Question about Samsung YP-T7Z MP3 Player
My mp3 jst stopped
I was transfering files to my computer and the mp3 was working fine. but whn i lata went back to turn it on it wont. i have no idea wot is wrong please help
4 Suggested Answers
SOURCE: Mp3 Not Being Recognised and Samsung Media Studio Not Installing
As with any issue with this type of digital device, you should always "RESET" the device first (little micro switch - next to the USB port, or on back) with a pin (or similar) for 2-3 sec's. I then suggest you fully 'remove' any Samsung Media software (via add/remove programs under control panel). Re-boot your pc, then connect your Z5 into a know working USB port on pc. See if it installs the Z5's driver correctly (ie starts communicating). If this gets it going, you must now download the newest firmware from Samsung's website (download centre), and then save the files into your Z5 (ie overwrite the old firmware). If this fails, then try Samsung directly for further intructions. Good luck.
Posted on Jul 01, 2007
SOURCE: Transferring files...
my brother had exactly the same problem as yourself.
wht i did was to take his mp3 player apart and disconnect the battery then putting it all back verry carfully i then tried to put things on his player and it now has no problems whatsoever.
i must stress the fact that if you do take the mp3 player apart do not touch any part of the pcb board as the static from your body will blow the components straight away.
so be carful and only touch the verry side of the board.
when putting the board back make shore that the board is angled awy from you as all the touch keys will go to the top of the board instead of being in direct contact with the keys.
i know what im talking about as im an ipc specialist.
so be warned.
Posted on Jan 04, 2008
SOURCE: Cant transfer music from samsung back to Windows Media player
i doont no how to tranfer music to my samsung yp-k3
Posted on Jun 08, 2008
SOURCE: Wont turn on
the ypk3 is not intended for xp use otherwise it totaly nacks the software on it you can only use it on XP trust me it happend to mine
Posted on Oct 01, 2008
0 characters
1 Points
My sansa mp3 play wont turn on
Tried this? 1.Push the hold switch towards the headphone jack so you see orange
2.Press and hold record on the left of the player
3.With record still being held down, plug into the computer
4.Once you see welcome to recovery mode on the screen of the player, let go of record
At this point you can reload the manual firmware by copying the firmware files to the detected removable disk.
Firmwares- Version 1 Version 2
Download the correct version or else it will render your device useless.Version can be found on the back plate at botton right.. Extract the downloaded file and transfer the contents to removable disk detected.After transferring,disconnect the player and let it upgrade the firmware
Sep 05, 2009 | SanDisk Sansa e260 MP3 Player
It keeps saying file error
Check the format of the music you are playing and if you have music that requires the license it will load the music but not play. It will show up as a file error.
Feb 28, 2009 | Coby MP300 MP3 Player
Wont turn on
poke a pen in the reset button on the bottom back of the player. same thing happened to me.
Jul 14, 2008 | Samsung YP-K3 MP3 Player
Computer not detecting
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
THEN, do the "Repair" in the Philips Device Manager
Jun 01, 2008 | Philips HDD1630 MP3 Player
Will not turn on
jst ******* people
May 01, 2008 | iLO MP3 Player
My videos wont convert i need help!
you need to go under settings then click on usb modes then change the mode to msc. if you dont have the option of usb mode, then do the following:
1) Download the sansa firmware updater from the sandisk website (
2) The program then turn off your sansa. (unplug it first).
3) Now move the hold button to the right and then hold down the center (round) button and then the power button.
4) Once your sansa is on, you can stop pressing the other buttons.
5) Now plug in your sansa.
6) Once this is done, your firmware updater should automatically start. If it doesn't, go to C:\programfiles\sandisk\.... and open it.
7) Select the most recent firmware and download it (it should automatically install).
8) Once this is done, disconnect your mp3 player (your firmware will then update).
9) Turn your mp3 player off.
10) Turn your mp3 player on.
11) go to Settings, USB Settings, and select MSC.
12) plug your MP3 player back into your computer and it should now recognize it.
Jan 09, 2008 | SanDisk Sansa e260 MP3 Player
Cannot transfer files
go to
download the updater. unzip the file and run the installation program. after you have install the iriver firmware updater, run the program. it will automatically detect what you need. follow the instructions. if the updater stops at 50% don't worry. wait bout a min or 2 then unplug your T30 and it will update by itself
Dec 07, 2007 | iRiver T30 MP3 Player
Won't play any songs.
I had this problem with my player (th 1101) when I was transferring songs from iMesh. After awhile I found out that even though I could listen to the files on the computer some wouldn't go on the mp3 player. Looked it up and there is an encoding on some tracks (preimium tracks they call it) that unless you pay for them they won't transfer off the computer (CD, MP3 players ect.). They also had free tracks that works just fine. Hope that helps
Nov 02, 2007 | RCA TH1101 MP3 Player
E280r MP3 player wont sync songs!
If your device is getting too close to its capacity, it will effect the menu on the device. You need at least 6-10MB of free space for the "music database". If thats not it, one or more of your files may be corrupt. To resolve this, you should format the device to delete all the music, then transfer it back to the player. To format, right click on the device under My Computer and select format. Please add to the question if that didnt work. Best of Luck.
Sep 26, 2007 | SanDisk Sansa E280 MP3 Player
My mp3 player wont work
ok! easy solution for you^^ 1) Make sure your Zen is powered OFF. if the blue light is on and won't turn off, here's what you do: set the hold button at the top of the player to the ORANGE position, then hold your power button for 3 seconds. the keypad will flash and your player will power down. 2) push in the reset button with a pin or other fine implement. the reset button is located on the bottom of the unit, right next to the connector. your player should power up as normal now. charge it fully! your computer should be able to read it during it's charge as long as you leave it powered on^^ I hope this helps you^^
Mar 25, 2007 | Creative Labs ZEN SLEEK MP3 Player
Samsung YP-T7Z MP3 Player Logo
18 people viewed this question
Top Samsung MP3 & Digital Media Players Experts
 Mike M
Mike M
Lawrence Oravetz
Are you a Samsung MP3 and Digital Media Player Expert? Answer questions, earn points and help others
