Question about Panasonic DMR-EH50 DVD Recorder
Panasonic DMR-50 while using my recorder it suddenly turns itself off? and R7:51 appears on the display?
Palmbeach
  • 185 Answers
SOURCE: AELFCHECK Problem with Panasonic DVD Recorder
Hi
This problem is associated with a regulator on the power board. It's an easy fix if you can use a soldering iron.
If not you may be able to get someone to repair it for you. I have posted instructions on how to replace the defective component.
Please note the instructions I have given refer to the DMR E55 but the E95H is much the same.
To see my earlier posting, please Click >HERE<
Posted on Mar 13, 2008
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Posted on Jan 31, 2009
nandosnut
  • 112 Answers
SOURCE: panasonic dmr-e55 won't work, just says "hold" on display
HOLD or X HOLD? If the latter - which is most likely - then the Child Lock has been activated! Press and hold ENTER and RETURN simultaneously until HOLD disappears!
Posted on Apr 24, 2009
SOURCE: Panasonic DVD player shows EXT-L in its display.
You have switched machine onto external link mode
Either press external link on remote or find it under the flap.
Has a small child been playing with the remote?
Posted on May 28, 2009
SOURCE: U88 displayed on dmr es15 panasonic dvd recorder.
Took off casing ,removed dvd unit. The laser runs along 2 metal spindles which i lightly oiled with wd 40. next to it runs another brass spindle which i also oiled. Re-assembled , and the machine is good as new.
Posted on Nov 16, 2009
Suddenly turned off. Why won't it turn on again?
TV Appears To Turn Off By Itself
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 12, 2013 - There are four cases in which your TV either turns itself off or appears to turn itself off. These cases are listed in the following table by category.
HELP! My LG LCD TV suddenly turn off by itself and ... - AVS Forum ...
www.avsforum.com/.../1084538-help-my-lg-lcd-tv-suddenly-turn-off-its...
Nov 13, 2008 - 30 posts - ‎22 authors
This morning, I turned it on, its suddenly turn off and on by itself repeatly. I can't even control the tv using the remote again. Then I try the trick ... Samsung TV turns on and off repeatedly before staying ...
Jul 1, 2014
My HDTV Shuts itself OFF then it Turns On by itself ...
Sep 12, 2008
More results from www.avsforum.com
Samsung Smart TV turning off - Forums - CNET
Dec 29, 2015 | Televison & Video
AD-DA display on sony je510
That means that your recorder is set to record analog. Hit the REC MODE button until it is set to record digitally.
Apr 08, 2014 | Sony Audio Players & Recorders
How to remove childlock
Hello
To unlock the receiver from child lock, Press '/Power ON button on the recorder. The recorder turns OFF and ' CHILD LOCK' appear on the display. The timer indicator remains lit if there is a timer setting. The recorder will not workexcept for timer recordings.
To unlock the recorder, Hold Down '/Power button on the front panel of the recorder itself, until the "CHILD LOCK" display disappears from the front panel display.
Mar 02, 2012 | Sony RDR-VX515 DVD Recorder/VCR
PHILIPS CDR 870 FLASHING "OPCFAIL" AND WON'T RECORD
I HAVE A PHILIPS CDR 870 "OPC FAIL" PROBLEM. I HAVE RECORDED ONTO CD-RW, AND NOT YET FINALISED THE DISK AFTER RECORDING, IN ORDER THAT I CAN GO BACK LATER TO ADD FURTHER RECORDINGS. AFTER SWITCHING THE MACHINE BACK ON OPC THEN OPC FAIL FOLLOWS, EVEN WITH NEW DISKS CD-R AND CD-RW. MGHT THE MACHINE ITSELF REQUIE CLEANING OR IS THIS A FAULT? I AM USING MAXCELL DISKS, BOTH TYPES. THANKS. JEREMY. GATESHEAD.
Mar 19, 2010 | Philips CDR870 CD Recorder
Mikomi ET858 digital voice recorder suddenly switched from saving files as .WAV to .ACT, whatever that is. Can play interviews on machine itself, but can't save them to computer. Help! How do I switch it...
Hi all,
I recently bought this little headache of a dictation machine to help me with my Law revision. Had similar problems but have worked out the following:
The machine appears to have 2 modes of recording - LP and SP. When the machine is in LP mode, it appears to be a format for the machine itself to allow for longer record time. Because of this individual format it will not play back on computers. If, however, you change it to SP mode (from what I can ascertain from the VERY unhelpful user manual is 'high quality recording' i.e. standard WAV format) it saves the file in a .wav format which is playable on computers.
To switch it from LP to SP (this is on my dictation machine only - i take absolutely no responsibility for breakages etc):
Turn on
Press 'M' to cycle to 'REC' mode
Use the Volume control to cycle between SP, SP VOR (no idea what VOR is i'm afriad), LP and LP VOR
Record as usual.
I've made test recordings on both SP and SP VOR and both save to WAV format and can be played back through a computer.
If anyone knows what VOR is then please shout back.
Hope this helps.
Liam
Apr 10, 2009 | Dictaphone Walkabout 5210 Digital Voice...
Lack of communication between DVD player and TV
I have just had the same problem. I changed the scarts over in the back of the DVD player, i.e top to bottom and bottom to top. I can record from the TV one way round and to view it and finalise etc I have to change them over. I have no idea why this is happening but it is a quick fix so I can record the rugby this PM.
Apr 27, 2008 | Panasonic DMR-E55 DVD Recorder
WON'T WORK!
In the back of your instruction manual there is a section on error codes and what to do in the event of.
Jan 29, 2008 | Toshiba RD-XS34 DVD Player/HDD Recorder
Panasonic DMR-EH50 DVD Recorder Logo
52 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
