Question about HP Compaq Presario V2000 Notebook
Compaq laptop My bosses laptop wont turn on and there is a lightning bolt symbol with a corresponding light next to the power on light toward the left front of the computer... same place the power cord light is... But it wont turn on and the light blinks under the lightning bolt? What does the lightning bolt represent or mean? I have a compaq presario V2000 laptop that will never load to windows, it says windws is starting up but will never actually do it, it's frozen and I have no clue how to bypass this dilemma
    Scholar:
  • 80 Answers
Dear its your operating system problem and to resolve it first of all when your system is restarting and the boot screen appear press the F8 key select the safe mode option and wait for the system to log on. As soon as it log on goto start menu-->run-->type msconfig and than press ok and than goto startup and disable all the program from the startup and apply and restart it. If it does'nt resolve the problem than please revert me.
Posted on Dec 19, 2008
  • VIPINKUMAR YADAV
    VIPINKUMAR YADAV Dec 19, 2008
  • 365 Answers
I think it may be due the displacement of the RAM or may be due to the loose contact in the RAM.this is the reason why the lights blinks.it can be solved by placing the RAM correctly into the slot provided or it may be due to the damage in the power supply.the windows may not load due to the great load of viruses affected with the system .try to format it and install a fresh operating system and look.thank you
  • JITHIN ANTONY Dec 22, 2008
    have you checked all
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls try to remove the battery and the AC adapter/charge. Let it rest for a couple of minutes. Thereafter pls try again just using the AC adapter without the battery. Should this work OK, then pls try with the battery. In some cases, it may be needed to charge the battery for at least 4 hours.
Good luck and Thank you for using FixYa. Happy Holidays.
    Genius:
  • 2,785 Answers
The lighting bolt symbol indicates you are connected to ac current, for your boss laptop plz try by removing the battery and put in the electrical charger, if the problem is not solved then resit the ram and check.If the problem persists then your boss lap top needs servicing.
For your laptop plz try to boot in safe mode.While your laptop is booting (bios screen) press F8 then you will get safe mode option just select it,if your computer is booting in safe mode then try to boot it normally, if you cant boot in safe mode then you have to reinstall or repair your operating system.
Laptop wont turn on.
*Take out the battery,
*Remove main supply,
*Hold power button down for 30 secs,
*Put only power supply in, do not put battery in
*Turn laptop on
*Put the battery in.
Aftermarket Car Headlights
Jun 11, 2012 | HP Pavilion dv6-1030us Notebook
How do I turn on the flash? I tried to buy a really simple camera and there's just too much 'stuff' on it. everything seems to be ok, just can't figure out how to make the flash work. ...
Easy. When the camera is in normal shooting mode, press the up button (marked with the symbol of a lightning bolt) until the symbol of a crossed out lightning bolt near the top left of the screen turns to an uncrossed lightning bolt symbol. that's it.
extra tips-
  • if you keep pressing the up button until the lightning bolt symbol has a letter A next to it, the camera will fire the flash only when it thinks it is necessary. this will keep your flash from firing in bright light and therefore save battery charge.
  • remember when you flipped through your math textbook in the first grade and it had "too much stuff on it"? you think its too much because you aren't used to it. don't be afraid to mess with the settings in order to learn how to use your camera best; you can never permanently damage a camera in changing its settings. the worst that could ever happen is losing all the photos in memory. if anything else goes wrong, you can always return the settings to what they were when you bought the cam in a few button presses (refer to the manual).
good luck and happy shooting!
Sep 04, 2011 | Vivitar ViviCam 8018 Digital Camera
My HP Pavilion dv4 is 9 months old and just came back from HP "repair" (2 weeks) for incessantly beeping which started when the laptop was only 6 months old. Of course as soon as I turned the...
Sounds like a common problem!
http://h30434.www3.hp.com/t5/tag/beeping/tg-p
The "3 dvds stacked on top of each other" is the symbol for hard drive and will light up when there is hard drive activity.
Lightning represents electricity (ie. is the unit powered on and/or connected to a power source).
I'm not sure about the clock - or maybe it's a thermometer?
Jan 12, 2011 | Computers & Internet
Starting problem
Starting problem Answer hi i have a HP compaq nc6000 laptop, and when i try to start it up all i get is noise of fan... (More) hi i have a HP compaq nc6000 laptop, and when i try to start it up all i get is noise of fan starting up with one glowing orange light next to a lightning bolt like symbol. IWhen I turn ON my laptop first time HP Compaq nc6000, sometimes the orange LED will just light up and nothing happens, sometimes when I get lucky I will be able to goto Windows. when start work properly.
Jan 31, 2010 | HP Compaq nc6000 Notebook
How do i set the flash on my vivitar cam. model 8025
Touch the lightning bolt icon in the function area until the flash icon and the letter A appears on the left side of the display. This activates the automatic flash.
Touch the lightning bolt icon again until the letter A disappears. This forces the manual flash mode.
Touch the lightning bolt icon again until the eyeball appears on the left side of the display. This activates the red-eye reduction feature.
To turn off the flash function touch the lightning bolt icon repeatedly until the no-flash symbol (lighting bolt in a circle with a line through it) appears on the left.
This is all described in the manual.
Jan 23, 2010 | Vivitar ViviCam 8025 Digital Camera
Compaq M2000 laptop lighting bolt flash 3 times wont start
Could be a bad mother board or a hard drive..see if you can connect the hard drive with a USB on another machine and run a test on it...
May 27, 2009 | Compaq Presario M2000 Notebook
Compaq presario c300 wont turn on at all
Looks like a bad motherboard ,have you tried another power adapter the one that connects to the wall socket.
The motherboard could cost over $100 ,chepaer on Ebay or you could take it to a Compaq/HP service center and ask for a quote on the repair.
May 13, 2009 | HP Compaq Motherboard
FLASHING AMBER UNDER LIGHTNING SYMBOL
Is it an amber lightning bolt? (I am assuming thats what you mean by UNDER lightning symbol)
That is the charging symbol for your battery, it means your battery is being charged by your power adapter.
Jan 29, 2009 | Compaq Presario X1000 Notebook
Compaq laptop
its not charging try any other power adopter....
Jul 17, 2008 | HP Compaq Presario V2000 Notebook
Red eye
Greetings mccombs7,
There should be a button corresponding with a lightning bolt symbol. When red eye reduction (pre flash) is on, then there is a symbol with an eyeball next to it. Depress the button until you get to the desired setting, which should be the lightning bolt alone.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jul 01, 2008 | Samsung Digimax S630 Digital Camera
HP Compaq Presario V2000 Notebook Logo
121 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
