Question about ParkerVision SIGNALMAX WR1500 (884181000031) Router
Specifications for AC Power Adapter
What is the OEM transformer Output and plug polarity (inner / outer) for the PV Signalmax wr1500?
In is 110-120 vac and 12.0 vdc.
Hope this helps!
Visit us at http://www.nipycom.com for more help.
Posted on Mar 14, 2009
I HAVE AN AC ADAPTOR,… CLASS 2 TRANFORMER FOR OUTDOOR USE THAT NEEDS TO BE REPLACED.. MODEL: KMUA - 240 - 05000- 66UL INPUT: 120V - 60Hz 570mA OUTUT: 24V - 50VA
Amazon has it.
AC Power Adapter 120V input 24V 50W (50VA) output, UL listed
www.amazon.com › ... › AC Adapters
Mobile-friendly - AC 24V Power Adapter; 50W Output (50VA); 120V AC Input; UL Listed; Ivory Color item in OEM box ... 24V20AC 24V AC 20VA Transformer Input: AC 110V / 120V 60Hz Output: AC 24V 880mA
Dec 09, 2015 | Computers & Internet
I need to know the POLARITY of the AC adaptor to provide the correct setting using a universal adapter.
there is no polarity in ac current as ac means alternating current and that means alternating between positive to negative back to positive back to negative and so on
only dc ( direct current ) and the center pin of the plug is designated as the positive pole has polarity, the outer case being the negative
OR Are you asking the voltage of the ac adapter and the voltage of the dc output side of the adapter
Nov 26, 2015 | Office Equipment & Supplies
Need the transformer specs for ParkerVision WR1500-WR3000
p/n 30-112-120602
model ad48-1201200du
here you go
input 120vac 60hz 250mA
output 12vdc 1200mA
Apr 26, 2010 | ParkerVision SIGNALMAX WR1500...
Vector VEC438 AM/FM/Weather Radio my AC adapter
I have one of these too. Here is the information, in case you don't still have the adapter.
Ktec
Model KA12D090050034U
Input 120V AC 60Hz 95mA
Output 9V DC 500 mA
The inner part of the plug is the positive side.
Try googling the model number above. I did and found several sources. If you still have the adapter and only the power supply itself is bad (but the plug is still good), you may be able to splice on another 9 volt DC adapter, as long as the power output is 500 mA or greater. If you go this route, make sure to check the polarity before plugging it into the radio.
May 06, 2009 | Vector VEC438 AM/FM/Weather Radio
Gateway 405ROG AC Adapter Output Polarity
it doesn't matter if its + or - , make sure the pc runs on 19 volts and that the AC adapter does also, look underneath the laptop to find out if it does run on 19 volts but make sure the power jack fits the socket o the laptop before plugging it in to the mains
Nov 11, 2008 | Computers & Internet
Voltage/Ma of AC adapter for WR1500??
The power supply on my ParkerVision WR1500 router is 12 vdc, 1.2a, center pin positive. http://straylightsoftware.com/downloads/parker2.html
Oct 29, 2008 | ParkerVision SIGNALMAX WR1500...
Hi; I Have a Dell XPS 1530 which is dull if I do not have it plugged in. I have three Targus power cords and cannot use any of them. The one that has the S35 tip fits, but only engaged...
I am showing the AC adpater specifications as:
Input Voltage Range: AC 100V - 240V
Output Voltage: DC 19.5V
Output Current: 4.62A
Power: 90 Watt
Does your adapter meet those specifications?
Although I am a proponent of Targus products, possibly purchasing an OEM adapter may solve the problem. We have successfully purchased ones available from reputible vendors on eBay at a discount.
Have you checked to always show the battery status in the system tray so that you can verify when the AC adapter is actually charging versus an intermittent connection or malfunctioning power socket?
Oct 22, 2008 | Computers & Internet
Power supply/ no output voltage
Actually i haven't fixed the problem as yet but i did find some info that would help me to fix problem.
I went to google and entered keyword,,, Electronic parts,,there came up a page,,and i went to several manuf sites till i found a replacement transformer,,then i disassembled the power supply and am now waiting for a replacement transformer.
Sep 21, 2008 | Boston Acoustics MicroMedia Computer...
Cpqusbfw usb hub
i have one of those hubs the ac adapter is output +5V, and current 0.2 - 2.5A, inside of connector is pos(+), outside is neg(-), input: 100 - 120 Vac and 0.45A Max
Aug 30, 2008 | Micro Innovations Compaq CPQ24USB
Power Supply
Have a look an the underside or back of the unit and see if it has a label on it with the voltage and current requirements.
May be something like 12v - 1Amp or similar like 15v - 800mA,
12v - 1200mA etc. These will more than likely be DC as the power supply has the electronics to convert the mains AC to low voltage/current DC.
If you can find them it will be easy to shop around for a power supply to match. It may also show the polarity of the plug that plugs in to the router from the power supply. i.e. outer = Negative (-), center hole =Positive (+).
Mar 04, 2008 | ParkerVision SIGNALMAX WR1500...
ParkerVision SIGNALMAX WR1500 (884181000031) Router Logo
64 people viewed this question
Top ParkerVision Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
Percy Silwane
Level 1 Expert
Are you a ParkerVision Computer and Internet Expert? Answer questions, earn points and help others
