Question about HP Pavilion dv6000z Notebook
External monitor Hi, I have hooked up an external monitor via VGA to my HP pavilion dv6000. Everything runs fine except when I run normal windows, I have no desk top, icons, background, or anything. The only thing that displays is the mouse cursor. Although when I boot in safe mode, everything is displayed, and fully functionable. I understand that it's a display issue, so please bare with my retardedness. Thanx a million.
  • 55 Answers
This does not appear to be a display issue but more of a failure of explorer to load. Try pressing Ctrl + Alt + Del so it brings up task manager. Click file then go to new task and type Explorer and see if all of your icons and such show up. If they do you will want to install a spyware remover such as spybot search and destroy from safer-networking to check for any spyware that is preventing explorer from running. Also check your event viewer in safe mode and see if there are any errors when you boot.
Posted on Dec 19, 2008
Hello, I have a problem with my HP DV6000 laptop.
The video card. is out In that case I suggest to buy a new laptop because its more cheaper and transfer all the data from the old one to the new one.
Nov 01, 2013 | HP Pavilion Computers & Internet
Yellow screen hp dv6000
The screen is faulty or the screen cable has become dislodged. Best take it to a repair shop.
Oct 12, 2017 | HP Computers & Internet
Keyboard lights up screen stays black....after inserting recovery disk screen still remains black...
Would like you to attach an external monitor for a diagnoses.
A VGA monitor.
Can be a CRT monitor that resembles a small TV, or a flat LCD screen monitor, that has a VGA cable attached,
http://en.wikipedia.org/wiki/VGA_connector
1) Laptop OFF, monitor OFF, attach the VGA cable of the monitor to the laptop's VGA connector.
[For the HP Pavilion dv6000z Notebook PC, the VGA connector is on the Left side at the Rear. Second port from the rear. 15 pins.
3 rows of 5]
2) Turn the monitor on. If a CRT style allow it to warm up.
3) Turn the laptop on.
By default the display should show on the external VGA monitor.
If not, press, and hold down on the FN key,
(Second key from the left, on the Bottom row on the Keyboard),
and tap on the F4 key.
(Top of Keyboard towards the left)
Still no? Hold the Fn key down again, and at the same time tap on the F4 key.
There are 3 display options;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
IF, the display shows up on the external monitor, and if it is OK, the problem lies in the Display Assembly, and/or the Video Cable.
More on that in a moment.
IF, the display does Not show up on the external monitor, or if it is garbled, the graphics chipset is bad.
HOWEVER, there is a problem with the graphics chipset, for the dv6000 series of HP Pavilion Notebook PC's.
More specifically it isn't actually the graphics chipset itself, but the mounting of the graphics chipset to the motherboard.
More on this in a moment.
External VGA monitor shows a good display;
Video Cable:
The video cable is checked for apparent damage first, and at the same time, see if it's connectors are tightly plugged in.
On one end, the video cable is plugged into the motherboard.
(ALL power removed, AC adapter { Charger} and Battery, the Switch Cover is removed, and the Keyboard, far enough to lay it back out of the way. Keyboard Cable still attached to motherboard. The Display Cable is the one to the Far left, right under the left side of the LCD screen. The cable next to it, to the immediate right, is the Microphone Cable )
The video cable routed from the connection on the motherboard, up under the left Hinge Cover, and into the Display Assembly, where it then attaches to the Back of the LCD screen.
THIS connection must be checked also.
{ Just gave advice similar to this earlier. The asker's problem turned out to be a loose video cable connection, on the back of the LCD screen }
Examine the sheath of the video cable. See if there are signs of damage. If so the tiny wires inside the cable could be damaged.
Apparent damage or not, you may want to remove the video cable, and perform a continuity check with a multimeter. (Ohm's. Check each wire in the cable)
Video Cable connections prove to be tight, video cable continuity check proves video cable is OK, move on to the screen Inverter.
Primer:
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, or a series of LED lights.
The Backlight is a CCFL for an HP Pavilion dv6000z Notebook PC.
[It is 2mm Wide, and 334mm Long. Or a little thicker than 1/16th inch Wide, and a little over 13 inches Long ]
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
A screen Inverter is used to convert power (Electricity) from the laptop, FOR the Backlight, and LCD screen.
