I have a viewsonic vg2021, it was working perfectly now when i try and boot up computer it says analog - no signal then the light on the screen goes orange, Please can you asisst urgently...
  • bostonfan221 Jan 03, 2009
    Ya i got the same issue i dont know what to do either lol try to unplug everything and then re plug everything best i got...
  • grannystone Jan 15, 2009
    Same issue here with mac using digital input... about half the time it works, the other half it doesn't and I have to shutdown, reboot, turn off/on the monitor repeatedly until finally I get digital picture. Piece of **** monitor!!!
    Problem Solver:
Hi grazerone,
That typically happens when there is no video connection between the pc and the monitor. Are both sides plugged in?
Alternatively you may have put the interface cable into the wrong socket on the video card.
Regards,
Ebek
Posted on Dec 19, 2008
I cannot get desktop for internet Th screen say no signal analog. I only use it to surf the net the small light lights up
Are you using the DVI (DIGITAL) or the VGA (ANALOG) to connect to the PC? You may also have the caps that are going bad, see example here, you should check them out before too late.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Jan 11, 2010 | ViewSonic VX2235wm LCD Monitor
My viewsonic mo9nitor says analog not digital on
To clarify, you know that analog is referring to the VGA 15 pin video input, and digital is referring to the DVI video input, right? You can't have the digital video unless you use the DVI input, which requires a DVI output from your computer (and a DVI cord of course).
If you already knew this and you mean that it won't switch over to your DVI, then there could be several problems. Most of them being with your DVI signal source (computer). Try booting the PC with ONLY the DVI cord attached between the PC and the monitor. If you have a VGA cord plugged into either, UNPLUG IT FROM BOTH ENDS.
Dec 05, 2009 | ViewSonic Computers & Internet
No signal analog
Can you still see the boot up screen when you start your machine up?
If you do, then restart the system.
As it's booting up, you tap F8 until you get a menu. Select "Last Known Good Configuration". That will help if you installed a bad driver for your graphics.
If that doesn't help, or if you don't get a picture at all, plug the monitor into another computer and see if it works.
If the monitor works and you still can't get a picture after following the aforementioned steps on your computer, you may need to replace the video card on your system.
Jul 12, 2009 | ViewSonic VA721 17" LCD Monitor
No analog signal
Sounds like the graphics card is gone belly up. Try the monitor with another pc or just replace the graphics card.
Hope this helps
Jun 12, 2009 | ViewSonic VX2235WM Monitor
"no signal"
If you turn on your computer press the F8 key continiously until you get to a screen that gives you the option to boot in safe mode, select save mode, select your operating system, you will be able to login to your profile, right click on the desktop and click on the settings tab( TOP RIGHT HAND Corner) change your resolution to 800x600, Restart your PC. Now you should be able to login to windows and your profile like always. Cheers
May 25, 2009 | ViewSonic VX922 19" Monitor Flat Panel
Blank screen with intermittent operation
you have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
Dec 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Viewsonic VA1912WB error says analog signal
I had a Gateway 19" TFT that did the same thing.
Does the power light stay on? If so, you more than likely have "dry" solder joints at the inverters. Take it apart & shoot a little solder on the inverter solder joints. Good as new now. The solder joints dry out because of the high heat generated. This is a very common problem.
Apr 22, 2008 | ViewSonic VA1912wb Monitor
Viewsonic VA712b issuses
Digital-to-Analog Converter - DAC When referring to Audio, DAC is also short for Digital-to-Analog Converter and is the process of converting a digital signal into an audio signal.
Random Access Memory Digital-to-Analog Converter - RAMDAC Pronounced Random Access Memory Digital-to-Analog Converter, RAMDAC is the ... the digital data to an analog signal to be displayed on a computer monitor.
Good Luck, Please dont for get to Vote/Thank you.
Dec 19, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
Monitor has no picture
Yes! :)
Your monitor is not the problem. Check all the connections from the back of the monitor, to the computer.
"No Signal Analog" means your monitor is working perfectly, however is not receiving signal from the computer.
Didnt find any loose cables?
Try unplugging everything. Leave it unplugged for at least 5 minutes. You need to give the system time to drain all the excess power.
Again your monitor is fine, blue light > No signal > orange light is totally normal for your montior.
Oct 12, 2007 | ViewSonic VX922 19" Monitor Flat Panel
No digital signal but analog works fine
Seems like this was already answered? But once you've checked against the owner's manual and ruled out the PC, I would suspect the signal / video board inside the monitor. May have gotten a surge or static, etc.
Jan 11, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
Computers & Internet Logo
568 people viewed this question
David Payne
David Payne
