Question about Lexmark T632 Laser Printer
I have a Lexmark T632. I just changed computers and went from a Parallel printer cable to a USB cable. The new computer did not have a Parallel port. I CAN' PRINT NOW and I am screwed big time. Anyone know How to fix this? I can't find any Phone Support open this late (1:10 EST AM). HELP !
  • 66 Answers
HI ApollonC,
You probably need an USB to Parallel adaptor. See
http://www-user.tu-chemnitz.de/~heha/bastelecke/Rund%20um%20den%20PC/USB2LPT/lpt2usb.htm.en
Rgds
S88
Posted on Dec 19, 2008
What kind of cable is needed to connect a Fargo DTC 520 to a computer?
The cable you need for that printer is a Parallel IEEE1284 Compatible Bi-directional printer cable. It is the regular printer cable everyone used before all the printers went USB. If you dont have a parallel port on your computer, the link below is to USB Parallel adapters that you should be able to use with this printer.
USB Parallel Adapters from Tigerdirect.com
I hope this answers your question. Have a great day!
Apr 06, 2011 | Fargo DTC520 Thermal Label Printer
I recently purchased a new pc hp2009m and the cord on my lexmark e250dn does not fit my pc how can i adapt please advise. Colin
This printer has three standard ports: bi-directional parallel, USB, and ethernet (RJ-45). Most likely your previous computer had a parallel port. The simplest solution is to get a USB cable (Male type A to Male type B - 6' or less in length is recommended.) Install the software on the computer then connect the cable to the port on the back of the printer and to the computer (the square end goes to the printer and the rectangle fits the computer). The USB port is in the same area on the left side of the back of the printer as the parallel port.
Alternatively you could get a network switch and connect the printer as a networked printer. The ethernet port is near the middle of the back of the printer.
http://support.lexmark.com/index?page=recommendedDownloads&locale=EN&productCode=LEXMARK_E250D&segment=DOWNLOAD&userlocale=EN_US#1 has the software and drivers for support OS versions.
I hope this helps.
(Getting a bidirectional parallel to USB adapter is cludgy when you have a USB port available.)
Jul 01, 2010 | Lexmark E250dn Laser Printer
Communication problem printer lexmark2600
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC, as explained below.
Frequently, issues are caused simply by a break in the signal sent from PC to printer or vice versa.Unplugging and re-plugging the printer allows the small amount of on-board memory on the printer to be cleared, with the result that the PC recognizes the machine properly.
Programs continuing to run in the background of the operating system (OS) can cause the signal to be lost. Rebooting the PC ends all programs that may be running and makes a 'clean' start, allowing the signal to be detected.
The Basics:
  1. Check your cables and their connections. Reconnect the parallel or USB cable to the computer and to the printer. Make sure there is a direct connection, with no scanners, switchboxes, or hubs inline. Other devices can sometimes cause communication problems between the computer and printer. For more information on this issue, see 'Scanners and Other Devices' below.
  2. Remove the power supply cord and reattach it to the printer. The printer should make a noise soon after the power cord is reattached. Note: This is a general diagnostic that seems to fix minor communication issues.
  3. If you are using a parallel port, verify that your computer is set up for bi-directional communications. If bi-directional communication is not enabled on your computer, the parallel port mode setting in the computer CMOS setup will need to be set to either bi-directional or ECP. Do the following:
    1. Right click on My Computer and select Properties.
    2. Click Device Manager. You should see a section called Ports (COM & LPT). There should be a (+) sign to the left of that section.
    3. Click on it, and look for ECP Printer Port (LPT1). You may need to contact your PC manufacturer if any of the following are true at this point:
      • It does NOT say ECP in the description.
      • There is no listing for Printer Port or any variation of'LPT.
      • There are question marks or exclamation points next to the LPT1 port listing.
        Let your PC manufacturer know what you are trying to accomplish and what you have done up to this point.
  4. Go to Start, Settings, Printers. Right click on the Lexmark object and select Properties.
  5. Click the Details tab.
  6. Under Print to the following port, it should say LPT1 for parallel cables and USB Lexmark or USB00x (<x> = 1-9) for USB cables. You can change these values by clicking on the arrow and selecting a new value from the list. Click Apply, and OK.
