SOURCE: 62" Toshiba Theaterwide HD DLP
If your lamp imploded then your product is perm. damaged. You could have a service center come out and try to clean it, however, by the time you pay for that if its not under the warranty then its going to probly cost you just as much as you might as well towards a new one. Also, Toshiba is one of the worst manufacturers that has issue on their HM195 or HM95 series. They had plenty of recalls going on with that series. If you own that model, you might want to see if the manufacturer can do something for you if you are still within the recall guidelines. Use this as a tool: Click on: "Replace lamp" This is Samsungs website, however, replacing a DLP lamp is the same process in every manufacturers products. Use the prompts in the pop up you see from there. See if that helps. http://www.samsung.com/us/support/guides/howToGuideSearchList.do?group=televisions&type=televisions&subtype=dlptv&model_nm=HL-T6756W&dType=D&mType=UM&vType=R# Good luck!
SOURCE: need to install a replacemen lamp in a Toshiba 62
After replacing the lamp per the instructions:
SOURCE: Humming Noise at the back of my Toshiba 62 dlp
You probably should have the TV looked at by a technician. if your lamp is lighting up then most likely the noise is the color wheel itself.
SOURCE: I have the toshiba 62"
The tv projection Lamp shutdown 3-4 mins,than u hear alot of clicking noises sound too?Yes,than the board that call the Ballast board it is dead too.The Ballast board only job are to help to ignite the projection Lamp only.
