Question about Intel Motherboard
Help please am i need help i just but a new gigabyte board. done the placement on the casing. but when i fix a 1.g ra the syatem restart by it self and also i fix a 256 it work but it works for some time and stop and i need to deliver this machine latest by tomorrow
    President:
  • 2,961 Answers
Check that you have the memory and processor timings right, eg both running at pc3200 or 266, within the bios settings. make sure the the processor isnt overclocked, so you may need to reset the cmos jumpers and start again, also the board may only run on two memory sticks of the same size or make and compatable and also use the correct slots if it has 3 of them as they have to be fitted into specific slots to work correctly.
Posted on Mar 30, 2007
Hi i am using 8i845gvm-rz gigabyte mother board, and i have currently installed windows 7, but my graphics is not working well. where could i find my graphics driver ? my ram is 1gb. my graphics card is...
If you cannot find the drivers you need on the Gigabyte site, there's a good chance that due to the age of the motherboard there are no Win 7 drivers. In that case, you can either upgrade to a different motherboard or install a new video card that does come with the correct drivers.
Sep 29, 2011 | Gigabyte GA-8I845GVM-RZ Motherboard
Changed MSI MB to Gigabyte. I get bios and even the windows recovery window but every time it just restarts and wants to do a start up and repair that always fails. Help.
http://www.gigabyte.us/support-downloads/download-center.aspx
This is Gigabytes link to downloads. Did you uninstall software from MSI? Try to shut down, unplug system, and restart. You might want to consider a "system restore" back to when it did work. Did it work at all with new board?
Mar 21, 2011 | Gigabyte MB GIGABYTE GA-MA74GM-S2H AMD740G...
Installed new motherboard (Gigabyte GA-G41M-ES2L), I cannot figure out where to plug the blue & white wire coming from the main power button on the front of the computer on the motherboard. Please...
hello tami_hennacy
unfortunately the wiring color for computer cases are not standard. so blue and white does not mean much. you need to look at the connection on the tip of the wire to see if it is labeled so you can locate the corresponding connection point on the mother board. Gigabyte motherboards have a very good step by step discretion of all connections.
if it is not labeled then you need to oped the case front panel and see what the other end of this pair of wires is connected to.
hopefully this has helped
good luck
Dec 30, 2010 | Gigabyte GA-G41M-ES2L Motherboard
Got an Alesis RA-150 off eBay to replace my RA-100, which worked great but I wanted more power. Was travelling when it arrived and my time to respond back to Seller has expired. With right channel set to...
it may be an open input side coupling capacitor in the feedback circuit around the power amp. if the amp has a limiter in it it may be stuck. here is the service manual, in any case.
http://forum.vegalab.ru/attachment.php?attachmentid=75690&d=1265371278
Dec 03, 2010 | Alesis RA-150 Amplifier
I have a gigabyte n650SLI-DS4L and c2q q830, Memory 2gig kingston and a Sparkle GeForce 9600 GT Problem: System restarts after 5-7 minutes of playing NBA 2k11, and other games. pls Help!
Motherboards usually will automatically shut down to prevent damage being done to the system if there is any, such as high temperature. In your case, it restarts when you are playing games, which take more power to process than other things. It seems like that your graphics adapter, CPU or something else might be overheating. You might need to consider upgrading some parts for better cool if overheating is the case.
Nov 16, 2010 | Gigabyte GA-N650SLI-DS4L Core 2 Quad...
Why can not I connect to the Dual chanel memory in the GA-K8NF-9
Supports Dual Channel DDR400 memory architecture. And up to 3 gb support in winxp32 bit. 4 gb support in winxp64 bit.
Dec 11, 2009 | Gigabyte GA-K8NF-9 (890552602964)...
My system is restarting
u just open the system in safe mode one time and scan syatem through an antiviruse.........if it helps then it ok and if not then u have to format ur pc
Dec 11, 2008 | Intel Biostar IDEQ200S P4 Barebone System...
Window programme got currupt
try to reformat ur hard drive and install a new os (windows)
May 27, 2008 | Intel Motherboard
Wiring
Click the link listed below that will take you Gigabyte. Download the manual described as, (English-Rev. 1103, format pdf, size 7.47Mb). The case leds placement is on pg. 25. USB's on pg. 27. Everything you need to setup this Ultra motherboard is here.
http://www.giga-byte.com/Support/Motherboard/Manual_Model.aspx?ProductID=1621
The only thing not mentioned for connecting the case led wires to the motherboard is the wire colors. Which is, pos+ & which are neg -. Usually white colored & black colors are negetive -. Other colors like Green, Blue & red are pos+.
This should make it much easyer to install.
please vote...
Feb 13, 2008 | Mercury P4VM800M7 Motherboard
Intel Motherboard Logo
23 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
