Question about JVC Cybercam GR-DVL520A Mini DV Digital Camcorder
Camcorder eating tape
Every time I put a tape in I get an error code and am told to remove battery. The tape is eaten each time I try so I can't use it at all. Any suggestions?
    President:
  • 3,130 Answers
There is a small nylon gear assembly on the bottom of the chassis that needs to be replaced and is not an easy repair for the skilled tech as the entire camcorder has to be disassembled. Good Luck
Posted on Mar 30, 2007
SOURCE:
Canon charge light blinks 7 times
If your Sony camcorder displays a tape transport or mechanical error code always try resetting the camcorder. This is done by removing the battery or ac power, wait 10 seconds, reapply the battery or ac power and try again. If it still goes into error try another tape. The camcorder will not always display an exact error code. Sometimes you may see an error message such as, "Reinsert the cassette", on the LCD screen. This is the camcorders way of saying, "Take the tape out and try again." Try reloading the same tape as well as a new tape. If the camcorder is still going into error this means it is time to send it in for service or repair.
The camcorder may also sometimes display a "Reattach Power Source." This is the camcorders way of saying,"Try resetting my system,so I can try again." Many people mistaken this error and think they have a problem with the battery or ac adapter. This is not true and has nothing to do with your battery or ac adapter. Reset the camcorder by removing the battery or ac power, wait 10 second, reapply the battery or ac power. If the error reappears the unit needs to be serviced or repaired.
Jan 23, 2013 | Canon VIXIA Video Cameras
I have a sony dig 8 trv340 and am receiving an error code of c31:42 what does this mean?
In DCRTRV430 Camcorder, the C:31:42 error message is a Self diagnostic display. This message can be clearly identified by the help of a Sony Authorized service technician. Each of these codes indicates the symptoms and resolutions of the Camcorder. In C:31:42, the issue is with the tape and the tape mechanism.
I suggest that you remove and reinsert the tape to check if it helps. You may also try inserting new tapes in the Camcorder. Please remove the battery and/or power cable, connect, and perform operations from the beginning. You may also try resetting the Camcorder back to factory default after removing the tape.
To Reset the Camcorder, perform the steps below:
? Please open the LCD screen to locate the RESET button.
? To reset the Camcorder, press the RESET button using a sharp-pointed object.
? Please make sure that the Camcorder is turned on while pressing the reset button.
Also, try turning off the Camcorder and remove the battery pack. Then move the 'Power Switch' of the Camcorder to the ON position
for 1 minute. After about 1 minute, move the 'Power Switch' to the OFF position.
Now reinsert the battery, turn on the Camcorder and check whether it is working fine.
Thanks.
KenSolutions
FixYa
Oct 23, 2010 | Sony Video Cameras
Camcorder is eating tapes (or tapes are getting stuck)
Hi ; this problem is a miss alignement off your tapthern and you may replace the pinch roler assy
and a good head cleen up
and that should solved the problem garanty
hope thats will help have a nice day
Mar 04, 2010 | Canon ZR10 Mini DV Digital Camcorder
Camcorder eating tapes
Your problem is a plastic belt that drives take up and supply reel. Most likely, you will not be able to relace it by yourself.
Dec 02, 2009 | JVC GR-AXM17U Camcorder
Eo1 comes on says take out battery and put back in should work but donot need to use camera now.
JVC camcorders are known for having safeguard problems.
mine was locked into safeguard the second time i tried to use it at 1 month old. i had it repaired and it came back eating the tapes. eating the tapes was blamed on old, or improper tapes. they were all brand new never used JVC tapes.
it came back from service locked in safeguard mode.
i got it back the fourth time and it worked for a few days, then went back into safeguard mode.
the shop had it more than i did during the first year.
when it locked the next time after the warranty was out, i was told the estimate for repairs was $300.00.
unless you want to try to risk taking it apart, the only 2 options you have is to send it in for repairs which is not cheap, or throw it away and never buy anything from JVC again.
i chose option 2.
Aug 27, 2009 | JVC Everio GZ-MG130 Camcorder
Code: 31:23....please reinsert tape. everytime i switch it on.
dear
u need to rate me for that ..ok dude....
actually this error is related to s reel i.e, the supply reel of the camcorder and some time when we insert a new tape in camcorder it start giving the error because the amount of tension is more in new tapes as compared to the old ones (used one) . . try to use the old tape u would nt have any problem .
but with new tape u will have these kinds of problem some times , to solve this problem for new tape u need to take the camcorder to near by service center of sony .nd they will align the tape path of your camcorder .
Jun 22, 2009 | Sony Handycam DCR-TRV265E Digital...
Eats tapes!!
Try using a DV tape cleaner to clean the tape heads first and see if that makes a difference.
Sep 26, 2008 | Canon ZR10 Mini DV Digital Camcorder
Remove Cassette Error
The problem that you are experiencing with your Canon GL2 camcorder is a common problem on your camcorder. Check out this video for more information.
Sincerely,
Sheryl Bahr
Nov 13, 2007 | Canon GL2 Mini DV Digital Camcorder
DCR TRV320
That is the "LOAD" error code.
However, to service the C:31 code, Sony recommends you do the following:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Oct 25, 2007 | Sony Handycam DCR-TRV320 Digital Camcorder
Optura Pi is eating tapes
hi from what i understand by "eat" is that the coil is popped out what it means is that the coil leader is misplaced and letting it to run free out of place this can be fixed by you if you will find what had gone wrong in that path (broken pin, cog etc...) and glue it back or fix the missing element in place good luck
Apr 27, 2006 | Canon Optura Pi Mini DV Digital Camcorder
JVC Cybercam GR-DVL520A Mini DV Digital Camcorder Logo
158 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Thomas F. Schneider
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
