Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Dark line across bottom of screen
I have a Sharp Aquos 42in LCD TV. After being on for an hour or so a dark band appears at the bottom of the screen. The band takes up about the bottom quater of the screen, is darkest in the left corner and lightens to the right. I have read suggestions about the closed captioning, but this is not the problem because I have that turned off. When I play with the remote to try and fix the problem the words that come on the screen in this area seem to burn in for a few seconds and slowly face into the darkened spot. The only remedy is to turn the set off for at least 20 min. Any help is greatly appriciated.
Thanks, James
  • 1 more comment
  • murphy48 Dec 23, 2008
    I also have a faint horizontal line going right across and don't know what it is or how to sort it. Please help.
  • BummedinMA Jan 06, 2009
    I just got a thin dark line going across the bottom of the screen about 6" from the bottom. Line appears regardless of the source. Our TV is about 18 months old.
  • Anonymous Jan 07, 2009
    I had a repair guy look at my TV. He said there is a pannel going out so the TV has to be replaced because sharp wont replace the pannels......now all I have to do is deal with sharp.
otacon
  • 1944 Answers
SOURCE: Sharp Aquos LCD TV 52"
Does your cable company support CC?
Posted on Apr 08, 2008
SOURCE: screen problem
it is clearly a case of "you got ripped off" just like me
Posted on Feb 25, 2009
gymhasafit
  • 31 Answers
SOURCE: Cable/Analog Icon on screen
Usually the DISPLAY Button on your TV remote will toggle through several different functions: 1 sec, 5 sec, Always on..... Press button until display on TV is off. Or see if there is an ON SCREEN DISPLAY portion in the TV Menu and turn it to off if you have not checked that already.
Posted on Apr 28, 2009
  • 8 Answers
SOURCE: Turned on set....screen all black except a dark blue rectangle in center which reads:Failed to receive broadcast [E202]
That message is presented when a selected digital channel is too weak to decode. Let us hope that something was accidentally changed:
Is the channel legitimate?
Is the antenna/cable still connected (to the Digital input)?
Go into menu - setup - channel setup. Is the selection of either cable or air channels correct for your situation?
Use menu - setup - Antenna Setup-DIGITAL to examine the signal strength. Is there nothing at all, or is it just a question of strength?
Odds favor a change in channel setup that you would not have made intentionally, or a simple physical problem (input cable, etc.). Start from scratch, and check the settings and connections you originally made. Hopefully it will be simple and cheap!
Posted on May 22, 2009
  • 161 Answers
SOURCE: green pixels on dark picture areas on Sharp Aquos.
This may help, but at your own peril.
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Posted on Jan 15, 2010
Vizio VW46L10 TV has a 6 inch dark band across the top of the picture.
Change input device to some other like a DVD player.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, call in a qualified service technician.
Aug 02, 2012 | Televison & Video
My zenith lcd tv has horizontal black lines whih form a band about 3 inches wide across the screen, sometimes the band looks more like a dark shadow than lines other times the right side of the screen...
This is either 1 of 2 things, first it could be faulty panel tabs , in this case, there is nothing you can do and is unrepairable....2) you could take the back off the tv and you will see 2 ribbons going from your t-con board to the panel tabs (top center of tv) remove them carefully and reseat them. This is a common problem. Tv repair tech 15 years! Best of luck.
Dec 05, 2017 | Zenith Televison & Video
Dark lines on Sharp Aquos 42" screen.
if the unit is stll under warrenty it would be best to take it back, it does sound like that it is the lcd that is faulty, or contact Sharp to see if the can repair it for you
Thanks
Oct 19, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Screen problem
Feb 25, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LCD 42" picture to dark
No, just go into your setup, and adjust the darkness. Should work for you.
Feb 21, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Faint horizontal lines from top to bottom after an hour of use...
I can tell you right off the bat that is a service issue you will have to take up with sharp. Contact their operational support, they have a quick turnaround with things like that. When you call, they will most likely ask you to take digital pictures of these black lines and have you e-mail the pics to them.
Dec 08, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Dark lines appearing across my lcd tv
This is symptom of LCD Faulty. Please note down cost of LCD is much high. In my suggestion
you change or purchase new TV
Nov 12, 2008 | Televison & Video
Sharp 42" flat screen LCD T.V.
This could be 1 of three things! 1-main lcd panel
2-y sustain module
3-z sustain module
This is something you cannot do yourself my friend.
Feb 22, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
267 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
