Question about Jensen VM9020TS Car DVD Player
VM9020TS Doesn't save presets on XM/Can't read full titles in menu
I can't save any presets on the Radio or XM. Also, the banner spaces where you read sports scores and titles on XM only shows about 8 spaces of info even though there is room for many more. Any help appreciated.
How do i fix 2014 nissan altima radio song and title display
What do you mean by "fix" the display, is it not showing it? If so- my Nissan Altima has not been displaying Sirius XM Title and Artist for months. After much searching of the internet, I finally found an answer that worked! Just be sure to write down your radio/sirius presets before you reset the radio - it'll clear them all (and the time). The answer is here- http://incodesystems.com/Troubleshoot/Cars/RadioInitialize.htm
Dec 04, 2013 | Cars & Trucks
2012 toyota highlander sirius radio constantly loss of signal
I have similar issue. Signal easily lost whenever there isn't a truly clear path to sky. My old cheapie XM radio add-on was MUCH better. I'm taking this back to my dealer tomorrow for other issues with the "top of the line" DVD/NAV/XM system. Such as it won't read the data on most CD's and display names of tracks (maybe 1 CD will display out of 10); and the way the radio truncates the Sirius/XM titles, etc. to much less than the full available screen (my cheapie add on did a better job). For $2,000+ bucks this is a very disappointing audio/GPS system. Sound is mediocre as well. This must be a huge profit center for Toyota -- cheap components + high price = $$$ for them.
Jul 24, 2012 | Audio Players & Recorders
When my receiver is plugged into my boom box, I get a display reading "check cradle for power"
It's not receiving enough power from the boombox so the voltage drops too low for the receiver to function properly. Check the cradle connector for bent or pressed pins and the power source of the box for proper functioning: measure the voltage it delivers and the status of its components, especially the filtering capacitors.
Jul 04, 2011 | Delphi Roady XT XM Radio Receiver
Receiver will not remember preset channels anymore
Try a factory reset
Menu -> Factory Defaults
If those don't work power of your radio and press:
2-1-1 + Push down Tuning Wheel
This will erase all of your presets.
Dec 27, 2010 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
I have a Kenwood ddx6019 with XM satellite radio. recently, I entered a manual channel change and lost all reception. A banner reads LOADING LOADING across the bottom of the screen. Any ideas on how to...
I have a Kenwood ddx6019 with XM satellite radio and sirius. i want to know how do i turn on the xm so i can get live traffic update and my garmin gps unit and weather. and were to i find the mx radio id for xm. i found it for sirius
Nov 01, 2010 | Kenwood DDX-6019 Car DVD Player
Delphi skyfi2 Xm Radio Receiver car connection
Yes, you can buy an FM Direct adapter that will allow you to transmit directly to your car FM tuner, but if you have an older SkyFi2, the Fm transmitter is so strong, you can sit the radio on the floor and tune your car radio to your preset XM channel, like 107.1 FM and it will work great. Go into "Menu" and pick a channel that's not used locally.
Jul 12, 2010 | Delphi SKYFi2 SA10101 XM Radio Receiver
How do I access the songs that are in the memory of my Roady XT?
I doesn't save the songs, only the song title information. Go to MENU and you can see there is a selection to it to show the 'memory' listing -again, it is only the channel, artist and title info to remind you the name so you can buy it. some also have the tunealert feature so that the radio beeps when your favorite is on another channel.
Aug 20, 2009 | Delphi Roady XT XM Radio Receiver
XM Direct 2
On the adapter cable if there is a separate cable for power connect the positive directly to battery power as opposed to ignition. The memory resides on the xmdirect2 module not on the head unit.
Oct 04, 2008 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
Cannot get to tune one station to next station
Does the radio have a full subscription? Next, check the "Preset/Direct" button and push it until "direct" is lit up. Then you can directly enter the channel number. Also, you can go into the MENU and set what channels to skip and jump to. My guess is that you bumped the "Preset/Direct" button and your radio is in "PRESET A or B or C" - you need direct. Try that first, than get back to me - okay? BTW, I'm assuming you're talking about an XM satellite radio like the one in the photo?
Oct 28, 2007 | Delphi Roady SA10035 XM Radio Receiver
Jensen VM9020TS Car DVD Player Logo
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
