Question about HP Media Center m7060n PC Desktop
Can not record internal sounds on my pc
I am trying to record the music off of a m-peg file using nero and/or roxio recording programs, when i bouble click my speaker icon, get the channel inputs and open property i only have a playback buttom. there is no record buttom to select so i can't record. what do i do?
    Genius:
  • 1,011 Answers
Try other software i think the nero cannot record mpeg files or may be the files not supported. so the record is disable
Posted on Dec 19, 2008
I want to put my LPs to an external hard drive, what do i have to do?
Plug your turn table into your input sound card (line in on your sound card) Use a program like Nero Media Player, or any digital recording program ( Sound Blaster or Wave Studio) Tell it to save the file as mp3, that simple. If you are an experienced Computer user and have a Wave Recording program such as Audacity [free] or Adobe Audition [$$$] you can do this: 1. Your record player must have a LINE OUT.....usually go from your stereo receiver [You can get turntables with internal Line outputs...this is what I have...via ebay] 2. Output from Receiver [turntable] must be the small [headphone like plug...used to be called Sony Plug...now it's the 3/32nd I believe.... 3. plug this into the line in of the sound card....it's the arrow that points INTO the little hole. Now the sound card can read the signal.....but wait...! 4. You must enable the little box in the sound card properties called "Line IN"....put the check mark there. 5. How to get to the Properties? Bottom right of screen there should be a speaker ICON....double click that. Then go to File....Properties....record.....then look for the LINE IN....check it. If you don't see it. Then you have to ask someone in person to help you. 6. If you get it working. Great! 7 Now open a recording program and press record....then play the record. You should see a wave file going across the screen. Then save it as an MP3 file. 8. Advanced tip: if you record at a rate of 59594 instead of 44100 then you can play the 33 1/3 speed at 45 RPM and save about 30% time in recording from a record. Then convert back to 44100 and it will be normal speed. I do this on ALL my LP to MP3 recordings... The above is for more advance type computer users.
Sep 02, 2009 | Roxio Easy VHS to DVD for PC
Can't hear sound on Windows Mediaplayer from DVD I recorded
I've been pondering this one for a day or so - at least two possibilities:
1) There is a mute/audio-off hotbutton inside Windows Media Player itself - click on it and see if the audio works. Alternatively, you can try playing a music file in Windows Media Player to see if THAT file has sound.
2) You need a better Codec - the free version of the K-Lite Codec has limited audio support. There are no easy answers to this problem. I frequently use my computer for converting VHS's to DVD, so I finally plunked down the $50 to purchase Nero 9 and all of its codecs. Before that, however, I used VLC Media Player (free) - it has DVD/VOB audio support.
As a side note, if you wanted to use your computer to convert the VHS's to DVD, you would need a plain-old VCR, a red/white/yellow cable, a DVD burner, and a product called the Dazzle DVD Recorder from Pinnacle. You can hook the VCR straight to your computer and burn away. To get the best experience however, I would also get a program like Nero, Roxio, etc. to do the actual DVD burning (although the Dazzle's native software is perfectly capable of doing the job).
-Tha Mp3 Doctor
Feb 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Is it possible to record from an exsternal device, ie cd burner to roxio on my computer... via rc cable out to mini plug in?
I don't think it's possible to record directly to cd. You can record from an external device to your PC and then burn that file. Depending on what you're trying to do depends on what software you'll need. Sound Forge is an excellent bit of software for recording. I use it to record when I play on my record decks, but it's the industry standard and isn't cheap. I think that the latest Roxio has a 'Record Now' bit of software with it.
Basically, you want to plug your external music device's output into your PC's input. (Normally the pink socket) and then use whatever software to record the input.
Be careful with the levels. You want it peaking just on the edge of the red!!
Nov 19, 2008 | Computers & Internet
Need help
first you need a music recorder like Audacity.
dependent on what you have, CD or DVD drive.
then you going to need a CD or DVD recording software like Nero, Roxio
recode the music from the internet, then you need to input the file to either Nero. or Roxio, then you can record them to the media.
Jul 28, 2008 | Envision EN-7220 17" Flat Panel LCD...
How do I get a Verbatim DVD RW disk to record a file that i have downloaded
1. You need a drive that will record on a DVD RW.
2. You need software that will let you record to a DVD RW (such as nero, roxio, there are others)
If you have the above the two, it depends on the software you use on how to record to the DVD RW.
Jul 01, 2008 | Computers & Internet
USB Audio Recording
well its midi keybord u will need sum hi tech gear here mini box usb for your pc to get controller keybord in it thats if it has midi outs most better hi end models all have midi out need to go to guitar center buy usb interface for pc recording ok to put in midi devices ok now if u wanna get crazy u can us eyour headphone out to eth in mini jack into your sound card in but most sound cards dont have software to record only x fi sound blaster higher end models will creative recorder program u can use that to record what u here from aux in jack save as hi end mp3 then drag drop to nero to burn a cd ok got all that
Dec 05, 2007 | Ahead Software Nero 6.0 (60045) for PC
Problems recording DVD
It sounds to me like you are having driver or software trouble/conflicts with CD/DVD monitoring programs. After booting, look in the lower right hand corner and see if there are any icons like DISK AT ONCE or VIRTUAL DISK MONITOR running. If you have any programs running in the system tray, it is probably that which is causing the problems.
If worse comes to worse, go into CONTROL PANEL, ADD REMOVE PROGRAMS and then remove any program that involves CD or DVD writing, such as ROXIO, NERO, SONIC, any of these. After removal, reboot, and then once everything is up and running try inserting a blank DVD. If it runs correctly (should show a blank disk or ask you what you want to do with a blank disk), then it was a software driver problem. Once fixed, you can either reinstall your old CD/DVD writing management program (like Nero or Roxio), or try a more stable and higher quality alternative (like the excellent, and free, DEEPBURNER), which is less likely to have driver/software problems.
Good luck...
Nov 21, 2007 | Microsoft Windows XP Professional for PC
HP Media Center m7060n PC Desktop Logo
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