    If you are using a USB cable and the USB value is not in the list, try uninstalling and reinstalling the driver as detailed in your manual.
    If you are using a parallel cable and do not see LPT1, you will need to ask your PC manufacturer to walk you through the process of turning your parallel port on. You will also need to make sure the Lexmark printer is set as default. If not, right click on it and select the default option.
  7. If the printer does not work when connected directly to the computer's port and you have complied with the steps above, there may be a hardware problem. In this case you should perform a self-test on the printer. (Click Start a New Search above this solution and enter self test in the search field.)
Scanners or other sharing devices could cause communication problems.
  • If you are using a parallel connection, please verify that your cables, scanner, or other sharing devices are IEEE-1284 compliant .
    If you are using an USB connection, they need to be at least USB 1.0 compliant.
  • If the printer prints normally without the scanner/sharing device and its cables, there might be a problem with the scanner/sharing device. Please contact the manufacturer for information on how to fix such issues.
    Note: Although connecting devices through a scanner (or other sharing device) may work, we do not recommend or support the use of such devices as they can interfere with the signal strength that is sent to the printer. Please contact the manufacturer of the scanner/sharing device regarding communication issues for that specific device.
USB Issues:
  2. Click Device Manager. Click on the plus (+) sign next to Universal Serial Bus Controllers. The host controller listed here is the software that runs your USB ports. It is linked to a chipset on the motherboard that requires frequent updates to satisfy the needs of newer products such as your printer.
  3. Look at the name of the host controller. Some of the more common names are Ali, Intel, AMD, Via, and SIS. You will need to contact your PC manufacturer to get help updating these specific controllers to the newest driver set.
    If YOU are the PC manufacturer, check the manual for your motherboard to find out who makes the chipset for the motherboard. Again, Ali, Intel, AMD, Via, and SIS are some of the more common manufacturers of chipsets.
  4. Look for either Lexmark USB Printer or Other Devices in the Device Manager.
  5. If you see anything with Lexmark..., click on the plus (+) sign to its left and look for Inkjet Color Printer below it.
  6. If it is present, double-click on it. Tje next screen should report that the device is working properly.
  7. If you see any question or exclamation marks listed in the Device Manager (small yellow icons next to the listings), double-click on those items to obtain information on what's wrong with the items. This information is useful for troubleshooting the system.
  8. If not or there is nothing present, you will need to uninstall and reinstall the printer driver software, or download a newer version from our web site. Click here and follow the link to our Drivers & Downloads center.
  9. It is also recommended that you connect your printer to a USB port that is hardwired or "part" of the motherboard. USB ports that are located in the front of the PC and those that are located in the expansion card slots may cause communication issues if used for printing. You should always try to use the USB slot that is located near your peripheral slots, i.e., your mouse, keyboard, parallel and serial ports.
Docking Stations:
If you are using a docking station, try using the printer with a different, standard computer with parallel equipment as a test. You may want to contact the manufacturer of your other device for information on the correct functioning of a pass-through device. If the printer does not function correctly when directly hooked to a computer, the hardware may be at fault and the printer will need to be run through the self-test.
Converters/Adapters:
Lexmark printers do not support USB/parallel adapters and will probably not work. Nor will any USB/Parallel constructed cables. Our printers require either an IEEE 1284 bi-directional parallel cable, or a USB v.1.0 or 2.0 A/B style cable. Some printers can only use the parallel cable, some can use only the USB, and some can use either one. However, Lexmark cannot support printers hooked up to computers with a cable that attempts to cross between parallel and USB platforms, as this will cause communication issues.
Software Interference:
A piece of software may be interfering with the printer's communication ability, or your computer may be experiencing a system resource problem. We can try to alleviate these issues by putting your computer into Selective Startup mode. This will prevent any software applications other than Windows from loading when the system starts. To do this:
  1. Click Start, Run.
  2. Type MSCONFIG on the Open line, then click OK.
  3. When the System Configuration Utility opens, place the marker dot beside Selective Startup. Below that, deselect Load Startup Group Items. Then click Apply and OK. You will be prompted to restart the system.
  4. When your system restarts, only the Windows operating system should be running. You should not see any icons in the lower right-hand corner of the screen, beside the clock.