90 PERCENT OF THE TIME the fault is a bad screen Inverter.
Example of a screen Inverter for a Pavilion dv6000z Notebook PC,
http://www.nylaptopparts.com/index.php?main_page=product_info&products_id=560
The thin plastic frame that surrounds the LCD screen, and is in front of the LCD screen, (Resembles a picture frame), is the Display Bezel.
The screen Inverter is located behind the Display Bezel, and at the bottom of the LCD screen area.
http://www.insidemylaptop.com/remove-replace-lcd-screen-inverter-hp-pavilion-dv6000-laptop/
http://www.insidemylaptop.com/take-apart-hp-pavilion-dv6000-laptop/
External VGA monitor does NOT show a good display, it is a graphics chipset mounting issue, more to follow.
Regards,
joecoolvette
Jan 15, 2012 | HP Pavilion dv6000z Notebook
Hp pavilion slimline s3100n doesn't display on the monitor. boots fine and fans spin and stuff, it just doesn't recognize its own VGA output. What do i do?
Hi
First,try hooking it up to an external monitor if you have access to one.Unfortunately,we need video to start checking for what may be wrong.
Try the monitor and post back to let me know what happens,and if it shows on the external display we can start looking at potential problems and fixes.
Bob
Aug 21, 2010 | HP Hewlett Packard Pavilion Slimline...
My HP Pavillion zt1170 has a very very very faint monitor but i can hook up a vga cable to my desk top monitor and see it fine. What is wrong?
the lamp on the monitor is going bad or the power inverter (which gives power to the monitor). You have to take it to a repair shop. We cant tell you without actually looking at your laptop. But it's definetely a hardware issue, not software. I hope this helps
Apr 27, 2010 | HP Pavilion zt1170 Notebook
The monitor on my laptop does not work. The laptop starts up by pushing the power button but the monitor does not come on. Its a HP Pavilion dv6000.
now u put the monitor to ur laptop by cable vga and u use fn+f4 to wiew in external monitor if u can see ur lcd laptop are problem, if not see anything u much check before ur memory try with another memory. good luck 4 u
Jan 14, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Hi, I was using my HP Pavilion notebook with Vista when it froze. The cursor wouldn't move and I was unable to do anything. I tried contol/alt/delete to shut it down, but that didn't work. I then held the...
you could have accidently changed to external monitor with Fn +F(the number is 8 on my comp but could be 5 on yours-check keys on top of the keyboard it has a picture rectangle / little TV), anyways to check that attach external monitor to your laptop(must have a VGA cable) if you have a picture on external monitor try Fn + F(depends on what you have on ur keyboard) it should bring you a window with choices to choose laptop LCD or external LCD choose 1st one .
hope that is it.
Dec 28, 2009 | HP Pavilion dv6000z Notebook
I have a Hewlet Parkard desk top that bleeps
dv2000/dv6000/dv9000 recall I have an out of warranty dv9000 and haven't had wireless for months. I just discovered HP issued a recall for the wireless and other problems with several different Pavilion and Presario models. For the wireless problem with the dv9000 they are replacing the motherboard on all notebooks in or out of warranty. I was wondering if anyone has had the repair done under the recall and how it turned out? I'm also wondering if HP is still cosmetically trashing notebooks when they are sent in for repair?
Here is the link for the recall:
http://h10025.www1.hp.com/ewfrf/wc/d...842189&lang=en
Nov 01, 2009 | HP Pavilion dv9000z Notebook
Monitor and LCD detection problem on HP DV6000
I HAD SIMLAR PROBLEM WITH ANOTHER MODEL TURNED OUT TO BE THE LID SWITCH WAS STICKING HOPE THIS WILL HELP
Dec 07, 2008 | HP Pavilion dv6000z Notebook
N5350 will not power up with power adapter
Are you certain the panel didn't simply give out? Try attaching an external monitor via the rgb/vga connector. If everything id running, then thst is the likely culprit.
Oct 30, 2008 | HP Pavilion N5350 Notebook
HP Pavilion dv6000z Notebook Logo
71 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
