Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
My computer won't boot nor display anything. It happened when I used the computer for about 12 hours. I think my processor overheated because according to the help about beep codes which I researched, 3 beeps means there is something wrong with the 1st 64KB of memory or a malfunctioning processor. Can somebody help me?
  • 20 Answers
1>> Just check your cable which joins HardDisk to Motherboard .... If Harddisk is not properly attached         to the motherboard ...your computer wont "boot" at all.....
2>> Even check your Battery(Lithium 3V rechargable) of your Motherboard...If your Battery is Damaged ... the computer will not start ... Because every program works on clock
3>>Also Check your RAM ...just deattach and clean with dry cotton and attach it again
Try these Steps your computer will repond......
Posted on Dec 19, 2008
    Scholar:
  • 93 Answers
Try replacing the Processor fan usually due to this processor over heats
regards
With using, the computer without reason/ warning got stuck and I forced turn off the computer; then, tried to turn on again. It was not Boot. The power on, but it is stuck in there, no Boot. Help!
A couple of things spring to mind, but difficult not having the machine.
Upgrade to Windows 10 is automatic and your machine is trying to update and finding a problem. I would not load Windows 10 until Service Pack 1 comes out.
Also sounds if the processor is overheating. When you boot up, you can get into the BIOS, often by tapping Delete, or F10. There is usually a prompt onscreen during boot up. One of the screens in the BIOS tells you the processor temperature. If it rises over 60' you have a problem with cooling. The computer has a fail safe feature to save the processor by shutting down.
Sep 02, 2015 | Gateway Desktop / Intel Core i3 Processor...
DELL 8400 MAKES A LOUD FAN NOISE AND WONT BOOT
There are 2 basic fans in Dell tower one for the power supply and the other for the Processor. If your computer is not booting then the Processor fan is most likely to be the culprit. What could be happening is that the Processor fan is no longer turning fast enough to cool the processor, so normal the processor when it over heats there is either protection to switch off the computer automatically or the computer won't boot. The best thing is to change the fan and make sure it is working properly but checking on the cables that they won't entangle on top of the fan to impede it's movement. You can easily damage your processor if the fan is not working properly.
Oct 18, 2011 | Dell Dimension 8400 PC Desktop
Hello, I have a problem with my widescreen. I have a laptop (HP Pavilion dv2418ca, Windows Vista, Memory 2,00 GB, Processor Intel (R) Core (TM) Duo CPU, 32-bit Operating System) and my widescreen...
It may be caused by overheating. Overheating is the main problem with HP portables. Use a fan to cool down the computer and check how long it last working. If blowing air with a fan "Appears to fix the problem" stop using the computer and get maintenance service for it. The processor area needs to be cleaned.
Nov 23, 2010 | HP Pavilion dv4-1120us Notebook
Acer won't boot up
Are the cooling fans working underneath
If they have stopped the processor will shut down
If it happens on a frequent basis you can cook the processor
Feb 12, 2010 | Acer Extensa Laptop
Acer won't boot up
when any computer posts/boots up.
it goes through a sequence of initialising things before booting.
i,ve been repairing computers for around 12-15 years.
1st i,d try removing the ram ( memory ) usually underneath the laptop, behind a screw cover. Or ocassionally under the keyboard.
if 2 sticks of ram are installed, remove the battery. and 1 stick of Ram. put battery on and try to boot. if no joy with that try the other stick of ram. and replace battery-Re-boot.
If this works you have 1 stick of faulty ram or faulty ram slot on motherboard. Failing this. I suspect that the CPU has overheated, and therefore a replacement Processor should solve the problem.
Thankyou for using fixya.
Mike @ compurepair.
Apr 20, 2009 | Acer Aspire 5315 Notebook
Sony vaio laptop model no VGN-S170P dose'nt boot / power up
oh...sounds like a virus problem....what i can suggest to you is the scan your computer using anti-malwarebytes...i think you this....
just search in internet if you dont know....
second..if still the same problem...uninstall some program in add/remove
Jan 04, 2009 | Sony MBX-49 ASSY Motherboard
3 Beep Diagnosis
try removing the memory chip and reinstalling it.
Dec 17, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Computer
i think the problem is with your processor fan....if you are using the system for many years...for example say 3 years.....dust will accumulate in the processor fan....and this in turn will produce more sound when the it is overheated also.....the solution is.....you have to remove the processor fan and clean it.....and then use it....this will definetly reduce sound.....try this...it will work 100%.........
Sep 20, 2008 | Intel Motherboard
My computer won`t display
Do you hear a single beep when it turns on?
Sep 19, 2008 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Computer not booting
remove & clean the ram then reinstall it your problem will sloves
Aug 24, 2008 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
112 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