  5. Try your action again. If it works, the source of the problem was one (or more) of the applications that were loaded into memory.
  6. You can return your system to its original configuration by clicking Start, Run, typing MSCONFIG and clicking OK. This time, select Normal Startup, click Apply and OK, and restart the computer.
Dec 02, 2008 | Lexmark X2500 All-In-One Printer
I have been unable to print to my lexmark z11 color jetprinter. pages come out blank. I received an error messarge saying : there was an error writing to LPT1 A printer timeoout error occurred. To...
This sounds like more of a communications problem than it does a "time out" problem. I am assuming that the printer is connected to the computer via a parallel cable. If that is the case, try unplugging the cable at both ends, the reattaching it. If that does not change anything, try replacing the cable.
If that does not solve the problem, try replacing the parallel cable with a USB cable and then follow the directions below.
If by some outside chance you have the printer connected to the computer via USB cable you can do one of two things. Replace the USB cable with a parallel cable or change the printer's port settings to use the USB cable. - If you do have the printer connected via USB cable you might be able to rerun the installation software that came with the printer and it may automatically pick up on the USB set up. If not, go to Contro Panel\Printers and Faxes\ - Right click on your printer and open properties. Under properties, click on the Ports tab. Since the error message stated "error writing to LPT1, check to insure that the LPT1 block is checked. If it is, and you are using a USB cable, scroll down until you see two blocks - "USB001 Virtual printer port for USB" and "DOT4_001". Check the box beside "DOT4_001" then click on Apply and close the window. The try printing again.
Hope that helps - Graye
Nov 24, 2008 | Lexmark Office Equipment & Supplies
My printer doesn't have the usb to connect it to the computer - what do i need to do?
If the printer does not have the square USB connector (USB B end), then it will have parallel. Parallel is a wide connector that plugs in to a DB25 connector on the back of your computer. These parallel port printer cables can still be picked up at just about any office supply or computer store.
What if your computer does not have the DB25 parallel port but the printer does? Well there are USB to Parallel Port adapters made specifically for this scenario. They can run $10 to $30 depending on where you go. I recomend www.Geeks.com for those. That will allow you to plug an older printer in to a newer machine.
If it's made for a mac only, there should be a small circular port about the same size as a PS/2 keyboard or mouse. That is to connect to the Mac serial bus. This is differant than the barrel connector or brick used to supply power to the printer.
Hope this helps.
Oct 16, 2008 | Lexmark Office Equipment & Supplies
Where to connect on computer
The printer will have one of two cables , either it is a USB cable , or an LPT cable
USB Cable Looks Like This:
The LPT Cable Looks Like This:
If it is the USB cable , it will connect to the back of your computer in a USB port, which looks like this:
It it is the LPT cable , it will connect to the back of your computer also:
Sep 29, 2008 | Lexmark Office Equipment & Supplies
Printer stays offline on Vista
To help you resolve this problem, try the suggestions below.
The Basics:
* It does NOT say ECP in the description.
* There is no listing for Printer Port or any variation of'LPT.
* There are question marks or exclamation points next to the LPT1 port listing.
* If you are using a parallel connection, please verify that your cables, scanner, or other sharing devices are IEEE-1284 compliant .
* If the printer prints normally without the scanner/sharing device and its cables, there might be a problem with the scanner/sharing device. Please contact the manufacturer for information on how to fix such issues.
USB Issues:
Multiple PCs:
The printer cannot be connected to multiple PCs at the same time. This includes, but is not limited to, using both the USB and parallel ports of the printer and the use of switchboxes. The system board on the printer will get confused at multiple requests for status, even if one computer is off and the other is on.
Docking Stations:
Mar 04, 2008 | Lexmark X6170 All-In-One InkJet Printer
HP Laser Jet 1320n series
The HP LaserJet 1320 has a USB port and a Parallel port.
The HP LaserJet 1320n has a USB port and an Ethernet port.
USB-to-Parallel converter cables, like this one, are designed to attach a parallel device to a computer's USB port.
But you need to do the opposite (attach a USB device to a computer's parallel port). A USB-to-Parallel converter cable will not do this.
Feb 29, 2008 | HP LaserJet 1320n Printer
Lexmark T632 Laser Printer Logo
108 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
