pdf files on your system or not.
c) you can also try an older version of acrobat, which i doubt should affect the problem.
Finally check the file extensions and password protection problems.
If that was helpful please press solved.
Posted on Nov 26, 2007
lenny297
  • 133 Answers
SOURCE: Adobe acrobat v7 can't open file
Do this:
1. Exit Acrobat.
2. Choose Start > Run, and type: %APPDATA%\Adobe\Acrobat\ into the Open text box. Click OK.
3. Right-click either the 6.0 or 7.0 folder, and choose Delete.
4. Start Acrobat and attempt to print.
Note:Acrobat preference files contain application settings such as toolbar arrangements. When you restart Acrobat, new preferences are created automatically based on application defaults. Deleting preference files will not result in the loss of saved documents.
Or, if u have having Quarkexpress in your machine update the version. Quarkexpress also creates PDF files, maybe this is where it was created from
Posted on Mar 14, 2008
SOURCE: Programmatically creating Postscript and PDF files
Check out this site http://www.ce.utexas.edu/prof/maidment/GISHYDRO/saunders/acro.htm
Posted on Jan 27, 2009
  • 12 Answers
SOURCE: Missing lines on PDF from a large TurboCad file
Will TurboCAD allow you to export to a .pdf instead of printing to a .pdf? Have you tried printing to a file (.prn) before turning the file to a .pdf? To print to a file, click Print Setup, there should be a box to check to Print To File. Make sure you check that box. Then you should be asked to pick a file format which should be .prn if you are using windows. After you create the .prn file, then open Acrobat and convert the .prn to a .pdf. I hope this helps you with your problem. Printing can be a pain with CAD programs.
Posted on May 08, 2009
label_chick
  • 407 Answers
SOURCE: I can no longer create 1 pdf file from mulitple files in acrobat 6.0 standard. I have to create a pdf for each file in word or excel and then open up acrobat and create 1 pdf file from multiple pdfs.
Have you tried appending to the document? this should give you the option to add multiple files to..
Posted on May 22, 2009
Object reference not set to an instance of an object. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information a
change PDF readers program.if yuo absolut want adobe acrobat uninstall it download new version.install that but be sure of get out all old files.in C\
Apr 01, 2013 | Computers & Internet
How do I scan multiple pages to one pdf file from my hp photosmart d110 printer
The scanner is for scanning 1 page at the time and save to a pdf file. To combine multiple pdfs into a single pdf requires user to use a program like Acrobat. There is a free app "PDFBinder" for Windows user as describe by Rob Lightner on CNET. Follow below link for download and instruction.
http://howto.cnet.com/8301-11310_39-57344712-285/how-to-combine-multiple-pdfs-into-one-document/
Feb 14, 2013 | HP Photosmart D110a Wireless E-all-in-one...
Changing word docs to pdfs worked for a long time op system windows Xp pro w office 2003 Adobe acrobat pro 7 error message the Acrobat PDF server cannot be loaded run installer to re install tryed...
LIbraOffice.org can read and write most office documents. It also has a built in feature to simple save a document as a PDF. It is self contained and does not require additional software to do so. I recommend using this as a replacement to Office 2003.
If not, a one time use for this project should still do what you need.
Apr 27, 2011 | Computers & Internet
I keep getting messages ..could not find acrobat External windows handler; . brand is e machines ..error messages,,
Hi Kate1958. I found this for you. Do one or more of the following solutions:
Solution 1: Remove all versions of Acrobat or Reader, and then reinstall one version.
If multiple versions of Acrobat or Reader are installed on the system, remove all versions and then install only one version. See the documentation included with Windows for information about removing programs.
Note: If you need to have multiple versions of an Acrobat product installed, remove all versions and then reinstall them starting with the earliest, installing the latest version last.
Solution 2: Start Acrobat or Reader, and then open the PDF file in the web browser.
If an error occurs when you try to start Acrobat or Reader, refer to Related Documents below, or search the Adobe Support Knowledgebase:
-- If you use Acrobat, go to www.adobe.com/support/products/acrobat.html .
-- If you use Reader, go to www.adobe.com/support/products/acrreader.html .
Solution 3: Make sure that the External Window Handler file (ewh32.api) is in the Plug-ins folder.
If this file is missing, reinstall Acrobat or Adobe Reader.
The default location of the Plug-ins folder is:
-- For Acrobat: Program FilesAdobeAcrobat [version]Acrobat
-- For Reader: Program FilesAdobeAcrobat [version]Reader
Solution 4: Disable Web Browser Integration.
Disable Web Browser Integration so that PDF files open directly in Acrobat or Reader instead of in the web browser.
