Cars & Trucks Logo
Posted on Aug 16, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does a 2008 dodge ram 5500 CUMMINS automatic Transmition get hot when i use my ac when the weather is hot outside
The transmition does not get hot when ac is off
Stephen
Level 3:
Top Expert:
  • Dodge Master 21,873 Answers
  • Posted on Aug 17, 2012
 Stephen
Dodge Master
Level 3:
Top Expert:
Answers
21873
Questions
0
Helped
6199542
Points
67230
Its possible the radiator is not cooling enough to handle the engine and trans. Depending on where the aux cooler is for the trans, there may not be enough air flow thru the radiator. With the condenser in front of the radiator the ac produces extra heat the radiator has to overcome.
5 Related Answers
Anonymous
  • Posted on Jan 10, 2009
SOURCE: Toyota Mr2 Automatic transmition problems
It sounds like maybe the torque converter might not be fully seated into the trans, try taking it out and re install and turn the converter clockwise then counterclockwise while keeping pressure on the front of the conv. until you feel three little clicks or thuds. When it is fully seated you should barely be able to get your fingers between the the bell housing and the converter. while you have the converter out check the front pump seal again for damage if it looks chewed replace it put some trans fluid on the hub that goes into trans, the shiney part then slide it in. Hope that helps also when installing the trans make sure you tighten the bellhousing bolts first then do the torque converter bolts, that way you won't accidently unseat the conv. You have to turn the flywheel to get to all the bolts make sure everything is tight and good luck.
Roger Foster
  • 701 Answers
  • Posted on Jul 07, 2009
SOURCE: where is oil pressure sensor located on 2001 dodge 2500 cummins?
Hello mhak330: My name is Roger and I can give you the answer to your question. Locate the ECM on the drivers side of the engine.look for the bottom bolt holding the ECM. To the right of the bolt you should see the oil pressure sender unit. Should you need further help please just ask. Please rate the quality of your answer. This way we know you received helpful information. Thank You for using Fix Ya. Roger
Anonymous
  • Posted on Jul 19, 2009
SOURCE: Trouble code P1740 on 1999 Dodge Ram 2500
I had the same code on my 2001 dodge 2500. The truck wouldn't shift from 3-4. I pulled the trans pan off and replaced a broken spring ($2.00). It is behind a thin plate with 3-4 small torq screws. You don't have to remove the valvebody. Only took me 45 minutes to fix.
I would like to give thanks to Jeff Russel from Teal automotive. He said this is a very common problem. He sells any part for any automatic Transmision and his prices are very affordable.
Here is a link to the website.
http://www.tealautomotiveinc.com/
Hope this helps.
Anonymous
  • 1206 Answers
  • Posted on Jan 15, 2010
SOURCE: how do i check the transmition oil an a automatic
on the right side of the engine compartment you should find a red plastic dipstick remove it from tube and check fluid mark do this on level ground and engine idling in park. fluid has to be between the add and full marks at bottom of stick use dexron 3 automatic transmission fluid the fluid is added into the tube the stick came out of.
Anonymous
  • 184 Answers
  • Posted on Mar 30, 2010
SOURCE: Recommemded engine oil for 2008 Ram 4.7L. Dodge
It won't hurt anything,so long as the oil is a little
thicker for hot weather use. Not 100% sure about
those grade of oils, but so long as it's a quality synthetic oil, I wouldn't worry about it.
VACUUM LINE DIAGRAM 97 DODGE TRANSMITION
you can get good diagrams at autozone library
SHIFTS POORLY WHEN THE WEATHER IS HOT
do you have an transmition cooler? if not its a good idea to install one,all so keep your fluid and filter changed,if you can afford it have a complete trany flush.
No forward or reverse: but the vehicle attempts to go forward when the shifter is placed in Reverse!
check the transmition oil level and if ok its maybe the transmition is broken
Dodge cummins tow haul stays on
Hi, I have a 2004 Dodge Ram 2500, 5.9 Cummins with 225,000 miles. Just today, my Haul/Tow keeps coming on and Trans/Temp light. Keeps automatically switching in and out on its own. It's been 100,000 miles since my last trans maintenance. Going to a mechanic close and he suggested to start with fluid change, filter change, and inspect the band, maybe adjust. Trans runs very smoothly. Checked the fluid, looks clean and not hot. Is this common with this year and mileage? If so, whats normally the out come? If the band is bad, do I have to replace the entire trans?
Scott
2answers
2004 Dodge Ram 3500 5.9 l cummins. My ac
Most likely culprit is the blower control module/ resistor. It is the part that controls the blower motor speeds.
My is shifting from 2 to drive back to 2 why is it doning that
Check your tranny fluid levels- if they are low your transmition will slip between gears, however if you notice any kind of free reving while its shifting (like being reved up when in park or neutral) then the hydrostatic clutches are slipping and the transmition needs repair.
Another thing you should investigate is your transmition kick down bar (it shifts the trany into a lower gear when accelerating hard to help pick up speed.
I HAVE A 2008 DODGE AVENGER AND IT WILL NOT GO INTO GEAR
check transmition oil refill to spec if low
Transmition problem
No forward or reverse? After you installed it how much fluid were you able to get in it before it read full?
2answers
Transmission code P1740
The transmition is slipping, dodge trucks are noted for their tranny problems, I just replaced mine ($2400)bearly over 100,000 miles on the truck. Watch the engine temp if you keep driving it. It may start to over heat. Get it to a reputable transmition shop ASAP,Some place that garentees/warentees their work.
As for the heat/AC I would check for vacuum leaks. Get either a Hanes or Chilton's manual for it and it will tell you how to check the system.
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
