Router problems My internet works fine but when i try to hookup my router it doesn't work even though i followed the step by step instructions so what do i do?
  • 916 Answers
After you hook up the router look in the wireless settings and select the option to clone the mac address. Some isp's block more than one mac address because they do not support home networks.
Posted on Dec 19, 2008
Wireless router will not power up?
Capacitors in the power supply have gone bad. Might be time for a new router.
Mar 06, 2016 | Belkin Connect N150 Wireless N Router
My router did not come with any software do i need it because i cannot get mine to work
Please reset the router by placing a pin in reset hole and push the pin sslightly, (remember you need to do this when the rrouter is in ON state)
Then connect your router to your computer using ethernet port (this is for configuration) and also connect the ADSL cable.
now open internet explorer and type in //192.168.1.1
Then it will prompt you for username and password
Username: admin
Passsword: password
this username and password is by default.
then configure your router as you need by changing display name, password authentication, MAC registration etc...
If you face problem with connecting internet even following the above steps, then you need to contact ISP(internet service provider) for settings.
Thanks,
Satheesh
Jan 04, 2011 | ASUS RTN10 wireless router
Network is "Hidden"
Try a router reboot.
1. Unplug the Router
2. Shut down and restart the laptops, unplug the XBOX for 20 secondes even though its working.
3. Replug the router.
If this doesnt work you can try resetting the router to the factory settings.
Follow the link below for step by step resetting procedure.
http://www.geckoandfly.com/5890/reset-d-link-router-factory-settings-and-default-password/
Jun 13, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
My internet keeps dro, i have installed filters ,
There is one case where everything is fine but still connection drops too often.---
This happens when the network type of your laptop is "public" as ublic networks are less secure, routers usually drop connections after sme time. Change the network type to "private". This should solve your problem. There is one more setting in your router where is says something like "automatically login when disconnected". Selecting this option allows automatically login to ISP when connection is dropped from ISP temporarily.
If network connectivity itself is the problem then you can debug followingly.
Step-1:
If ISP company says everything is fine from their side, then you need to check your router. To confirm this first connect the wall outlet of ISP to your laptop and check network connectivity. If there is problem, then ISP has to fix it.
Step-2:
If connection works fine then ISP is fine and you need to check your router settings. Now check network connectivity by connecting the laptop to the router through a ethernet wire. If the network does not work then your router hardware could be wrong and may need servicing or replacement. If this works fine then go to step-3.
Step-3:
Try resetting your router by using a paperclip. Usually the reset button can be found at the backside of your router. This will reset all the settings and there by making as good as a fresh one. Try to access internet from a place close to router where router signal is strong.
Change authentication and other network settings of your router to connect to ISP. Now network should work fine. Ensure that you set router password to avoid unauthorized access to your router by others.
Nov 08, 2009 | D-Link Computers & Internet
I have a Dell XPS 1330 laptop and a DI-524 wireless router.
Unsure what your problem is exactly but here is something to try. Power off all computers, modem and router. Power up the modem first, and wait until it is completely up before proceeding. Next power up the router and wait until it is completely up, the only light that probably wont be lit is the LAN light. Then power up each computer, they can all be powered on at the same time, that part really doesnt matter. See if that fixes the problem.
Aug 11, 2009 | D-Link AirPlus DI-524 Wireless Router
I can't get my WRT150N linksys routers CD to configure a network
Since the router is new, it will still be under Linksys's warranty, give them a cal and have them walk you through the process of fixing the problem step by step.
Dec 30, 2008 | Linksys Wireless-N WRT150N Router
Trying to install router, no success
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
Apr 14, 2008 | NetGear WGR614 54Mbps Wireless Router...
Confuguration Issue
You seem to be following the correct procedure, so the only thing left to do is re-set the router. My best guess is that the router password was inadvertently changed at some point. Reset to default settings: The following reset procedure will completely restore the default settings on the router including your password. Step 1 Locate the reset pinhole on the back of the unit. Step 2 With the router powered on, press and hold the Reset button. Step 3 Hold the Reset button for about 10 seconds. Step 4 Release the Reset button. Step 5 The device is now at factory defaults. The default username is admin and leave the password blank. You'll need to follow all the steps you performed initially to re-connect to your ISP.
May 28, 2007 | D-Link DI 514 Wireless Router (DI-514)
Sympatico & DLink DI-704P
It usually is simple, and hopefully the answer is as well. If you haven?t already done so unplug the modem and the router. Wait for a few seconds and then plug the modem in followed by the router. Reboot your PC and try the Internet again. If it still doesn?t work then I would try doing a hard reset of your router and reconfigure using the setup process outlined by the manufacturer. If that still doesn?t work let us know and we?ll continue ?.
Jan 01, 2007 | D-Link DI-704P Router
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
