Dtv converter box - low sound
I purchased a Magnavox # E 175216 converter box from Walmart. After installing it the picture was fine, but the sound volumn was way down. Where I used to listed to the tv at say 9 or 10 now I need to crank it to at least 25 or more. Is this because I bought a "cheap" box or is this a common problem with converter boxes. Is there a way to correct this?
  • 3 more comments
  • rag1306 Jan 05, 2009
    I have a Zenith converter box and the same thing happened after hook up--extremely low volume. I too have to really crank it up. Another thing I found is that if I record on a VCR and play the tape back on another set, the sound is almost nil.
  • Anonymous Mar 14, 2009
    I just hooked up my magnavox from Walmart.  Not only is the sound low, there is static in the audio.  What is up with that?
  • Anonymous Apr 13, 2009
    Two Different con.boxes, same result,i try contacting Fcc ,they dont have an all inclusive complaint box! So Stick DTV.Give me my Analog Back.
  • Anonymous Apr 27, 2009
    always having to adjust the sound...it is either too loud or too low
  • Anonymous May 10, 2009
    I have purchased 3 different brands of Digital Converter boxes and have the same problem on all 3 units that the volume is way too low. When I record on a VCR tape, the volume on the TV has to be all the way up to maximum, and I have to sit very close to the TV to hear it. When I stop the tape, the TV blares the sound so loud it startles everyone in the house. It's an awful problem. Note: One of the Converter boxe is a PLUS model which is suppsed to have a stronger audio/video reception, but noooo...
    I heard that 3 RCA cable connections would resolve this problem (instead of a coax cable connection) but it didn't. I recorded some very special programs that I wanted to keep, but they were useless and disappointing. Can hardly hear them. BTW: My hook ups are all correct.
    Sure wish I could resolve it.
We have a cottage up in Maine and we purchased a Magnavox converter digital box, We cannot get the menu to come up and we cannot receive any channels.
Posted on Jun 22, 2009
  • 3 Answers
I have a Zenith model , Actually TWO. BOTH of them are the same way. It makes No difference if the RF modulator output, or the Line output is used. The volume needs to be around 90% up on the TV to hear decent and this is with the internal volume of the converter turned all the way up! I got sick of this so I did some searching and found a kit that solved my problem. I actually built a Audio line level booster which actually works quite nice. The model is Velleman-Kit Model # K2572. About 17$ before shipping. This solution is if you are experienced in Electronics and want to build a board kit. I had to do as recommened and change the two input resistors to 100k ohm (Described in note in kit). You will also need a power supply to power it; a 10-30vdc transformer pack supply will work. I made mine. I know this is if you are a hobbiest which you may not be... so.... If you want to buy an already built product to fix the problem you can buy one on ebay for about 50$ ( Model TCC TC-780LC ) before shipping. Do a search in ebay for that model #. I can not make any claims wether it works because I have not tried it, but it does claim to do the job and it looks like it would. Good luck!
Posted on Jul 11, 2009
Tb110mw9 and tv remote
The Magnavox DTV converter requires a dedicated remote
Jun 25, 2013 | Televison & Video
Radio Schack converter doesn't program Ch: 25 like Magnavox!
Returned product to dealer. That fixed my proble.
Thanks...
Aug 19, 2009 | Philips Magnavox 20MT133S 20" TV
Program Magnavox Converter Box into my Directv Remote
you do not need a converter box with any cable or satellite tv.
Jun 12, 2009 | RCA 3-Device Universal Remote
I work for Phillips/Magnavox tech support. If the volume is low like that unfortunately, there isn't anything you can do about it. Coby makes a converter box as well as Memorex, and their boxes had the same problems. The box should be returned to the store for an exchange, or sent in for warranty repair/exchange. There is nothing you can do to fix that problem.
I hope this information allows you to make an informed decision as to how to proceed.
Thank you for visiting FixYa.
May 30, 2009 | Philips Magnavox M61117 (DBM61117)
DTV Cnverter Box
Your tv needs to be set on channel 3 or 4 depending on which the box uses, then when you turn the box on you will go through a semi sutomated setup, and thats it
Jan 25, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Added dtv converter box and sound volumn drops!
some of those converter boxes have their own volume inside the box also. If your remote control for the converter box has its own volume control, try turning it up and then turn up the TV volume control use the TV remote. If this works you should see a volume indication on the screen of the TV for each of the attempts.
Jan 04, 2018 | Televison & Video
Analog Pass-Through DTV Converter Box with Remote Control (3 digit code for the Remote Control
i can not get my tv to pick up a signal.I know my antena works i have tried it on other tvs.Has anyone else had this problem or know how to fix it?
Aug 04, 2008 | Philips Magnavox 20MT133S 20" TV
Televison & Video Logo
1,206 people viewed this question
Top Televison & Video Experts
