Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Sony kp 51ws510 convergence problem
HI,
My Sony KP 51WS510 had a convergence problem, all 3 colors were mis-positioned, and I had replaced 2 convergence ICs, but the problem still there, I was wondering maybe the convergence board needs to be replaced, any idea where can I buy the convergence board ?
Thanks
Steven
  • 1 more comment
  • kcsrmd1 Dec 21, 2008
    I have same convergence problem, can you help me how to change Convergence ICs, is it difficult to change convergence ICs and how much it cost for parts. Thanks and appeciate your comment.
  • Anonymous Jan 19, 2009
    i have the same convergence problems with my sony kp51ws510 rear projection tv...has anyone contacted sony to see why there was no recall on this poorly manufactured or badly design tv?
  • JIM RICK Apr 08, 2009
    I have replaced the two convergence ic's . On one of them i seem to have pulled the copper from the hole as one pin will not solder to the circuit board. Anyway, i tried to fill it up and hope for the best.
    turn on the set and picture is fine but after a few minutes red shadow lines. I checked 5 yellow 3.25 amp pico fuses under the fins and are fine. How do I find the resistors or any other fuse that feed the convergence?
    Please!
    Jim
  • Sony Master
  • 3,459 Answers
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and shouldsony kp 51ws510 convergence problem - 2c07611.pngd. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
578ba6c.jpgTV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Apr 18, 2009
  • 1 more comment
  • Edward
    Edward Dec 11, 2009
    Let us know if the solution above helped.
  • Edward
    Edward Dec 21, 2009
    Just checking back to see if you fixed your set. Keep everyone posted.
  • Edward
    Edward Apr 16, 2011
    Glad it worked
  • Sony Master
  • 5,138 Answers
In order to aline convergence you have to get into Service MENU for tech only.Codes to Enter Service menu. Also have you ck the pico fuses that feed the ICs they look like resistors but are not green or yellow 6amp/ 7amp pico fuses if one or more is open you can not control convergence settings. If the picos are OK ,then you need to get into service menu to set convergence. /will have to find SMC for sony will let you know asap!
Posted on Dec 28, 2008
2 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: Sony KP 51WS510 convergence problem
Please check pico fuses in D board and confirm +22 & -22 volt supply to convergence ICs.
Fuse numbers are as follows...
PS8001, PS8002, PS8003, PS8004, PS8005, PS8006
Posted on Dec 21, 2008
The borders of objects in the picture have a black border, it makes it look like the image has been put into a cartoon filter in photoshop
Tv have colors lines like R,G,B mis alignments.Picture have shadow or tv have 3D picture look alike?Yes,this tv the convergence board it is dead,convergence board 2 STK convergence ICS and some or all of it resistors must be replace to repair the convergnce picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 06, 2011 | Sony KP-51WS510 51" Rear Projection...
I have a Sony KP-51ws510 that has wavey or fuzzy corners opposite of one another?
The problems ur tv having it is call a convergence problems,it dead.Very common problems,for old DLP tvs design.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than tv covergence board is dead.Tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 08, 2011 | Sony KP-51WS510 51" Rear Projection...
Hi.all the color are not alined
Tv have a problems known as a convergence problems,it dead.The tv have colors R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced on the tv convergence board to solved the tv picture convergence problems.
Oct 13, 2010 | Sony KP-65WS500 65" Rear Projection...
Sony KP-51WS510 picture swirls in the corners and is doubled
The tv have a problems known as a convergence problems,it dead.The tv have any colors lines R,G.B mis alignment,picture have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 15, 2010 | Sony KP-51WS510 51" Rear Projection...
My tv has lots of red and green. Faces are shadowed by a red outline. It occurs on all channels and dvd.
If problem does not fix by flash focus/ convergence adjustment in Menu then replace convergence output ICs on D board of tv that sounds defective and causing problem.
Comvergence output ICs replacement requires soldering work with proper tools and electronics knowledge/ experience, call local tech if you have no experience.
Jul 16, 2010 | Sony KP-51WS510 51" Rear Projection...
Color out of SYNC, (red color not align)
The tv have a problems known as a convergence problems,it dead.Any colors R,G,B are out of alignment.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 19, 2010 | Sony KP-51WS510 51" Rear Projection...
Dec 21, 2008 | Sony KP-51WS510 51" Rear Projection...
How to change convergence ICs in Sony KP-57WS510 TV?
Replace Both STKs convergence ICs big black ics with number on them STK392-560.Parts 1-800-223-3205
Dec 20, 2008 | Sony KP-51WS510 51" Rear Projection...
Same problem as achilles_08...different colors on screen
This is a convergence problem that can be as simple as poor solder connections at the convergence ICs or defective ICs. Try esoldering the ICs first. If that fails to resolve it, replace them. These will be large black ICs attached to a heat sink and marked STKxxx.
Dan
Sep 07, 2008 | Sony KP-51WS510 51" Rear Projection...
Color issues
This is a convergence problem that can be as simple as poor solder connections at the convergence ICs to defective ICs. Can you solder? If so, let me know and I'll provide additional instructions.
Dan
Sep 05, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
7,889 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
