Question about Maxtor One Touch II (EO1E200) 200 GB Hard Drive
Insert a s/hand HD into a pc as a replacement HD?
I want to replace a HD with a HD that has a geuine XP program installed, what r the problems,,will it start up ok,, or is this a big problem to attempt?
  • 55 Answers
If it is from an identical PC there are no problems with doing this. If it is from a different model computer you will need to update drivers if you can get it to boot. Depending on how different the model of computers are it may cause a blue screen of death upon boot. This is a very risky and difficult task if the computers are different.
Posted on Dec 19, 2008
My pc says"boot failure,insert boot diskette in A"
If XP was not installed on the HD from your computer then the computer won't boot from it. Reinstall it.
The system may not see your HD. As you boot, go to the boot menu and see if the HD is listed. - If it's not, see if the HD is well connected to the motherboard. - If it is then re install XP.
Sep 16, 2011 | Microsoft Windows XP Home Edition
My old hard drive on my COMPAQ PRESARIO C306US died, after I replaced the drive I tried reloading windows XP and I get an error that the hard drive could not be found. I loaded Ubuntu and it recognized the...
check the HD if its properly inserted,if the old one is working before then the new one you bought my be a damage one. try to replace another HD to see if which HD is working or not.
Jun 06, 2011 | HP Compaq Presario C306US Notebook
Replaced HD and CD Rom drive, PC will not boot to disk, Do I need to format HD 1st. before loading OS?
Hi Get to the bios screen using F8 or F9, change the first boot device to CD ROM/DVD, then insert a bootable disk into the CD drive and try installing the OS first by completely formatting the HD during installation Win XP and higher OS editions give you the option to partition the HDD Hope this resolves
Nov 05, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
I recently had a HD crash and have replaced it with another HD using the same Windows XP OS. While trying to reload programs that were on the old HD to the replacement, some of the programs get this error...
I always receive a "C:\WINDOWS\SYSTEM32\AUTOEXEC.NT" error message.
“C:\WINDOWS\SYSTEM32\AUTOEXEC.NT. The system file is not suitable for running MS-
DOS and Microsoft Windows applications. Choose ‘Close’ to terminate the application.”
This error message is not caused by the installation CD-ROM, but rather by the
“Autoexec.nt” system file. Windows is unable to find this file when launching the
installation CD-ROM, the file most likely having been deleted by another application.
To resolve this problem, proceed as follows:
1. Go to “C:\Windows\repair” and find the file “Autoexec.nt”.
2.Copy this file to “C:\Windows\system32”.
3.Right-click the file “Autoexec.nt” that you have just copied, and select
“Properties”.
4.Tick the “Read-only” box and then click “OK”.
Aug 06, 2009 | Microsoft Windows XP Professional SP2 Full...
Just bought a laptop cheap as on trade me for extra battery was told that it was broken but fired it up and works but is asking me for a user name and password to log on to windows. can i over ride it or...
keep the laptop, hope it got a working cd-rom/dvd-drive !(if not, take-out /replace the harddisk)
-win xp has to be removed from harddisk,
the hd must be formatted so you got a blank hd to set up your new system
you'll need :
- antoher PC with internet connection and cd/dvd-burner
- a win98 installation cd or bootable savecopy of it,
- a new win-xp install cd plus cd-key
- a program called PC Wizard(download)
and a bit of time...(one night or two:-)
follow instructions:
if you can enter bios (press F1 or F2 or Del)
during booting), youre lucky...
enter bios while booting, in the menu look for boot otions or devices, change order of boot devices, so that cd/dvd-drive is 1st, then save and exit (F10)
insert win98-CD, boot from cd, try to setup win98, you'll be asked to erase/ format all data/installations/partitions
on the harddisk (drive c:,probably), do so, format the drive using the FAT32-file system,
then end installation without fully setting up win 98.
now you should have a blank disk witout any operation system on it.
now put in win xp cd, go through the whole installation process
install and run pc wizard(it'll tell you all hardware devices of the laptop)
get the proper drivers for the notebook for win-xp from the net(google might be helpful)
install them.
happy computing!
if all this did not work, remove the harddisk,(you'll have to unscrew a lot of the laptop)
replace it by a new s-ata ide-drive()and..
erh.. come again then, this is a long process as well
Jul 23, 2009 | Microsoft Windows XP Professional SP2 Full...
Hard drive died & replaced with a new hd
Make sure your pc is recognizing the drive before installing any program. If the drive is recognized but is still not booting, then reset your pc as soon as the pops up press f12 which will show a list of the booting order you of course will want to select cd drive or you can enter f2 and make the booting configuation changes thru your BIOS in the Booting Sequence. change the order or replace the drive or drivers and Voila Your good to go, Hope this helps
Good Luck =)
May 29, 2009 | Dell Latitude D505 Notebook
Fujitsu c series lifebook can't install window
with the windows xp cd go through it as though you are going to re install xp but instead go to recovery console and run the command
chkdsk c: /r
assuming c: is the drive letter and that should check the hard drive - if the hard drive has problems then thats your issue, if not then run a re install of xp
Apr 30, 2009 | Fujitsu LifeBook C2340 Notebook
I am replacing the hard drive in my Dell Dimension L866r
Do you have a floppy drive in the drive if so remove it. Also turn off your floppy drive or just remove it completely it could be bad sending false info to the main board saying there is floppy drive in the computer. Also try and turn the drive off in the BIOS
Jan 16, 2009 | Dell DIMENSION P3/866MHZ 128MB 20GB DVD...
Purchased computer model Elite 9070a have been well serviced with HP products this being 3rd HP computer we have purchased. However am very disalusioned with Vista program and wish to replace with windows...
You sound like you tried to install XP with Vista running - this will generate the message that you have received.
To install XP on your system, insert your XP disk into the computer and then restart it.
Select Boot From Disk during start up and this will lead you into the XP Installation.
Xp will not recognise Vista and will just overwrite it - deleting the current OS and formatting the C:\
Good luck.
Apr 23, 2008 | Computers & Internet
New XPPro Install... Can't see HD
Try to download a widows XP based driver for your Promise Controller from the manufacturer's website and install it. This is really necessary. If it does not solve the problem, you reinstall windows XP. When XP begins installtion it flashes a message like this: "Press F2 to install a third party driver......" Press F2 and insert the Promise controller driver in a floppy. This way it will work. (I hope so..) Note: Do not remove floppy untill Windows finishes installation
Sep 26, 2007 | ASUS A8V Deluxe Motherboard
Open Questions:
Maxtor One Touch II (EO1E200) 200 GB Hard Drive Logo
60 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