To disable Web Browser Integration in Acrobat 6.0.x -7.0.x or Reader 6.0.x -7.0.x:
1. Open Acrobat or Reader.
2. Choose Edit > Preferences > Internet.
3. Deselect Display PDF in Browser.
4. Click OK.
To disable Web Browser Integration in Acrobat 5.x or Acrobat Reader 5.x:
1. Open Acrobat or Acrobat Reader.
2. Choose Edit > Preferences > General.
3. Click Options in the list in the Preferences dialog box.
4. Deselect Display PDF in Browser.
5. Click OK.
To disable Web Browser Integration in Acrobat 4.x or Acrobat Reader 4.x:
2. Choose File > Preferences > General.
3. Deselect Web Browser Integration in the General Preferences dialog box.
4. Click OK.
I hope this helps. Please dont forget to rate and provide positive feedback for our fast-free support today. Thank you :D
Apr 30, 2010 | Computers & Internet
Can't save Adobe Acrobat 9 fillable forms
Fill in an interactive pdf form After you fill in the form fields, do any of the following:
  • Click the submit form button. Clicking this button sends the form data to a database across the web or over your company intranet.
  • In Acrobat, choose File > Save As, and rename the file to save the form with the data you entered.
  • In Reader, choose File > Save A Copy, and specify a location for the copy. Note: If the form author gave Reader users extended rights, the saved copy will include the entries you made in the form. Otherwise, the saved copy will be blank.
Enable Adobe Acrobat Reader users to save form data Ordinarily, Reader users can’t save filled-in copies of forms that they complete. However, you can extend rights to users of Reader 8 and later so they can do so. In Acrobat Pro and Pro Extended, these rights also include the ability to add comments, use the Typewriter tool, and digitally sign the PDF.
  1. Open a single PDF, or preview a component PDF in a PDF Portfolio.
  2. If you are editing the form, click Close Form Editing in the upper-right corner of the form.
  3. Do one of the following:
    • (Acrobat Pro and Pro Extended) Choose Advanced > Extend Features In Adobe Reader.
    • (Acrobat Standard only) Choose Advanced > Extend Forms Fill-In & Save In Adobe Reader.
    These extended privileges are limited to the current PDF. When you create a different PDF form, you must perform this task again to enable Reader users to save their own filled-in copies of that PDF.
If you don’t want recipients to overwrite the blank form template by saving form data, do not extend rights in the copy you send to them.
Limitations on saving filled-in forms locally
Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended each allow Adobe Reader 8 or later users to fill in and save PDF forms locally. The use of the Reader Extensions capability for local saving of PDF forms (called extended documents) is limited in two ways:
Number of deployed extended documents An Acrobat Standard, Acrobat Pro, or Acrobat Pro Extended customer can send an extended document to an unlimited number of recipients for them to fill in. For example, an Acrobat customer can post an empty form template on a web page that allows users to fill in and save PDF forms locally. An unlimited number of people can access the template. However, the Acrobat customer can collect only 500 responses from the filled-in form. This limitation includes both hardcopy (paper form submission) and electronic representations of the filled-in form.
Number of recipients of the extended document An Acrobat Standard, Acrobat Pro, or Acrobat Pro Extended customer can send an extended document to no more than 500 unique recipients. For example, an Acrobat customer belongs to an organization with 500 people or less. The Acrobat customer can send an unlimited number of copies of the extended document to those 500 recipients and collect unlimited responses from the filled-in form.
Both limitations apply per entity/company, and multiple users in an entity cannot abuse this feature. Obtaining additional licenses to use Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended does not increase the above restrictions. For example, five Acrobat Standard 9 users in a company cannot send out the same extended document to receive and extract data collectively more than 500 times.
Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended include technology that can enable PDF documents with certain features by using a digital credential. This credential is located within the Software (“Key”). You agree not to access, attempt to access, control, disable, remove, distribute the Key for any purpose.
I hope it helps.
Regards
Mar 16, 2010 | HP Computers & Internet
Same thing - just stopped working.
hi there - can you send me an error message - or the version of software you are using
Jul 24, 2009 | Adobe Acrobat 6.0 Professional for PC
Want to scan several pages as one pdf document
Try OCR Terminal,which is an online OCR service that converts scanned images into searchable text. Register an account and you can convert 20 pages for free every month.
Have a try and hope it helps.
Mar 30, 2009 | HP Officejet J6410 All-in-one InkJet...
Do this:
1. Exit Acrobat.
Mar 14, 2008 | Adobe Acrobat 7.0 for PC
Dear Wendy,
Nov 14, 2007 | Adobe Acrobat 6.0 Professional for PC
Adobe Acrobat 7.0 Professional Logo
403 people viewed this question
Top Adobe Computers & Internet Experts
Peter Dragonetti
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
