Question about MSI P4MAM2-V Motherboard
My mother board is on but no display. blank screen
  • Anonymous Mar 28, 2009
    i did check the cable and it still is saying no signal. I installed a video card from a working gateway tower of mine and is still doing the same thing
  • Roberta Smith
    Roberta Smith May 11, 2010
    onboard video card or pci video card ?
    Problem Solver:
  • 7 Answers
Check monitor signal cable
Posted on Dec 19, 2008
Samsung lcd model la32s81b sound is good .Fault is blank screen with no display or if u want white screen.
It could be either or. More then likely it is your mother board, which is the brains of your t.v.
Feb 04, 2015 | Samsung Televison & Video
Screen bis Blank
1) Try an external monitor to see if it displays anything. If it does, the backlight in your LCD screen died. You will need to replace the LCD screen.
2) If it doesn't display on the external monitor, then the motherboard is bad.
Jan 10, 2014 | Sahara AL-096 Laptop
Come on screen but at that time when I press the menu all menu function come on screen but pc display not come. I change display cable & video board also but problem not solve.So, Pls. guide me. Thanks.
If again again display problem create then i suggest you change mother board and purchase own device supported mother board. If change mother board then display problem solved, but one step you change RAM may be your RAM device week and damage. So you first of all change RAM then finally change motherboard.
Thanks...
Oct 09, 2013 | LG 700M 17" CRT Monitor
Screen Blank Acer aspire as5052an wxmi
your system is resolution is out please set resolution for other lcd 800/600 and solve the problem
May 08, 2012 | Acer Computers & Internet
Wordtank IDF-4000. The screen is blank. Can it be repaired ?
This can be failure of the display driver, failure of the power supply to the display , failure inthe connecction flexible cord to the display or a fault in the mother board.
All these can be confirmed only with a detailed check on the main board.
Mar 19, 2011 | Canon Computers & Internet
Display window has a light but no information
Possible failure of the mother board/ power supply section. You will need to remove and reconnect the lines from the mother board to the display and sections.
If there is no result even after this with the display staying blank then the board can be faulty.
Nov 19, 2010 | HP LaserJet 2420 Printer
I have a Compaq nc6000 that would not boot up. I
Sounds like your display panel is bad or it's another symptom of a mother board flex problem at the Maxim chip
May 22, 2010 | HP Compaq nc6000 Notebook
Moniter Screen Blank when my PC start....Giga byte 8S661FXME-RZ Mother board
try to remove the motherboard from the casing and see it if the have some capacitors or any circuit distroy. use other mother board for testing chek your hardware one by one maybe some of your hardware devices damages.
Jan 01, 2009 | Computers & Internet
Lcd screen
this can be a few different problems
1) one the simplest is a loose video cable beween the mother board and the LCD.
2) bad inverter or back light if in a split system mostly on some wide screen models.
3) a bad display
May 15, 2008 | Toshiba Satellite P100 Notebook
MSI P4MAM2-V Motherboard Logo
102 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
