Question about Kenmore 46123 Stainless Steel Electric Kitchen Range
F1 Error code
We had a storm last night here in Oklahoma, and our power flickered a little bit, and now I have a F1 error code on my display panel and noon of my functions will work. I can't turn on the oven or the oven light. However I can turn the glass top burners on. any ideas on how to clear the code. just as a side note I did unplug the range for about an hour. Help please.....
  • 3 more comments
  • Robert Shirley Apr 03, 2007
    Thank you,,, very much
    I figured that was what I was going to have to do. Good thing it is still under warrenty.
  • kcsun May 01, 2008
    I have a Kenmore single (separate oven. All of a sudden it blinks the F-1 code and beeps incessantly. I hit the cancel button and it stops temporarily, but begins to beep again. What do I do to stop this.
    Help
    Ken
    kcsun@mpinet.net
  • Anonymous May 28, 2008
    My Kenmore electric stove flashes F! and beeps. Any suggestions on how to fix the problem?
  • notkurl Jun 21, 2008
    F1 error and beeps until cleared. Sounds exactly the same as my issue. Where can I get a control board and the instructions for replacig it?
  • ekosborne Aug 03, 2008
    The F1 code has popped up on my Kenmore model 790.46804992 which is a glass top slide in. We've had it eight years and this has happened several times with this last time not solved yet (the F1 comes on and closck goes off after a few minutes). The instructions are to "push clear on the display and reprogram. If this does not work call for service". I found that throwing the breaker switch (which is easier than trying to unplug it) and leaving it off over night solved the problem for several years until now. You may even want to try turning the power off and on several times quickly to the stove, which could help reset it, before you call a repairman. In my situation has there been a part that is typically been replaced to solve this? Sounds like a resistor (or something like it) getting weak.
    Thanks for any suggestions.
I just had this same issues happen after running the self clean cycle. f1 error, fan would come on, fan would turn off. its not the control board, its the temperature probe. I picked up the part for 40 bucks and put it in myself. plugged the stove back in and it was good to go. the old temperature probe's wires melted during self clean. note to self: clean you over the old fashion way with some elbow grease.
Posted on Aug 26, 2009
F1 is na control board code you need to replace it
Posted on Mar 31, 2007
  • 3 Answers
Replace control board
  • kristopher reed Mar 31, 2007
    f1 is a bad control board
    replace control board
Haier Wine Cellar, Dual model, displays EE error code and was heavily iced on the interior back.
If the refrigerator or freezer displays error code, request a technician to check, please call the service
Different series display different error codes.
The error codes for the refrigerator: F1, F2. F3, F4, F5, F6, F7, EO, E1, E2, E6, Er, Ed, an so on
The error codes for the wine cellar: F1, F2. F3, F4, F5, H1. H2, A1, A2, E1, E2, EE, HH, LL, and so on
Notice: If you power off then power on, maybe the error code disappear, but it will display again after a few hours.
Mar 27, 2018 | Haier Refrigerators
My gas range started beeping last night, displaying F1 in the clock area. I uplugged it and plugged it back in but it still beeped with the F1 display.
Hi westae6733,
The F1 error code description is a bad touch pad or clock (ERC). You need to replace the control board (also called ERC or clock) to fix the problem.
Hope it helps.
Thank you for using FixYa.
Sep 22, 2011 | Kenmore Kitchen Ranges
Old Magic Chef wall oven (model 9875-5XRB), constantly beeps and displays the F1 error code. I have replaced the touch pad once before. Is that the only solution?
Does anyone know the answer? This was posted in October 2010! I ran the self clean too about a week ago. But we had a bunch of power outages last night. Today my oven has taken to beeping and flashing the F1 code. It is almost the same Model number. they wrote 9875XRB (not 5XRB) ...
Oct 18, 2010 | Ovens
Konica 7020 error code f-26-2
Says that it is a PCL connector problem. Look at all of your connections and make sure they are ok.
Jun 24, 2010 | Office Equipment & Supplies
What do codes e2 and f1 mean?
Here is what the manufacture says about it, my comments are below.
F1 E2 - UL A/D error(s)
1. Verify failure if not displayed, using CANCEL/OFF key. Press key for 5 seconds until last
error code is displayed.
2. Disconnect power longer than 30 seconds.
3. Re-apply power and observe for longer than 1 minute.
4. If failure remains, disconnect power, replace control.
Phil's comments----->
F1 Codes are related to the control itself, if there was a storm, power outage, surge etc it could have damaged the control. Try resetting the board by unplugging the range or turning off the breaker for a couple minutes. Restart and see if that helps. If not you will need to replace the control.
The part number for this unit is 4453614 and runs just over $300.00
Apr 25, 2010 | Whirlpool GR465LXLS Electric Kitchen Range
Unusable new oven after ice storm
HI. the storm has caused an electrical surge that traveled through the home wiring system and, the Oven control received the hit in this case. it is damaged at this point, and it should be replaced asap, if possible. this code represents a major control breakdown. the board is ruined.
replace it asap.
Dec 17, 2008 | Whirlpool RF380LXPS Electric Kitchen Range
Kenmore oven/range
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 28, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Range displays e2 f1 and beeps every so often
F1 E2
Oct 26, 2008 | Whirlpool GS460 Gas Kitchen Range
"F1" error code on Magic Chef gas range Model 3488XRA
I'm not sure how to fix this, but my mom's magic chef has been doing this for close to 10 years. She's managed it by plugging a power strip into the wall outlet and plugging the stove into the power strip. Then she can just turn on the strip when she needs to use the oven. It only requires moving the unit once, and is easy for the technological/ home repair novice.
Sep 18, 2008 | Kitchen Ranges
F1 Error Code on MayTag range
migs, on a Maytag the F1 indicates there is a problem with the touch-pad or control itself. Usually, it's the touch pad. Try killing the power to the range and remove the touch pad ribbon from the control board. Clean it with an eraser. Power back up and see if the error comes back. If it does, remove the ribbon cable again and power up with-out it attached. If the same error still returns, then I would suspect the control board itself. Catriver..post back.
Jun 05, 2007 | Maytag MER5875QA Electric Kitchen Range
Kenmore 46123 Stainless Steel Electric Kitchen Range Logo
1,783 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
