Question about Dell Latitude CPX Notebook
Battery I dropped the battery from my Dell Latitude and when I put It back into the laptop It discharged very quickly the compute still operates but in the cmos it shows the battery discharging If I charge the battery out of the computer it comes up to full 14.8 v and holds The charge but as soon as i put it back into the computer it discharges again.???
    Genius:
  • 3,587 Answers
Voltage on a battery is fine. current(charge/discharge) on other hand is what keeps it running. The battery you have, MAY be fine, yet the risk isn't worth it. Good news? They don't leak, but why take the chance on having your computer die in middle of something vital.
Posted on Feb 02, 2008
  • 624 Answers
As you have probably already figured out it sounds like the battery is damaged. Due to the potential fire hazard I would immediately remove the battery even if the laptop is off and discontinue its use until you are certain it is working correctly. Laptop batteries are not safely repairable by users and most technicians. Other than inspecting for bent pins there isn?t much you can do. If the battery is less than a year old you can call Dell, tell them it doesn?t work and see if you can convince them to warranty replace it. Batteries should not become unusable by a normal 3-4 foot drop. If it?s out of warranty I strongly suggest you try to borrow an identical battery to see if it behaves normally, or if that isn?t an option purchase another. Let us know if you have any other questions and please don?t forget to rate this post.
Posted on Mar 30, 2007
Dell c640 battery not charging
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Mar 02, 2013 | Dell Latitude C640 Notebook
Tip
Should I Remove the Laptop Battery?
Question: Should I Remove the Laptop Battery?
I have a dell latitude d820 laptop at home which I use as a desktop replacement. As such, 99% of the time the laptop is being used it is plugged in. I wonder if I should remove the dell latitude d820 battery so that it is not permanently being charged, or does the laptop cut off the current to the battery once it is fully charged? I do unplug the laptop when I turn it off.
Answer: When using a laptop as a desktop replacement the battery should not be left in for long periods of time. The laptop will over time discharge the battery. Remove the battery – making sure that it is charged to 40% and store it in a dry, warm place. Ensure that it is wrapped protectively and nothing will be dropped on it.
The battery should be re-installed every 3-4 weeks and allowed to fully discharge. Leaving a battery in storage for longer than this without using could cause the battery to fully discharge as the circuitry of the battery itself consumes power.
Leaving a battery in a laptop while using an electrical outlet for long periods of time will keep the battery in a constant state of charging up and that will reduce the life cycle of the battery.
Remember that when you have removed the dell vostro 1500 battery from a laptop while using with an electrical outlet – the automatic battery backup is no longer functional. Make sure to plug your laptop into an uninterrupted power source (UPS) not directly into an outlet or surge protector.
on Apr 20, 2010 | Computers & Internet
No battery is detected in dell 830
Jan 28, 2013 | Dell Latitude D830 Intel Core 2 Duo T7250...
Battery charging LEDs not light but charging up to 76 %
Oct 02, 2012 | Dell Latitude X200 Notebook
There are two blinking green lights that will not go off. The computer screen is dark. when i press the turnoff button, the computer green light on the right hand side of the computer continues to stay...
Unplug the laptop and remove the battery. The discharge the laptop by pushing the power button for 15 seconds while it is unplugged and does not have the battery installed. Then put the battery back on and power it up, and use your laptop as you normally would.
Nov 08, 2010 | Dell Latitude D600 Notebook
Mine is dell latitude d620 laptop.battery is new.problem is it was running both on ac and battery.suddenly battrey is not taking the charge but my laptop runs on ac power. can i remove the battery and run...
the batteries eventually wear out and quit taking a charge. You can run the system without a battery with no ill effects. replacements are about $100 for a new battery
Sep 27, 2010 | Dell Latitude D600 Notebook
Dell laptop battery has 3 lights flashing when hit battery tester
You can't get the modern batteries to come back to life. Time to get a new one.
A suggestion: When using a laptop battery, run it on battery and discharge it until it shows about 2 to 3% charge left at least once a month. Do not keep charging it without letting it run down periodically. Most important--do not run always plugged in to line current.
Sep 09, 2009 | Dell Latitude D810 PC Notebook
Battery help
yes and what did you drop ?
Sep 06, 2009 | Dell Latitude D600 Notebook
Dell latitude D600 battery charge light flashing
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
May 29, 2009 | Dell Latitude D600 Notebook
My Dell Latitude D610 Battery Stopped Working
The battery light flashing RED/AMber is an indication of a failed battery.
Portable batteries have a life expectancy of 300 to 500 recharge/discharge cycles. (roughly 18 months under normal use) After that, the charge life starts to drop off and eventually it will not hold a charge. Because of this, the battery is considered a consumable item and is only warranted for one year from the manufacturer.
Since all the systems listed in the post are D610's (4 to 5 years old) it is not surprising that the batteries are failing.
Dropped Puck, if you replace the battery and a new battery doesn't charge/run the system, then the charging circuit on the MB is failed.
Feb 22, 2009 | Dell Latitude D610 Notebook
Dell Latitude CPX Notebook Logo
53 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
