Question about Sharp (RLMPF0014CEZZ) Projector Lamp for XV-H30U, XV-H30U, XV-H30
Lamp timer reset sharp xvh3ou
So old cant find procedure.
3 Suggested Answers
SOURCE: Reset Lamp sequence for Sharp XGE-3500U
http://www.unitedvisual.com/Pdf/SharpxgeCounter_Reset.pdf
Posted on Apr 12, 2008
  • 3 Answers
Hello everyone,
May you tell me how much it cost to buy Sharp XG3000U?
Thank you for all of your time.
Reset sharp xv-100 timer
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Mar 05, 2012 | Sharp (CLMPF0053DE03) Projector Lamp for...
I replaced the lamp on my sharp dt100 projector and now it will not turn on
Have reset the lamp hours after installing the new lamp? If, not the projector has treated the new lamp as old lamp & refusing to light further. So, reset the lamp hours to zero. To reset the lamp timer do as follows. Plug the power cord into the AC socket of the projector. Switch ON the power of the socket. (not projector) While pressing simultaneously MENU/HELP, ENTER & DOWN (button near MENU/HELP) on the projector, press STANDBY/ON on the projector. "LAMP 000H" is displayed, indicating that the lamp timer is reset. If this does not correct your problem then the problem lies in other area. Let me know so that further I can provide you solution. Above things are preliminary.
Aug 06, 2011 | Sharp Office Equipment & Supplies
I have a sharp xg-c55x. I put a brand new lamp. It worked once for about 20mins. Since then it starts warming up & then it turns off. How do i fix or reset? Thank you
Have reset the lamp hours after installing the new lamp? If, not the projector has treated the new lamp as old lamp & refusing to light further. So, reset the lamp hours to zero. To reset the lamp timer do as follows. Plug the power cord into the AC socket of the projector. Switch ON the power of the socket. (not projector) While pressing simultaneously INPUT, ENTER & UNDO on the projector, press ON on the projector. "LAMP 100%" is displayed, indicating that the lamp timer is reset.
Jul 07, 2011 | Sharp XG-C55X Multimedia Projector
THE LAMP DOES NOT COME ON AND THE LAMP LIGHT BLINKS
New projector lamp time! you may have found that a symbol of a lamp comes on in the bottom corner of the picture after you turn it on for a short time. perhaps the lamp light has been flashing too. But yourself a lamp and be sure to follow the instructions that come with the lamp on resetting the timer- you must do this in order to get it to fire up again. Tip for the Sharps- Must replace it with the AC cord disconnected. (reconnecting the AC cord is part of the reset procedure)
Happy lamp shopping!
Jan 11, 2010 | Sharp (BQC-PGC20X//1) Projector Lamp for...
I bought a new lamp for my sharp XR-11XC. Standaby/on light is flashing and lamp light is red. TI tried two new lamp. all has the same problem. Need help, Thanks!!!
have you reset the lamp timer yet? can't remember the procedure for that one exactly often hold power and down and left arrows whilst plugging in power. Check info on instructions that came with your new lamp.
Nov 18, 2009 | Sharp Projector lamp Projector Lamp
I have an old video projector, a SHARP XG-C40XE, and I was told that there is no immediate need for a replacement lamp after 2000 hours. Instead of changing the lamp, you can simply reset the built in...
I would replace the Lamp. Too many times I have seen people reset the Lamp Timer and when the Lamp explodes, it also causes the Ballast to fail. At that point it may not be repairable due to parts not being available or the cost of them being through the roof.
Contact Sharps Customer Service and see if they could hook you up with a Lamp and the Lamp Timer Reset info.
That is my recommendation.
Skyassoc
Sep 18, 2009 | Televison & Video
Changed bulb on panasonic PT-52LCX66-k and cant reset timer.
I can help you reset the lamp timer for your Panasonic PT-52LCX66 Projection HDTV.
The buttons used are the TV's volume down and the remote's number 0.
Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Apr 11, 2009 | Panasonic PT-52LCX66 Projection Television
Lamb will not reset
Reset The Lamp Timer.
While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
Sinista
Mar 18, 2008 | Sharp Notevision PG-B10S Multimedia...
62 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
