Question about SanDisk Sansa Fuze MP3 Player
My sansa fuze screen goes black whenever i move the wheel or push a button. it comes back on in aprox 5 seconds but as soon as a buttons push of wheels turn it goes black.
  • Anonymous Feb 20, 2009
    Same. what have you done about yours??
  • Anonymous May 16, 2009
    same problem-really annoying and mines brand new
I have the same problem.
Only work around I found was installing Rockbox, then in the settings turning off the wheel light.
Seemed guessing cable issue?? once wheel light when out, the screen would come back.
Posted on Oct 17, 2010
Whtie screen only after charging
Push the the On Button Up while Clicking Home at the Same Time. Once The Screen is Black, Turn On the Sansa Fuze and it should be fine.
Apr 21, 2011 | SanDisk Sansa Fuze MP3 Player
How to re format with sandisk firmware?
  • FOLLOW THE STEPS OF INSTRUCTION GIVING BELOW IT WILL SURELY HELp
  • INSTRUCTIONS
  • 1Press the "Home/Menu" button to return the Sansa Fuze to the main menu.
  • 2
    Highlight "Settings" and press the "Select" button to bring up a list of adjustable settings on the Fuze.
  • 3
    Choose "System Settings" and "Format." A confirmation message will appear on the screen.
  • 4
    Select "Yes" to format the Fuze. It will take several seconds to several minutes before the player is reformatted.
    Sansa Clip
  • 1
    Push the "Home" button to return to the Clip's main menu.
  • 2
    Choose "Settings" by highlighting it and pressing the "Select" button.
  • 3
    Select "System Settings" and then "Format." A prompt will appear on the screen asking you to confirm the formatting.
  • 4
    Highlight "Yes" and press the "Select" button to confirm reformatting the player.
  • Oct 02, 2010 | SanDisk Sansa MP3 Player
    My sansa fuze at times freezes. I do not know why,
    When the blue ring is illuminated, first try the RESET for the Sansa Fuze.
    The player should NOT be connected to any other device:
    1. Slide and hold the Power switch up for approximately 20 seconds.
    2. Release the Power switch.
    3. To turn the player on, slide the Power switch up then release instantly.
    When a RESET won't work or the player freezes again, UPDATE the firmware on the player in 2 steps.
    > step1: Enable MSC mode
    1. Turn device OFF: when the player is frozen first perform step 1 and 2
    of the RESET procedure:
    seconds.
    2. Slide the Hold switch down to Lock (orange colored dot showing).
    3. Press and hold the left button ( |<< ) while connecting the device to the PC.
    > step 2 : UPDATE the firmware
    Use next page for updating the firmware on the player.
    http://kb.sandisk.com/app/answers/detail/a_id/278
    There are 2 methods for updating, for Windows operating system the
    updater ( method 1 ) should work:
    Method 1; Use the Sansa Firmware Updater
    Method 2: Use the update board / Sansa forum
    Look in the Update page for the steps to follow.
    Jul 20, 2010 | SanDisk Sansa Fuze MP3 Player
    Frozen
    If the light around the spinning wheel is blue and the screen is black, then Hold the on/off button up for about 10-20 seconds and it should turn off. then you can just turn it on again. I fit doesn't work, then just wait for the battery to die and charge it back up.
    May 05, 2010 | SanDisk Sansa Fuze MP3 Player
    My SanDisk MP3 player is stuck on one Podcast and
    Press and hold for 20 seconds the ON and PLAY (>||) buttons at the same time.
    Mar 08, 2010 | SanDisk Sansa Fuze MP3 Player
    I was told that i could restart my sansa fuze with the restart buttom, but the problem is that my sansa fuze dont have a restart button
    this is work for you;
    Press and hold the "Home" button while sliding the power switch on the slide up - not sure how long it'll take (less than 30 seconds) but with headphones on, you will hear a faint "pop" (similar to when you plug in headphones or turn it on with the ear buds in). You can then release both buttons and it should turn on. It will "refresh" it's media list, but you shouldn't lose any tunes loaded.
    when Sansa Fuze freezes is hold up the power button for about 2O seconds. When this is done, release and it should say "Goodbye" on the screen. When you turn the Fuze back on it will take only a moment to refresh its memory. Try to wait if you are recording something important though, sometimes it will just start back up again, no harm done!
    Jan 11, 2010 | SanDisk Sansa Fuze MP3 Player
    Wont turn on... balck screen... when i hooked it up to my computer nothing happened... tried the lock button, power button, and the wheel... still nothing
    Hi, I just learned here that you have to do TWO things to get it to turn on. One, make sure the slider is in the On position. Then press and hold the play button (top one on the wheel) for 3 seconds. Worked for me, when previously the only way I could get it to turn on was to hook it up to a power source (wall or USB), which sounds slightly different than you. Hope it works anyway!
    Jan 02, 2010 | SanDisk Sansa Fuze MP3 Player
    My Sandish Sanza ( 2gb) backlight screen is black
    Reset All
    NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
    TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
    TO PERFORM THIS OPERATION!
    If your device freezes up press the Menu button and hold for 15 seconds.
    This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
    will be gone.....
    IF that doesn't work try to recover...download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Star the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa hope this works.... Please rate
    Jun 02, 2009 | SanDisk Sansa Fuze MP3 Player
    Power goes out
    easy fix my friend its temporary firmware problem . ok now to fix it plug the sansa in your pc ,just doing so can fix the problem if not ,unplug it from the pc the unit should have stayed on (the blue LED's of the wheel r on but no screen backlight) push the ON button on the side and hold it push for a good 20 secon then releass it that will make the unit do a soft reset and then turn it back on again it may chow the low bat simbol just plug it back in your pc the screen will show the turning arrow the backlight of the screen will work, let it recharge and there you go fix.
    Dec 29, 2007 | SanDisk Sansa View 8GB MP3 Player - Black
    SanDisk Sansa Fuze MP3 Player Logo
    276 people viewed this question
    Top SanDisk Audio Players & Recorders Experts
    Gyula Lacz
    Mohamed Ismail
    Mohamed Ismail
    Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
