Question about Dryers
No heat Whirlpool dryer
Whirlpool model # SGDS800JQ2. There is no heat coming out of the dryer. I have already replaced the ignitor and there is still no heat. Any other suggestions?
  • bbonkers12 Dec 21, 2008
    You were absolutely right, I replaced the thermal fuse and it works great. Thank you very much, your help is greatly appreciated.
  • 179 Answers
When you turn on the dryer does the ignitor glow if it does replace the coils if not check the thermal fuse
Posted on Dec 20, 2008
Whirlpool gas dryer we have the ignitor comes on, gas lights, runs for a minute and shuts off. After about a minute the ignitor comes back on but the gas does not. thanks
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 17, 2010 | Whirlpool LGR8648L Gas Dryer
Drum turns but no Heat problem!!
Brian, if the glow ignitor comes on for a minute clicks and goes off then you need valve coils. if no glow at all could be ignitor or thermal fuse.
Jun 27, 2010 | Whirlpool LGR7646E Dryer
Whirlpool Model SGDS800JQ2 gas dryer getting no heat
Check to make sure the burner ignitor is not burned out. Check all the other parts you mentioned........ pull one wire off each part(one at a time) and check with with with an OHM meter.... should all be in the closed position.
Mar 16, 2010 | Whirlpool Dryers
I have a Whirlpool gas dryer, it won't heat up. I replaced the ignitor, but it still doesn't heat. The ignitor doesn't glow either. HELP
Replace the thermal fuse . The little 1 " long , narrow white part , with 2 wires going to it . Without the model number , I cannot tell you where its located .
Jan 28, 2010 | Whirlpool Dryers
Have a Whirlpool Gas Dryer - model # lgr7646a spins but no heat
Thre is no pilot light. This dryer uses an ignitor (glow bar or coil).
Open the lower front "door" (small access door) and turn on dryer.
If the ignitor does not glow (bright orange), then the ignitor needs to be replaced ($60).
If it does glow, then the gas valve needs replacement ($60).
If it isd the valve, the internal spring is stuck. Do not try to repair it, you must replace it.
Sep 25, 2009 | Whirlpool Dryers
My whirlpool gas dryer will not heat. I replaced
there is a big black box on top of the burner check this if good check theremal fuse this will be on the heat tube most likly in the back it is small and white
Jun 26, 2009 | Whirlpool Dryers
Comes on but no flame
The heat from the ignitor has to be seen by an electric eye--which turns on the gas valve, either one could be the problem.
Apr 26, 2009 | Dryers
Whirlpool gas dryer not heating up consistantly...
replace the sensor on side of the heat tube where valve and ign is located
Nov 26, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
196 people viewed this question
Top Dryers Experts
Marvin
Marvin
